Old 05-27-2014, 07:51 PM   #1
12WhiteLS
12WhiteLS's Avatar
Drives: 2012 Camaro 1LS M6
Header Wrap
Anyone else have the idea to header wrap the downpipes(lack of a better word)? Might cut down on underhood heat.
12WhiteLS is offline   Reply With Quote
Old 05-28-2014, 10:44 AM   #2
DFW_Inferno
Drives: SOLD - 2011 Inferno 2SS/RS
Here is a write up:
http://www.camaro5.com/forums/showth...ht=header+wrap
And yes, I plan on it as well!
DFW_Inferno is offline   Reply With Quote
Old 05-28-2014, 06:45 PM   #3
12WhiteLS
12WhiteLS's Avatar
Well this is the LFX Forum. But what I'm talking about is wrapping the exhaust pipe from the heads to the cat. I wonder if that would be worthwhile. I've heard good things and bad things about header wrap(on headers).
Old 05-28-2014, 06:49 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
The only good thing about header wrap is that it keeps the engine bay cooler. It drastically reduces the life expectancy of your down pipes / headers though.
DSX_Camaro is offline   Reply With Quote
Old 05-28-2014, 06:54 PM   #5
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
What sort of efficiencies would be gained? I cruise at about 176'F, so I'm wondering what this would drop that temp to. I've only hit the strip once, but I never got anywhere near overheating and it was a pretty warm day.
6bangerBOOM is offline   Reply With Quote
Old 05-28-2014, 07:05 PM   #6
12WhiteLS
12WhiteLS's Avatar
Well if your thermostat is showing 176F, I imagine your engine bay would be hotter than that. A cooler ambient engine bay temp should affect intake air temperatures as well.
Old 05-28-2014, 08:44 PM   #7
DSX_Camaro
DSX_Camaro's Avatar
If you wanna get the engine bay temperature down, look into a vented hood. There's a lot of them, and you usually get more downforce as a bonus.
