Old 08-01-2009, 11:02 AM   #1
MPGomatic
Drives: it changes every week
Does Wheel Size Affect 0-60 Times? (V6/Auto)
I'm in the midst of cutting our V6/Auto Camaro video review. Loved the car, but I've been banging my head with this question for a while ...
Our test 2LT unit was equipped with the #2 21-inch wheel package. Couldn't hit the stated 0-60 times (6.1 sec) ...best stab at it was .5 off. Should I just hang up my keys (and take up stamp collecting), or does wheel size affect 0-60?
This looks to be the same car that AutoBlog tested ... packed with $11K in options.
MPGomatic is offline   Reply With Quote
Old 08-01-2009, 11:08 AM   #2
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
smaller diameter tires, that will lower your gear ratio, will give you a tad more acceleration,
same diameter, but lighter tires/wheels will remove some rotating mass and improve your times.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 08-01-2009, 11:15 AM   #3
96rss/ls6
Inferno is the only color
96rss/ls6's Avatar
Drives: 96 ls6 camaro, iom 2ss/rss /
Yes the wheel size does make a huge difference. You are dealing with much more rotational mass with the 21s. If you weigh them I bet they are 25 pound more than the stockers a piece. so you are adding like 100 pounds of rotational mass. I dynoed my LS6 with 20s then with factory aluminum 16s and got a astounding 60hp and 77 LB/FT of torque. Its like changing to light weight fltwheels, or drive shafts ect.. You gotta pay the price to look good. My 96 started life as a v6 and after 20s and a world class stereo were added it wouldnt get out of its own way, so I then put a ls1 in it, then converted to a ls6, then nitrous, then..... well you get the idea
96rss/ls6 is offline   Reply With Quote
Old 08-01-2009, 11:38 AM   #4
MPGomatic
Thanks! That's along the lines of what I've been thinking ...
If we had Mythbuster's budget (as opposed to a non-existent budget), we'd set up mileage and performance tests, using various wheel sizes, from 18s to 21s.
I've got a couple of ideas and something to shoot for, if nothing else.
Old 08-01-2009, 11:40 AM   #5
96rss/ls6
96rss/ls6's Avatar
Yep, good luck with it.
Old 08-01-2009, 12:51 PM   #6
Black5thgen
Drives: 2007 C6
The overall dia. is suposed to be the same for all wheel/tire combos offered from 18-21". The side wall is what varies. You may notice a small difference between sizes due to weight, but is you run an 18" wheel with a 50 sidewall tire you will definantly notice a difference.
Black5thgen is offline   Reply With Quote
Old 08-01-2009, 01:05 PM   #7
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
yup everybody else nailed it lol
Gentry78 is offline   Reply With Quote
Old 08-01-2009, 01:45 PM   #8
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I seriously doubt that the entire .5 seconds is due to the wheels. You're assuming that he'd get the advertized time on the run.
Old 08-01-2009, 06:43 PM   #9
97one
97one's Avatar
Drives: 2016 & 1967 Camaro, 2015 Impala, +1
Tire dia.
YES wheel & tire Dia. does effect 0-60 MPH ET.
What size rims did it come with from the factory? The 2LT has 19" with the RS pkg. they are 20" ...What is the overall Dia.of your 21"tires ? What was the overall Dia. of Tires it came from the factory with ? IF there is much of a difference THAT could the reason.
A smaller overall Dia.Pkg. would give you a quicker ET
You would think a larger size rim with tire would have a larger overall Dia. than a smaller rim with tire. That is not always true. IT ALL DEPENDS on the TIRE size.
97one is offline   Reply With Quote
Old 08-02-2009, 09:49 AM   #10
MPGomatic
97one - This car has the #2 dealer-installed OEM 21-inch option package. 21" x 8.5' rims, 245/40ZR21s.
I didn't order it that way, I'm only the test driver. Not sure about the tire diameter ...
Old 08-02-2009, 12:06 PM   #11
97one
97one's Avatar
I would think your 245/40ZR21s have a larger dia. than the 275/40ZR20s that come w/the RS pkg. (same 40 profile) BUT without knowing the overall Dia. you can't be sure.
MOTOR TREND gives the 0-60 mph ET as: 5.9 sec. for the manual and 6.0 sec. for the AUTO. That is the V6 with the RS 20" tires.............
Old 08-02-2009, 12:23 PM   #12
97one
97one's Avatar
[QUOTE=MPGomatic;746611]I'm in the midst of cutting our V6/Auto Camaro video review. Loved the car, but I've been banging my head with this question for a while ...
I forgot to add : I would think the possible small Dia. difference between the 20" & 21" would only be app. .1 or .2 sec. in the 0-60ET times.
I guess you used the SPORT mode or Paddle shifters to make the test ?
Sorry but I had to ask...........
Old 08-02-2009, 01:18 PM   #13
MPGomatic
Yep, Sport mode with traction control on (the culprit?). Here's a 0-60 clip:
Old 08-02-2009, 01:25 PM   #14
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
7 sec?..sounded like a poor start..
2SS Silver Ice Metallic at ATL Car SHow Cmurf_SS Camaro Photos | Spyshots | Video | Media Gallery 40 11-09-2009 10:38 PM
Minimum size wheel on SS Brembo Brake JEFF2010SSMANUAL Wheels and Tires Talk Sponsored by The Tire Rack 57 10-21-2009 02:04 PM
Wheel size vs. smoothness of ride mikenmar Wheels and Tires Talk Sponsored by The Tire Rack 6 05-24-2009 06:25 PM
Offset and lug pattern of CAMARO 5 x4.75? D1BADZ Wheels and Tires Talk Sponsored by The Tire Rack 27 12-02-2008 01:24 PM
General Camaro Questions - wheel size / Release Date ProCamaross Wheels and Tires Talk Sponsored by The Tire Rack 11 05-14-2008 10:36 AM
