Old 03-28-2014, 01:50 PM   #1
CamaroI
Drives: 2010 IOM Camaro
Where to drill hole 2010 QTP cutouts
anyone have photos on where to drill hole for the QTP cutout wiring to go into cabin?? Did you use silicone to seal hole? Switch is going to be in my center console.
CamaroI is offline   Reply With Quote
Old 03-28-2014, 02:07 PM   #2
hush
Drives: 2013 Camaro SSRS L99
Send a message via Skype™ to hush
Hello, is this what you are looking for?
http://www.camaro5.com/forums/showthread.php?t=38977
hush is offline   Reply With Quote
Old 03-28-2014, 03:10 PM   #3
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
When I had them, I went through the shift boot.
I wound up swapping them out for NoWEEDS because QTPs constantly failed and leaked.
Sent from my SCH-I545 using Tapatalk
jeepguy_1980 is offline   Reply With Quote
Old 03-28-2014, 03:41 PM   #4
LS3 SS
LS3 SS's Avatar
Drives: 2010 Cyber Grey Camaro SS (LS3)
No need to drill holes. Loosen your shift boot assembly, run the wires through the boot, and tap into the cigarette lighter for power and ground. Clean install.
GPI SS3 Cam / PRC 255 heads / Forged 376ci bottom / Fore level 2 fuel system / D1SC ProCharger on 12lbs / Alky control dual nozzle / 770 whp / 649 wtq tuned by Ryan Stevens at GPI
LS3 SS is offline   Reply With Quote
Old 03-28-2014, 05:02 PM   #5
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
Any tips for install? I am getting mine next week thursday according to tracking number.
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 03-28-2014, 05:27 PM   #6
CamaroI
I wanted no weeds but they said they would not work with my magna flows because not enough room??
Old 03-28-2014, 05:29 PM   #7
CamaroI
They also said would have to switch my magna flow x pipe out for an American racing one. Wasn't sure if any contraidication for doing tar
Old 03-28-2014, 09:34 PM   #8
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Under the drivers and passenger floor is a rubber grommet you can run the wires through also.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
