Old 01-22-2014, 12:16 PM   #1
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Most Cost Effective Way to Hit High 11's and/or Preferably Higher Trap Speeds
Ok, I'm not going to beat around the bush with this question, and I don't think that it has been asked...
The new M5 runs gets through the quarter in 11.9 seconds at 120.3 and these are my target minimum numbers...particularly that trap speed.
I'm seriously considering the AGP turbo but I'd really like to target this question at the cam gurus here.
Is there any way to match those above numbers with a cam and headers with tune, at significantly lower cost than going with the turbo setup?
I do understand that the AGP setup will blow away those numbers previously posted, but now I'm becoming more concerned with my project going over budget, and hence entertaining other options.
Hoping the cam gurus chime in, I'm very new in the "muscle car" game.
Camaro Dude is offline   Reply With Quote
Old 01-22-2014, 01:00 PM   #2
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Cam and bolt ons. Light suspension work, nice wheel/tire combo. Deep 11s easy with good driving.
Rhino79 is offline   Reply With Quote
Old 01-22-2014, 01:04 PM   #3
KyWildcats
Z Bowman
KyWildcats's Avatar
Drives: 2010 2SS (SOLD), 2016 2SS, 2007 Z71
tvs2300 or what rhino said!!!!
2016 2SS M6 Bo White Ported MSD, Bo White Ported TB, Flex Fuel Kit, Drag Pack, Rotofab, Ryan Stevens GPI tune, 15” conversion
Fastest Bolt On N/A M6 Record Holder 11.268 @ 120.268
2010 2SS/RS A6 (sold)Mods: Borla Atak Catback, Stainless Power 1 7/8 Headers, TSP VVT-3 Cam, 3200 Yank Stall, CAI Inake, Ported TB, 18" MT ET STREETS
KyWildcats is offline   Reply With Quote
Old 01-22-2014, 01:06 PM   #4
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
This. With the 1LE gearing you probably don't even need the cam but anything worth doing is worth over doing.
Old 01-22-2014, 01:19 PM   #5
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Intake cam headers tune. Perhaps some wheel hop prevention in the rear suspension.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 01-22-2014, 01:58 PM   #6
Camaro Dude
Drives: ‘13 1LE
When you say wheel tire combo, are you referring to drag tires?
I'd like to be able to do high 11's, but on my existing 1LE tire setup ?
Old 01-22-2014, 02:02 PM   #7
Camaro Dude
Drives: ‘13 1LE
When you guys write intake/cam/headers/tune, can you be just a tad bit more specific, perhaps even with a price? (Approx)
AGP I'm looking at $6500-$7000 and I can install it myself.
What are we looking at for the cheapest and well thought out NA setup to allow Sledge to keep up with an M5, without making a huge fuss about it if you catch my drift?
If the price ends up being not too far off the AGP turbo setup, I'll go with AGP then.
Just curious if NA can be done at significant savings, again, referring to my above target numbers.
Old 01-22-2014, 03:06 PM   #8
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Motion427 is in Eastern Canada and quite knowledgeable, maybe get to know him too.
Local friend did blower, headers, tune, a little suspension, and I don't recall tires and went 11.9@121 with Maggie.
I'd think headers/cam/tune and the other little stuff you'll have 11 second potential.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 01-22-2014, 04:08 PM   #9
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
These are the prices I've uncovered during my research & purchase.
Things I've installed already (self installed):
Headers + exhaust = $1500-$2000
CAI = $350-$400
Ported throttlebody = $150
Tune = $500-$600 (dyno tune scheduled for 2 weeks from now at a shop)
Sway bars + endlinks (not sure if necessary for drag) = $400-$500
Parts that I've researched and plan to add:
Solid subframe bushings = $500
trailing arms / toe rods = $350
3.91 gears & posi mod = $500 (install additional $500 - quote from same shop that will do tune)
Cam = $3000 (includes valve springs, oil pump, timing chain, installation, etc)
Coilovers = $1500 - 2k
I'm sitting at ~$4k invested so far (includes other things like catch can, shortthrow shifter, etc), with another ~$7k planned, but this also includes suspension stuff that you'd want to do either way. This does not include anything towards wheels/tires either, which I would expect to drop ~$2500 more (wheels + tires).
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 01-22-2014, 06:50 PM   #10
Rhino79
Rhino79's Avatar
It may be doeable, but realistically, huge wheels suck for drag racing. Not only are they heavy, they don't have enough sidewall to let the tire bite hard on a launch. A 70 lb wheel/tire assy on each side of the rear is very violent when it shakes and or wheel hops. Also, I'd doubt it would be very consistant with a 20" dr
So when I have a customer wanting me to spec a combo to drag with, whether it be bolt ons, or all out, I say buy wheels and tires.
The car works better, less harmful on the driveline, and will be much more consistant at the track. Plus the weight reduction from rotating mass will help et and trap speed as well.
Old 01-22-2014, 09:52 PM   #11
Irnwkrkev
Irnwkrkev's Avatar
Drives: 2011 SS/RS LS3
Adding more power without being able to put it to the ground is useless.
You can dump all the money you want on turbos and still run 12's if you can't hook.
....never mind break a lot of shit without driveline and suspension mods.
Irnwkrkev is offline   Reply With Quote
Old 01-22-2014, 11:08 PM   #12
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
This.
Go look at the fast times list and see that virtually EVERY car that's in the 11's are running drag tires. That's not just coincidence. The stock tires just aren't sticky enough to pull the 60ft's you need to get the numbers you want. Best thing you could do is to get another set of rear wheels to put some DR's on. That way you can swap them out when you go to the track.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-22-2014, 11:52 PM   #13
B-_-RAD
Banned
Drives: ...
Headers/cai/tune, and a small shot of nitrous (wet 75-100) and of course some tires. That should exceed your expectations.
B-_-RAD is offline   Reply With Quote
Old 01-23-2014, 08:16 AM   #14
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
This is going to prove as a problem. I would recommend to at the very least run a 305/35R20 or 315/35R20 drag radial on those 1LE wheels.
