05-18-2014, 06:12 PM | #1 |
Drives: 2016 2SS Camaro Join Date: Apr 2014
What wheel/tire set-up for dd/drag
Trying to decide what route to go for a fairly cheap drag pack and dd friendly setup. Done some research and it seems the 18" nurburgrings net the most weight savings over the stock 20's. I've considered dismounting my stocks and having them powdercoated gloss black for austhetics obviously but I don't want to waste my money on that if I can turn around and sell my stock rims and tires for say 1,500 or so only have 9k miles on them. What gains in et and seat of the pants feel did y'all notice going heavy stocks to the 18's thanks
05-18-2014, 08:15 PM | #2 | |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
05-19-2014, 08:21 AM | #3 | |
Drives: '69 SS Convertible Join Date: May 2009
The OEM wheels are heavy pigs though. I remind myself of that every time I have to take them off. It's too bad I like the looks of them so much.
Build Journal |
05-19-2014, 08:39 AM | #4 |
I've plastidipped my rims in the past and I ain't going through that again. And yeah I know it sucks they do weigh so much cuz I like the looks of them too
05-19-2014, 09:23 AM | #5 |
Speed Freak
If you want to buy another set of rims the TSW Interlagos are about as light as you can get at a reasonable price. 18" is probably the easiest all around, but I have 17" welds for drag racing, 19" TSW for road racing and drive on the stock rims on the street. The stock rims are kind of heavy.
