Old 08-06-2009, 05:56 PM   #1
ljustin293
ljustin293's Avatar
Drives: 2010 VR CAMARO 2SS/RS
How to remove inner door moldings (videos)
Some videos I found on youtube..VF Electronics goes through and shows you how remove sections of the camaro..all on your own..enjoy..
Old 08-06-2009, 06:25 PM   #2
1320junkie
Drives: The Imperial Army
sweet
Old 08-06-2009, 06:43 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
noice
I piss excellence
and fart awesomeness
Old 08-06-2009, 07:38 PM   #4
Gentry78
HOOK'EM
Gentry78's Avatar
Drives: 97 c1500/92 olds
awesome
Gentry78 is offline   Reply With Quote
Old 08-06-2009, 08:56 PM   #5
rharon
rharon's Avatar
Drives: 2010 Yellow 2SS/RS
That is Great I think that will help for abl upgrades
Magnacharger TVS2300, ARH HEADERS, ROTO-FAB CAI, NOWEEDS.NET DIVERTERS
rharon is offline   Reply With Quote
Old 08-07-2009, 08:00 AM   #6
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Thank you for posting this! Great team player move!
Hylton is offline   Reply With Quote
Old 08-08-2009, 08:40 PM   #7
ljustin293
ljustin293's Avatar
Old 08-09-2009, 01:10 AM   #8
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Thread moved to the DIY section. For those looking for a DIY on a doors, they'd probably look here...not necessarily in the media section. figured it'd be better...lmk.
Old 08-09-2009, 03:14 AM   #9
Rikarus
I can't tpye!
Rikarus's Avatar
Drives: 2010 RS/SS Victory Red
when someone pulls there door panels, mind shooting some close ups of the abl
Rikarus is offline   Reply With Quote
Old 08-09-2009, 06:40 AM   #10
SRFnSNO
SRFnSNO's Avatar
Drives: Blown & Flamed
Great Info Thanks.
SRFnSNO is offline   Reply With Quote
Old 08-20-2009, 09:51 AM   #11
calflan
calflan's Avatar
Drives: 1LT; IBM; 6 Spd Manual
Video leaves a few key points out:
1 - Pulling the door panel, there is a screw behind the door latch as they show, but also a screw under the pop up panel where the door hand hold is. Pop out the door hand hold with a scribe, the panel comes right up, and there is a screw there #3 phillips head.
2 - Behind the door panel, there are more electrical connectors than outlined as well. There is a mirror connector, window, trunk and tweeter connectors. The tweeter connector is accessed by removing a screw behind the tweeter panel at the top of the door near the side mirror.
3 - After removing the 3 screws outlined in the video, on the outer portions of the panel, pull the panel away firmly and the press on fasteners will release the panel. Next lift and pull the top of the panel away from the door. This will rellease the upper fasteners. I put my fingers on the door 'felt area' that sweeps the window and lifted up and away to release.
4 - Next lift the panel away from the door lock rod.
5 - The door latch rod will need to be disconnected by pushing the clip that attaches it to the door panel interior, forward and then freeing the cabel away from the panel, then lifting the ball out of the latch mechanism. Easy to do and visualize once your in there.
Not really too bad, just be 'tender' with the press on fasteners as they are an old design and get pulled out of shape and lose their latch quality over time and too much pulling. Be firm and easy on them.
All the electrical connectors have release type clips on the sides of their connectors. Take a good look at each and release the latch. Do not just try to pull the connector away for the door mounted female connector. the latches need to be released to remove the connector.
1LT; Airaid CAI; Flowmaster American Thunder Axelback; Int Floor Lts; RS Spoiler; Radio Controls; Sequential tail lights; Oil Catch Can; VMAX Throttle Body; MACE plenum spacer; Mace manifold insulator[/I]
calflan is offline   Reply With Quote
Old 08-20-2009, 09:53 AM   #12
ljustin293
ljustin293's Avatar
yea...I thought about that after i posted it
Old 08-20-2009, 11:38 AM   #13
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
These will be pretty useful in about 25-30 years when people start pulling these cars apart to do restorations on them. Will I be able to find them when I need them? Probably not.
Thanks for posting.
rolnslo is offline   Reply With Quote
Old 08-20-2009, 05:38 PM   #14
ljustin293
ljustin293's Avatar
Thanks for posting.
no problem
