![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RS Inferno Orange Metallic Join Date: Mar 2010
Sunroof Guys and girls
Guys Check your drains in the trunk. One of mine was not put back together, after the Accident and I ended up with about 3 inches of water around the battery. This caused radio problems and I might even have a bad Amp now.
2024 Camaro/Panther Emblem,Hot Wheels Emblems, Hot Wheels Door Sills and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills,
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 camaro Join Date: Feb 2012
not sure I understand. the battery is sealed, otherwise the acid would leak out. the battery is about 8-10 inches tall. sitting in three inches of water shouldn't make any difference. or am I missing something?
Cables and wiring in in the bottom of the trunk. Plus water in trunk equals rust.
Living Life in MPH.
![]() I'd be sooo mad
Drives: 2014 Z51 Corvette Join Date: Apr 2011
Was this from the factory or did you have work done to your car?
#6 |
![]() Drives: 2016 Camaro 2SS M6 Black Join Date: Nov 2013
Same exact thing happened to a buddy of mine's Mini. Sorry for your luck.
#7 |
#8 |
Did a body shop do the work after your accident?
#9 |
![]() Drives: 2011 2LT/RS red jewl tintcoat Join Date: May 2012
yup if that drain line is unplugged everything gets wet. had it happen to me but it didn't do what yours did. just got the carpet wet ...i put a little silicon on the hose and put it back together no more leaks
#10 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
I think he said it wasn't put back together right after an accident, so probably not a factory defect.
The Bird is the word! |
#11 |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Black - Std Exhaust Join Date: Mar 2013
I am sure I am going to sound very stupid, but what does this have to do with a sunroof?
#13 |
The water drains from the sunroof go through the trunk and if they come loose it could flood the trunk.
#14 |
Yep, Thanks, my drain was undone for over three months. And well the water just accumalated in the bottom of the trunk till it shorted something out. We've have a good bit of rain in the last three months.
