Old 01-22-2014, 12:38 PM   #1
CrisisMusick
Drives: 2014 AGM 1LE/2SS/RS
Best Intake for 2014 SS?
I have a 2014 1LE, and I've heard that the different hood might cause an issue with some of the Intakes available for 2010-2013 models. Which intake do you guys recommend? Would it void any type of smog regulations in California?
CrisisMusick is offline   Reply With Quote
Old 01-22-2014, 01:35 PM   #2
Dupree878
Dupree878's Avatar
Drives: '13 Dusk Edition 2SS/RS M6
I'm going out on a limb here and assuming that the issues you've heard of with some manufacturers and the new hood are due to some cold air intakes using the hood as the top of their box.
If you search here you will find the leading cold air intake seems to be the one made by cold air inductions (CAI), which actually has a closed top box, so I don't believe the new hood will be a problem.
As for smog regulations in California, that I cannot help you with.
Dupree878 is offline   Reply With Quote
Old 01-22-2014, 01:38 PM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Like Dupree mentioned, the CAI Inc systems are good to go. California regs are too ridiculous and fluid to try and keep track of. I'll leave that to someone local.
Old 01-22-2014, 02:31 PM   #4
nightshift
nightshift's Avatar
Drives: Victory Red 2011 2SS/RS
Regarding California smog regs, so long as it's CARB approved, you will pass smog (California Air Resource Board). It should come with a CARB sticker which should have a number on it. Prior to purchasing your intake, make sure it's CARB approved if that's an issue. I have an Airaid which is not. However, I kept my stock intake and can swap it out. My car will pass the test, just not the visual. It's silly as it's a similar design to many CARB approved intakes on the market. That being said, if you bought your car new, you should be good for five years before you have to smog it in California. The smog here is crazy. No long tube headers either. Won't pass in Cali.
nightshift is offline   Reply With Quote
Old 01-22-2014, 03:04 PM   #5
Sales @ CAI Inc
Sales @ CAI Inc's Avatar
Drives: 2010 SS/RS Supercharged 427 Build
Our CAI has 0 fitment issues on the 1LE, and it is not CARB/SMOG certified. Feel free to PM me or give me a call if you have any other specific questions.
Sales @ CAI Inc is offline   Reply With Quote
Old 01-22-2014, 03:33 PM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
ADM race intake
62nalide is offline   Reply With Quote
Old 01-22-2014, 03:59 PM   #7
Egon
Egon's Avatar
Drives: 2014 2SS/RS 1LE
As a fellow Kalifornian I do not believe there is any cold air intake available that is CARB approved. However they are so easy to swap out with the original intake at smog time I would not let it dissuade you from getting one and installing it. When I get one for my 2014 it will be the CAI model mentioned above.
Egon is offline   Reply With Quote
Old 01-22-2014, 04:22 PM   #8
SSTG
Drives: 2014 Z51 Corvette
Is the Roto-Fab an issue?
I just don't like how CAI has what looks to me like Aluminum foil on the inside.
SSTG is offline   Reply With Quote
Old 01-22-2014, 07:16 PM   #9
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
After having done some research, there is no CA-legal CAI at the moment.
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 01-22-2014, 07:31 PM   #10
Joe@CPR.com
Drives: 03 vette, 94 trans am, 04 gto
Roto-fab is what we prefer!
Joe@CPR.com is offline   Reply With Quote
Old 01-23-2014, 02:59 PM   #11
Dupree878
Dupree878's Avatar
I've seen this referenced twice now, and I still can't figure out what y'all are talking about. Mine, as well as the one I put them my friends car both have ceramic coating and their smooth on the inside of the tube.
If you're referring to the inside of the box, that is actual heat shielding, which is why the CAI kit keeps intake temperatures cooler than many competitors, and what keeps it able to have a metal box instead of a plastic box which, in my opinion, looks better.
Old 01-23-2014, 04:25 PM   #12
SSTG
Thanks, I know what it is. And I just don't care for it. If the CAI blew the Roto-Fab out of the water I would get it and tint the glass so you couldn't see into it. But the gains are about the same and I think Roto-Fab looks better and it has a metal box also.
My question was to Chase if there is an issue with the Roto-Fab and the 2014 Hoods?
Old 01-25-2014, 08:28 PM   #13
Lethal Racing
Lethal Racing's Avatar
Drives: LSx Performance Specialist
We have installed both on the CAI and Rotofab on the 14's and they both work and fit fine.
Lethal Racing is offline   Reply With Quote
Old 01-25-2014, 08:33 PM   #14
SSTG
Has anyone tried the Airaid on the 2014? I like the way they look, reminds me of the intake on the Z.
