Old 05-14-2014, 11:30 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Catch can for Z28
Easy way to mount a Elite CC. I just wish there was more room to mount in the cold air intake like my ZL1.
Skylane765 is offline   Reply With Quote
Old 05-14-2014, 11:32 PM   #2
Skylane765
Skylane765's Avatar
Pic
Old 05-15-2014, 01:41 AM   #3
intensifi
Drives: '12 2LT Convertible
If you have a moment, can you measure the diameter of your throttle body opening?
Just trying to figure out what the Z/28 intake will fit on.
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 05-15-2014, 12:43 PM   #4
Skylane765
Skylane765's Avatar
90mm is what's on LS7
Old 05-16-2014, 07:02 PM   #5
Skylane765
Skylane765's Avatar
All installed, very easy to do
Old 05-18-2014, 11:31 AM   #6
Skylane765
Skylane765's Avatar
The CC is a Elite 2. Ask for hockey stick mount.
Old 05-29-2014, 12:18 PM   #7
Skylane765
Skylane765's Avatar
After checking how the PVC works on the LS7. I now see we need 2 catch cans.
Under full load the clean side will need a CC to keep air oil from going in front of Throttle body. I will use 1 E1 and 1 E2 Elite CCs
Old 05-29-2014, 12:49 PM   #8
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Nice installation and I like the way the upgraded fittings look on the hoses.
Elite Engineering is offline   Reply With Quote
Old 05-29-2014, 01:09 PM   #9
Skylane765
Skylane765's Avatar
I just called you and I need one more small CC for my clean side.
Old 05-29-2014, 11:39 PM   #10
Elite Engineering
Drives: 2010 Camaro
Thanks for the order. Shipped within 24 hours after receipt of order.
Old 06-05-2014, 12:03 AM   #11
Skylane765
Skylane765's Avatar
Here is my dual catch can install, the second CC is for wide open throttle, to keep oil out of the intake side of TB. I used the standard and E2
Old 06-05-2014, 12:07 AM   #12
Skylane765
Skylane765's Avatar
By the way, do not need the L bracket. I was able to use the hockey stick.
Old 11-01-2014, 03:41 PM   #13
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Skylane - would you mind posting info on this full setup?
Known---
Elite CC Standard
Elite CC E2
Hockey Stick bracket for E2 CC
Unknown===
Hose size and length (looks like 3/8)
Hose fittings type
Bracket for the CC standard
Anything else that might not be seen
***Edit***
Looks like each of the catch cans come as kits from Elite. Was elite able to swap out the straight fittings for the 90° fittings for the return lines? Was there sufficient hose supplied?
Zslash28 is offline   Reply With Quote
Old 11-02-2014, 05:43 AM   #14
TonyNDeb
Drives: Candy
Interested in details as well. TIA John.
TonyNDeb is offline   Reply With Quote
