Old 04-13-2014, 04:28 AM   #1
v6
v6's Avatar
Drives: 2012 45th 2LT RS
Door projector lights from AAC issue
So i noticed that the projection on the ground is changing in it's look and i'm guessing it has to do something with the bulb burning out. I have the wires connected where they are supposed to be, but the light is still on when i am driving my car, causing the bulb to burn much faster... How can i change this?
I can see the light shining down by my seat when i shut the doors and start driving.
v6 is offline   Reply With Quote
Old 04-13-2014, 07:42 AM   #2
CamaroI
Drives: 2010 IOM Camaro
Put it on a toggle switch.
CamaroI is offline   Reply With Quote
Old 04-15-2014, 03:02 AM   #3
v6
v6's Avatar
i guess it's a little late now, the projection is hardly readable. Damn AAC
Old 04-15-2014, 04:42 PM   #4
mbrusco103
mbrusco103's Avatar
Drives: 2011 2SS/RS (M6) 427 Twin Turbo
You should hook it up too the dome light next time so its only on when the dome lights are on
2011 Camaro 2SS/RS ERL 427 M6 TT
-AGP Twin Turbo 55/57 .83ar | ERL 427ci | Squash Fuel System | Stainless Works Chambered 3" | Mcleod RXT | Factory Hurst Short Throw | Black Forgestar F14s | CTS V 6 Piston Brembo | VIS AMS Carbon Fiber Hood | Anvil Carbon Fiber Spoiler
mbrusco103 is offline   Reply With Quote
Old 04-15-2014, 07:14 PM   #5
USMCSSGT-RET
USMCSSGT-RET's Avatar
Drives: '14 SIM 2LT/RS Vert
That's how I have mine wired.
USMCSSGT-RET is offline   Reply With Quote
Old 04-19-2014, 12:16 PM   #6
JakeSpeed21
Drives: 2012 45th SS/RS
I have mine connected to the door pin switch. It's a Red/White strip pos, Gray/Blk Neg.. I tested it with the door panel off and open and close of the door and it does turn off with the door closed.
JakeSpeed21 is offline   Reply With Quote
