![]() Drives: Camaro 2Lt Join Date: Nov 2011
Gas Mileage :(
Its been a few months already and I've noticed that the mileage is not too great in my 2Lt, I know its not as economical as the 2Ls, but I seem to be getting as little as 11 mpg now. The car still has less than 1500 miles on it, Ill bring up the issue when I go back to the dealer for an oil change.
I have a CAI on mine that I switched from my other car and have been using premium gas since I got the car...I know you can use regular gasoline, but I swear the 2Ls ran a little smoother and gave me slightly better mileage like that. I recently cleaned and re oiled the air filter on the CAI. (as per instructions and taking care not to over-oil) so taking into account the differences in gears, I was wondering if the CAI had anything to do with it, the one I have was meant to fit 2010-2013 models. there is a slight difference with the gril, but otherwise the engine compartment is exactly the same in 2010-2014 models.
Theres no reason you should be having that terrible of gas mileage. Hell, I get about 17/18 city and 25 highway.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
![]() ![]() Drives: '04 Z06, '14BMW M235i, '15 SS/1LE Join Date: Feb 2014
My LT is right under 20 mpg at almost at 2000 miles (highway) and I'm not easy on the pedal at all. With your mpg something else is going on.
Sent from my LG-LS995 using Tapatalk |
![]() ![]() ![]() ![]() ![]() Drives: 2023 Camaro 1SS Join Date: Apr 2014
We need to know more about your driving habits and also how you came up with 11mpg.
Also, not sure that a CAI would affect your mileage much, but maybe you somehow messed with the MAF? It's been discussed at length regarding fuel octane, but you are absolutely wasting money by putting higher octane fuel in your v6. |
Bad 45th
Drives: 2012 45th Anniversay Edition SS Join Date: Apr 2014
That doesn't sound right. I'm getting 16/24 on my 2SS and I'm not a conservative driver.
- Carl
2012 45th Anniversary SS - LS3 Magnuson TVS 2300 Supercharger / Alky Meth Injection / Lingenfelter GT12 Cam / Kooks LT Headers, 3 inch exhaust & QTP electric cut outs / Monster LT1-S Twin Disc Clutch / MGW flat blade short throw shifter / Haltech CAI / VMax Throttle Body / DSS Stage 3 axles/ BMR Trailing Arms, Toe Rods, Suspension Bushing and 1" lowering springs / Taylor 8MM Plug Wires / Tuned by Henderson Performance Technologies / EBC dimpled and sloted rotors / G2 Painted Calipers / GM Tower Strut Brace / ZL1 Factory Rep Wheels |
#6 |
Living Life in MPH.
Premium gas doesn't do much for a regular engine..
http://www.cartalk.com/content/premium-vs-regular-1#1
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
The engine is exactly the same in the 2LS and the 2LT...
Detailing is an involuntary obsession.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 2SS M6 Join Date: Jun 2013
is it a stick if so take it out of 2nd gear JK. but ya somethings wrong you should be in the 20s
#9 |
![]() Drives: '14 Red 2SS/RS/LS3 Join Date: Dec 2013
2SS with c.a.i. I get 15 mpg city, 22 mpg highway
2014 Red Hot 2SS/RS/M6/NPP/Shifter/Nav/Roof/SilverRallyStripes/Airaid intake/GM StrutTowerBrace/50%-35%tint
#10 |
![]() Drives: 2017 Camaro 2SS, 2011 Camaro 2LT Join Date: Jan 2014
Are you sure you GM didn't put a ZL1 engine in there?
#11 |
![]() Drives: 2014 Red Hot 2SS/RS/1LE NPP Recaros Join Date: Sep 2010
#12 |
Chu no guat a hasa is?
Drives: 14 Jeep G Cherokee Overland HEMI Join Date: Jun 2011
14 city about 19-20 hwy.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
#13 |
![]() Drives: 2010 Camaro 2SS Black Join Date: Jun 2013
Why did you already oil your filter? It's like 10,000 miles between recharges typically
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 camaro Join Date: Feb 2012
unless your letting it idle a lot, somethings wrong
