Old 05-06-2014, 05:15 PM   #1
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
2014 Corvette wheels
I have a set of 2014 corvette factory chrome wheels and tires for sale. Not sure if they will fit the Camaro. They are the 5 spoke 18"/19" wheel set. The tires have 7 miles on them. They were replaced by the dealer with the 19"/20" set.
I will try and get pictures up tomorrow. Asking $2,200.00
Fishdadddy is offline   Reply With Quote
Old 05-06-2014, 05:54 PM   #2
Dexman1349
2010 2SS/RS M6
Dexman1349's Avatar
Drives: 2010 2SS/RS M6
Check your lug diameter. The newer (2013+) Vettes have a smaller lug (12mm vs a 14mm on the Camaro). Smaller lug holes = no fit.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete
Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace
Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter
Bumblebee Racecar Build
Dexman1349 is offline   Reply With Quote
Old 05-06-2014, 07:32 PM   #3
Fishdadddy
Fishdadddy's Avatar
Thanks. I will check that.
Old 05-08-2014, 02:03 PM   #4
Fishdadddy
Fishdadddy's Avatar
The lug holes on the Vette wheels are 14mm also
