![]() ![]() ![]() ![]() Drives: 13 ZL1 vert blac fastlane/LPE 750 Join Date: Jul 2011
You asked me to post it when i was ready to sell it again....750hp LPE ZL1 vert
Well after thinking long and hard I have deiced to let it go,as hard as it is...I am moving out to the country ,and a ZL1 and dirt roads do not go hand in had...Plus its still hard for me to get out of,and I now have a Truck with the correct handicapped equipment in it to drive that has a lift for my wheelchair.....I have posted it in the for sale section,and there are extra pictures in my profile..I will send a video to anyone interested in the car as it wont post from my Iphone on the forum,something to do with the format ..
This is a list of what i have had done to it..The car has about 4500miles on it,and only about 500 since all of this work was done..The car is perfect as a used car can get the underside is as clean as the top side...It is stored inside,and has only been in light rain once while being bought home from the dealer.. 210150309 Lingenfelter LS GT9 Hydraulic roller camshaft 215/247 629/656 121 CL $365.00 - L200175307 Lingenfelter 3 Bolt cam conversion kit $69.95 -PRO SERIES HEAVY DUTY TIMING CHAIN BY IWIS $83.95 - heavy duty pushrods - comp cams LS rocker arm trunion kit - Brian tooley High lift spring kit - Gasket kit, fluids for supercharger,waterpump,cam kit gaskets ,etc..$ 100.00 -High Flow Camaro ZL1 Cold Air Intake LSA 2012-2013 ROTO FAB $399.99 - L220070709 Cadillac CTS-V Camaro ZL1 ATI 10% Overdrive Balancer Pulley 2009-2012 $649.95 - L220300709 Lingenfelter CTS-V Camaro ZL1 LSA 2.55 8 Rib 10 Bolt Pulley $99.00 - L960130709 Lingenfelter Supercharger solid Isolator Coupling LS9 LSA Engine 2009-2012 $54.95 - K080670 8 Rib Poly V Belt For 10% Overdrive Pulley & 2.55 Upper Pulley 67.0 inches $50.00 - 90 lb Fuel Injectors $699.00 - L310065307 Lingenfelter 160 Degree Thermostat $22.95 - UPF48R AC Delco oil filter $60.00 -Part Number: L230075897 LINGENFELTER LSX DOUBLE VALVE SPRING TITANIUM RETAINER & SEALS KIT $489.95 -LINGENFELTER 76 MM DIAMETER IDLER PULLEY KIT $111.06 -LINGENFELTER LSA IDLER RELOCATION BRACKET CTS-V, ZL1 CAMARO 2009-2013 $99.95 -Hurst Comp Shifter for Automatic Transmission Camaros #5380432 $ 460.00 -Vmax CNC Ported 90mm TB $150.00 -D3ep heat exchanger $799.99 -D3ep High capacity water reservoir $379.99 - Stainless Works Long tube Headers & Connection Pipe 1 7/8 $1200.00 -carbon dipped super charger cover $300.00 -carbon dipped fused box $99.99 -APEX oil return catch can $189.99 -Every exterior plastic piece has been Carbon dipped -front splitter All front light rings, fog light housings, front grill top and bottom ,front and rear bow tie emblems, tail light bezels, rear spoiler, rear diffuser, side rocker panel covers, about $3500 -Labor to R&R and tune all engine parts,hex ,body parts $ 4500.00 -complete clear bar front, rocker panels,mirrors ,hood,bumpers,grill,fog light,etc $ 1000.00 installed at XPEL Houston location. 10yr warranty installed 2013 ALL the fluids have been serviced completely. Cost $400.00 CAR had the aligment check and adjusted $89.99 There is easy 16,000.00 worth of mods and I am sure there are some things I have forgotten,along with some labor costs here and there ASKING 54k OBO SO MAKE A OFFER ,ALL I CAN SAY IS NO..THIS CAR IS MINT AND WELL TAKEN CARE OF NEVER BEEN TO THE TRACK,OR HAVE I EVER USED IT FOR STREET RACING..
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
![]() Drives: VR ZL 1 Join Date: Feb 2013
Nice Car !!
![]() Drives: 2010 Camaro SS Join Date: Apr 2011
beautiful car buddy! good luck with the sale.
![]() ![]() ![]() Drives: 2016 Nightfall Gray Metallic SS Join Date: Dec 2013
Nice!!!
GLWS
2016 Nightfall Gray Camaro SS |
![]() Drives: 2013 black on black Join Date: May 2013
Hey can you pm on who did the clear bra. Somebody's gonna get one hell of a deal.
#6 |
![]() Drives: 2013 ZL1 Triple Black Vert M6 #5591 Join Date: May 2013
Good luck. Beautiful car, IMO NEEDS BLACK GORILLA LUG NUTS..just saying. Might help the sale. Lol. Only kidding
695 RWHP / 660 RWTQ @ 13.5 PSI
Dyna-Tech Headers Ceramic Coated w/Super Flo Cats, JRE Custom Rough Idle Racing Cam Package and 125 RWHP Pulley Kit w/ 28% pulley, Custom Tune by Ted, ID850 injectors, JMS Fuel Booster, NGK Plugs, MSD Plug Wires, Roto-Fab CAI, Roto-Fab Big Gulp, Elite Catch Can, Mild to Wild, 90mm VMaxx Ported Throttle Body, Skip Shift Elim., D3 Coolant Resevoir, Separated Clutch Resevoir, and Fuzzy Red Dice.. |
#7 | |
I have a 2014 quad cab ram being done as well..for 950 they are doing the frt all the sides,doors hood,and on the drivers side the whole rear door up to the window and the whole side of the bed,to protect it from my wheelchair when i get in and out of it ...as i have a lift built into the truck to lift me into the cab,and my chair into the bed...
#8 |
good idea never thought of that,thks..
#9 |
![]() Drives: 2014 Z/28 # 89, 69 Camaro, 2013 ZL1 Join Date: Jul 2013
Good Luck with the sale Mark....dirt roads would kill a beauty like that !
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
That's a smoking deal. You should part out the mods to help your fellow ZL1 brethren.
#11 |
Just curious , you said never on the track ,,,,
Then ,,,,,run 10 sec ?? Smoking deal either way ! |
#12 |
Shouldn't this be in the for sale section of the forum??? Just because it's a ZL1 doesn't mean that it should be in the ZL1 forum. It's a car that's for sale. I think it would be FAIR for it to be moved there.
#13 | |
![]() ![]() Drives: 2013 zl1 Join Date: Nov 2012
quit trolling... you don't want it, then leave him alone... jesus I cant stand busy bodies like you.. this is a ZL1 and for sale or not it belongs here AND the for sale side if he wants,,
![]() 2011 cts-v coupe (pinky) wifes car.. ls9 cam c.a.i. 11.44 2007 corvette vert ..retired.. 2013 zl1 stock blower stock ci 20" wheels 10.36 135...so far.. |
#14 |
Power weight etc...it doesn't take much to figure it out with good tires,good driver(not me anymore,lol) plus i have owned,and built for customers many 10,sec cars in my life before i was crippled.. thks....10.99 0r 10.2 is still a 10 sec pass...Although most know that a vert can not run without a roll bar installed anyway to understand what i meant...thank you for the question....
