![]() Drives: 2010 2ss RS Join Date: Jun 2009
Valve train woes LS3
Today. 8K miles on new motor. Aftermarket heads with .675 springs .620 ish lift cam. Stock rockers with comp trunion upgrade. Started hearing ticking and found metal flakes in on the heads under the valve covers.
Here is what greeted me when I took the trunion kit out of the first rockers! Before all this… 24K miles with stock heads same .675 dual springs with a .640 ish lift cam. Factory rocker trunions . 13 of the 16 lobes wiped out on the cam and one flat spotted lifter. With the exception of ONE intake rocker (which was replaced and prompted the trunion upgrade to all on this new motor) all the factory rocker trunions were perfect after all those miles! Symptoms of a greater issue I expect…….. Last edited by Cruz-lo; 05-05-2014 at 08:04 PM. Reason: Error in typing |
![]() Drives: 2010 Black M6 RS/2SS Join Date: Oct 2009
What oil are you using?
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs |
VR1 10W30 now.
Was M1 5W30 with first set up. |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
What's the part number on those PAC springs? I see .650, .700, and .750 springs. I don't see .675.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
Sorry About that.. They are the .675 springs. Going to take the rest of the rockers apart over the weekend I hope. I will post up what I find.
#6 |
Eh, that'll happen
Drives: 2010 2SS Join Date: Apr 2012
Those must be the 1208s. Way too much spring for that cam. Theres a lot of talk going on about those exact springs the last couple months. I am running the same springs as you. I am planning on changing cams real soon and will also be changing the springs out.
2010 Camaro SS LS3 - No Modz
#7 |
![]() Drives: 2007 Corvette C6 983 RWHP Join Date: Dec 2011
There is no reason to run more spring than needed for the cam specs. As said this topic has been discussed quite a bit lately but for some reason some are still recommending those PAC 1208x springs. I would say this is proof that they are too much.
2007 C6 vert, auto, F55, LT3
LME LS402 , WCCH 245 Heads, Pat G. Custom cam YSI / 3.0 pulley, ARH 1 7/8 headers, NPP Dewitts / dual spals, A&A dual pump fuel system. 3.42 polished gears, hardened shafts, Alky control meth, Cartech line lock, ECS axle loops, Trans brace, 6L80 built by me. ID 1000 injectors, comp rockers, Morel lifters, BT springs, Trend 3/8 pushrods, ATI 10% OD Damper Circle D Triple Disc stall 1009 RWHP @ 7000, 817 RWTQ @ 6000, |
#8 | |
Search Ninja
Brian Tooley
#9 |
For a cam up to 650ish you wont need more than 400 open. This is exactly why trunion upgrades and short travel lifters cant help you when you have WAY too much spring. Id look into the Brian Tooley or the Nextek springs for the setup you have.
#10 |
aka Patrick
Oh wow that's some crazy wear on parts!
I just finished a whole discussion and debate about .750 lift springs due to this exact concern. I swapped over to some BTR .660 springs due to the concern of too much spring pressure causing damage to the valve train. Hope you get things all fixed up and someone jumps in to get you headed in the correct direction! Keep us Updated!
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft |
#11 |
![]() Drives: 2010 Camaro SS Join Date: Feb 2010
I have the Jannetty rough idle blower cam kit, with .600 plus lift. I used the supplied springs which I am sure were also Comp products. I had to tear the engine down due to an unrelated failure, and found identical wear on some of my trunions. Three of my exhaust valve stems had severe wear on them also.
I was using 10W30 Mobil 1 prior to the tear down. I didn't find any other oil related failures to include lifters or cam. I had about 4000 miles on the setup. I am now using Gibbs LS30, with about 2000 miles on the new engine (LSX 429). I haven't taken anything apart for inspection yet. Wonder what they look like? |
#12 |
old school chevy rodder
I would recommend using a spring more in the .650 to .675 as that was what I was recommended with my .639/.623 lift cam from TSP, and also using Driven racing br30 break in oil and ls30 after break in.....You know that the lift we have with our cams is already very large compared to regular flat tappet engines of old...and the spring pressure is already excessive at .675 and I will have to tear into my engine to check mine at 25k on the cam and am hoping they still have enough pressure and are good form using the best oil I can find.......one for our engines ! Read the tech bulletins on drivens website is what I recommend, and if you get curious about other oils read a lot first online......... Heres some links and zddp is crucial in our engines also especially if cammed.....
http://www.drivenracingoil.com/news/...-break-in-too/ http://www.amsoil.com/lit/g3115.pdf
#13 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Sub'd
Want to watch this one
#14 | |
155 to 165 pounds @ 1.8 (my installed height is about 1.85) 370 to 390 pounds @ 1.125 (spring is about 1.2 at full lift) Could be my tester is not correct though.... |
