06-01-2014, 05:00 PM | #1 |
618 RWHP
Closing a ZL1 hood ?
Ok- i know this may sound like a stupid question but i have to ask . I went to close the hood on my new ZL1 - like i have closed the hoods on many other cars i have owned. I bring the hood a little over half way down and let it go with a little push and the hood latched but would not close so i gave it another try and the same thing happened. So i finally ( with the hood already lacked ) i gave it a firm push down and it closed . Is that how to close the hood on a ZL1 ?
I ask because i have never had to push down on a hood like that . Its only sheet metal and i don't want to dent it . |
06-01-2014, 05:08 PM | #2 |
Drives: 2013 ZL1 Join Date: Mar 2013
You are right,be careful pushing it down because it will bend. I pull my hood down about halfway and let it drop.It latches everytime.You might try putting just a little grease in the latch and I mean just a little and you should be fine. If that does not work you will need to adjust it.
06-01-2014, 06:00 PM | #3 |
Faster than you...
Drives: 1194whp. 8.62@168. daily driver... Join Date: Nov 2013
A thread on how to close a hood? I've seen it all now...
GTR
06-01-2014, 08:01 PM | #4 |
Native Floridian
Drives: 2014 - ZL1 / 2003 - Corvette Join Date: Oct 2013
It's a hood - Close like you would any other car!
06-01-2014, 08:03 PM | #5 | |
Drives: '21 ZLE A10 Join Date: May 2012
06-01-2014, 08:20 PM | #6 |
06-01-2014, 08:37 PM | #7 |
Drives: 2013 Camaro ZL1 convertible IOM Join Date: Feb 2008
Close it like you stole it.
06-01-2014, 09:30 PM | #8 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
Agreed. With that said, I pull the hood down until it latches, then push it shut with a quick nudge using the bottom of my palm. I used to do this with my 98 TA with a lightweight composite hood and just kept doing it.
OP - You can adjust the two outermost posts located in the radiator cover area to change how the hood closes. They're really for aligning the height of the hood to the front bumper, but will aid in this as well. |
06-01-2014, 09:33 PM | #9 |
Drives: 2013 ZL1 Ashen Gray Join Date: Oct 2013
I drop mine from 12-18in it latches every time.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience. 754 RWHP 747 RWTQ 93 Octane http://www.camaro5.com/forums/showthread.php?t=347243 |
06-01-2014, 09:40 PM | #10 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
This is funny, I never drop my hood at all. I gently lay it down then lay my hand directly over the latch and gradually increase pressure unit I hear the latch snap. I may spring test it to be sure it is firmly latched but I don't do anything violent....lol. Works great for me.... and my hood has been opened a few times.....
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
06-01-2014, 09:41 PM | #11 | |
06-01-2014, 10:54 PM | #12 |
Speed Freak
That is just silly. I have literally pushed it hundreds of times with no adverse effect, do you really believe it suddenly is going to dent and crumple like an aluminum can? The aluminum on this car hood is thicker than what you find in a pop can. What do you think happens to the hood when you drive the car 200 mph? I'll bet it gets pushed on a lot harder than anything I'll ever do with my hand.
06-01-2014, 11:27 PM | #13 |
Drives: '12 ZR1 Join Date: Jul 2010
"What do you think happens to the hood when you drive the car 200 mph? I'll bet it gets pushed on a lot harder than anything I'll ever do with my hand"
^^^^^This^^^^^ |
06-01-2014, 11:39 PM | #14 |
Innocent Bystander
Drives: 2013 ZL1 BRM/2002 35th SS/2009 GMC Join Date: Dec 2009
12" to 15" drop, good to go.
Living on the RaGgEd EdGe! |
