![]() Drives: 2012 45th anniversary SS Join Date: Jul 2012
It's been a sad last few days...
Yesterday I took my car and met a friend, while waiting I turned my car off because as much as I love my cam it does get annoying when just sitting. I go to start the car about 10 minutes later and it's not wanting to turn over. After trying 3-4 times the car finally turns over and I just thought I'll take it into my local dealership later. I go to pull into the gas station and look in my side mirror and saw a lot of white smoke/condensation and that concerned me as well. At that point I was going to take my car in as soon as I got gas. While pumping my gas I popped the hood just to make sure everything was alright which it wasn't... The same white smoke/condensation was flowing out of my oil breather cap. (I was not burning oil or low on oil.) At that point I got scared and drove slow and watched all my gauges to the dealership (all gauges normal).
I get the phone call today that 4 pistons warped from lack of fuel. Even though I have a zl1 fuel pump and a booster. They also tell me I melted 4 spark plugs and they ran a compression test on the motor. Tomorrow they're going to pull the heads and check the bottom of the motor for damage and check the piston walls to see what damage, if any, was caused. I'm just waiting until tomorrow with another night of me feeling sick over my car. Any insight on the possibilities of damage that could have been done or just any advice at all?
45th Anniversary. Borla LT(catless), Borla S type, CAI intake and Rhino79 installed whipple 2.9L, alky meth kit, 102mm throttle body , GPI tune, VVT custom competition cam, 416ci stroker, forged internals.
Scott's45
Drives: 2012 2SS 45th Anniversary Join Date: Mar 2012
Oh man, as a fellow 45th owner, I'm greatly saddened. Although I would be for any fellow camaro owner as well, but for a 45th even more. I'm not engine savvy, so I can't advise on anything, but wishing you the best. Hope all works out for the best. Keep us posted.
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Wow that is terrible. Looking over your list of mods I can say you are probably in for a big repair bill. Minimum engine rebuild, maximum engine replacement. Good luck and I hope it doesn't hit you too hard.
The Bird is the word! |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: too many Join Date: Jul 2013
ugg sorry expect the worst engine replacement.
Youch! Doesn't sound good (or cheap). Wishing you the best of luck.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
#6 |
Raining Blood
Drives: 2014 SS Performance Sedan Join Date: Oct 2009
Damn that's hard, I'm sorry for you. Why not use the free roadside, and get the car towed rather than drive it? BTW, who did your engine build? I'd ask them to look at it....
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
![]() 2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Z/28 #533 Join Date: Jul 2012
Sorry to hear that OP, best of luck with the repairs.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
It could be lots of things, like bad injectors or faulty fuel pump. Aaron will take care of you. Sorry you will be without the car for a while though.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
#9 |
![]() ![]() Join Date: Feb 2010
look into the tune! wideband tune?
#10 |
![]() Drives: FOR SALE! Bumblebee 1 of 1 Join Date: May 2010
When you did the cam, did you remove the AFM equipment and disable with a proper tune?
#11 |
Jedi Master
Drives: Boeing 757/767+2010 IBM 2SS Join Date: Aug 2008
This sounds plausible
#12 |
In his sig it says he had the L99 to LS3 conversion kit installed. I would assume this eliminates the AFM and equipment associated with it.
#13 | |
At some point the fuel dropped and the pistons were running too lean, that's all I know as of now.
#14 |
![]() Drives: 69rs/ss 2014 ss/rs 1le Join Date: Oct 2013
Sorry about your misfortune during this time of the year. I don't know much about EFI but anything can be rebuilt. Just make sure that every piece is scrutinize, you only want to do this once. If its not your primary vehicle i would come up with a plan that would make it better than it was.
69 rs/ss white 2014 ss/rs 1le hot red |
