Old 06-05-2014, 11:26 PM   #1
FenwickHockey65
General Motors Aficionado
FenwickHockey65's Avatar
Drives: 2023 GMC Canyon, 2020 Colorado
2015 Chevrolet Corvette C7 Z06 Rated at 650 HP, 650 lb ft Torque
2015 Corvette Z06 Rated at 650 Horsepower
Supercharged LT4 V-8 engine is the most powerful ever from Chevrolet
General Motors
2014-06-06
DETROIT – The all-new 2015 Corvette Z06 is the most powerful production car ever from General Motors and one of a few production cars available in the United States that delivers more than 600 horsepower.
The Z06’s LT4 supercharged 6.2L V-8 engine is SAE-certified at 650 horsepower (485 kW) at 6,400 rpm and 650 lb-ft of torque (881 Nm) at 3,600 rpm.
“The LT4 Small Block sets a new benchmark for power and torque at GM,” said Steve Kiefer, vice president, GM Powertrain Engineering. “The engine also puts the new Corvette Z06 on par with the most powerful supercars offered in America, while delivering performance with impeccable manners that make it suitable for daily driving.”
Compared with other supercar engines, the LT4 is a veritable fountain of low-end torque, producing 457 lb-ft (619 Nm) just off idle and 625 lb-ft (847 Nm) by only 2,800 rpm. The V-12-powered Ferrari F12 Berlinetta, for example, produces about 28 percent less torque than the Z06, despite offering about 12 percent more horsepower – and its peak torque isn’t achieved until 6,000 rpm. The LT4 maintains 90 percent of its peak torque, or 592 lb-ft (802 Nm), from 2,500 to 5,400 rpm.
The new LT4 engine eclipses the Porsche 911 Turbo S engine’s peak power levels by 90 horsepower (67 kW) and 134 lb-ft of torque (182 Nm).
“Torque is the pulling power of an engine and the LT4’s abundance of it at every rpm in the engine’s speed range helps the 2015 Corvette Z06 accelerate quicker and respond nearly instantaneously,” said Jordan Lee, chief engineer for Small Block engines. “It’s the very definition of power on demand.”
The new Z06 engine produces 40 percent more peak torque (180 lb-ft / 244 Nm) than the previous-generation’s 7.0L LS7 engine – and 7.5 percent more than the supercharged 2013 Corvette ZR1’s 604 lb-ft (819 Nm). At 3,200 rpm, the new LT4 surpasses the LS7 by 208 lb-ft of torque (252 Nm). On the horsepower side of the graph, the LT4’s 650-hp rating is 29 percent greater than the LS7’s 505 horsepower (376 kW), and 12 horses more than the ZR1’s LS9 engine.
“The new LT4 engine builds on the design strengths of our previous supercharged engine and leverages the technologies introduced on the Corvette Stingray – direct injection, cylinder deactivation and continuously variable valve timing – to take Corvette performance to an all-new plateau,” said Lee. “Our new, very compact supercharger also helps the engine make power more quickly, and perhaps more importantly, it helps produce more torque earlier in the rpm band.”
“It’s also worth mentioning that the LT4’s supercar performance numbers are achieved with an engine that is nearly the same size as the very compact LT1 engine introduced in the 2014 Corvette Stingray,” Lee said. “The power density of the LT4 makes it one of the smallest and lightest 650-hp engines in the industry.”
LT4 details
The new LT4 engine is based on the same Gen 5 small block foundation as the Corvette Stingray’s LT1 6.2L naturally aspirated engine, incorporating several unique features designed to support its higher output and the greater cylinder pressures created by forced induction, including:
  • Rotocast A356T6 aluminum cylinder heads that are stronger and handle heat better than conventional aluminum heads
  • Lightweight titanium intake valves
  • Machined, forged powder metal steel connecting rods for reduced reciprocating mass
  • High 10.0:1 compression ratio – for a forced-induction engine – enhances performance and efficiency and is enabled by direct injection
  • Forged aluminum pistons with unique, stronger structure to ensure strength under high cylinder pressures
  • Stainless steel exhaust manifolds and an aluminum balancer that are lighter than their LT1 counterparts
  • Standard dry-sump oiling system with a dual-pressure-control oil pump.
A new 1.7L supercharger spins at up to 20,000 rpm – 5,000 rpm more than the supercharger on the Corvette ZR1’s engine. The rotors are smaller in diameter, which contributes to their higher-rpm capability – and enables them to produce power-enhancing boost earlier in the rpm band. That boost is achieved more efficiently via a more direct discharge port that creates less turbulence, reducing heat and speeding airflow into the engine.
“The Small Block’s cam-in-block design heritage has always enabled very high performance and responsiveness in a small, compact package – an attribute amplified by the performance of our new supercharger’s design,” said Lee.
The LT4 is assembled at the new Performance Build Center at GM’s Bowling Green Assembly Plant and at GM’s Tonawanda engine plant in New York. It is matched with a standard seven-speed manual transmission or an all-new, paddle-shift eight-speed automatic transmission built in Toledo, Ohio.
Designed to deliver shift responses on par with the world’s best dual-clutch transmissions, it is the first automatic offered in a Z06. It also makes the Z06 one of the few cars this powerful to offer the choice of a conventional manual transmission or an eight-speed automatic.
The 2015 Corvette Z06 goes on sale in the fourth quarter of 2014.
2023 GMC Canyon Elevation
2020 Chevrolet Colorado W/T Extended Cab (State-issued)
Old 06-05-2014, 11:29 PM   #2
AZCamaroFan
Camaro6 2016-2018
AZCamaroFan's Avatar
Drives: sometimes
Old 06-05-2014, 11:47 PM   #3
URBAN LEGEND
URBAN LEGEND's Avatar
Drives: 20 X3M CP & 19 ZL1 1LE A10
So answer this: Which is faster? C7 ZO6, Z/28, or 1LE? All on the Trofeo Rs.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 06-05-2014, 11:49 PM   #4
FenwickHockey65
I think it's a pretty safe bet that Z06 would murder pretty much every Camaro.
LT4's idle torque comes close to the F12 Berlinetta's peak torque output.
Old 06-05-2014, 11:52 PM   #5
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
The C7 Z06/Z07 will decimate most cars it faces. GM says it produces more downforce than any car they've tested and with this kind of power, it will tear up tracks. As disappointed as I am that it's supercharged, you have to be in awe of those numbers.
Bhobbs is offline   Reply With Quote
Old 06-05-2014, 11:52 PM   #6
Krajkerjac
Krajkerjac's Avatar
Drives: 2011 SS
The C7 is going to be incredible.
2011 SS L99 - CAI, Ported TB, Air Scoop, LT and HF Cats, Borla Exhaust, Quad Tips, 3.91 gears, 1.4 lowering springs, plus some misc.
Krajkerjac is offline   Reply With Quote
Old 06-05-2014, 11:57 PM   #7
keving2873
keving2873's Avatar
Drives: 2011 Camaro 2SS RS
I swear they said it was supercharged in that little segment...
2023 Black ZL1 **Awaiting Allocation**
476whp 455trq / Tuned by Tom Wong
CAI Intake with ADM Scoop, Borla ATAK cat-back, ARH 1 7/8 Headers and HF Cats
Custom Comp Cam 231/234 114LSA 617/598 lift, Katech timing chain
Apex Catch-can
VMAX Ported Throttle Body
20" Niche Essen's wrapped in Michelin PSS 315/295
keving2873 is offline   Reply With Quote
Old 06-05-2014, 11:59 PM   #8
crysalis_01
Iron fist, lead foot
crysalis_01's Avatar
Drives: 2003 Mustang Cobra
The question now is, will we see this beast in the next ZL1? Or will it get a "dumbed down" version, ala LSA vs LS9?
'03 SVT Cobra-SC4.6L V8 || modded with mods'n'stuff
crysalis_01 is offline   Reply With Quote
Old 06-06-2014, 12:00 AM   #9
Bhobbs
Bhobbs's Avatar
It is supercharged. I was hoping it would be a 7 liter LT instead but they couldn't meet the smog regulations with a 7 liter engine anymore.
Old 06-06-2014, 12:01 AM   #10
Bhobbs
Bhobbs's Avatar
I would be surprised if the ZL1 version isn't detuned.
Old 06-06-2014, 12:02 AM   #11
crysalis_01
Give it time, we may still see a big cube LTx. Plenty of numbers left and a whole alphabet too.
Old 06-06-2014, 12:05 AM   #12
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
holy mother of God
tramtwo is offline   Reply With Quote
Old 06-06-2014, 12:15 AM   #13
2010-1SS-IBM
Drives: 1998 Nissan, 2010 Camaro
This thing is a monster.
2010-1SS-IBM is offline   Reply With Quote
Old 06-06-2014, 12:20 AM   #14
Camaro Lives On
Force RECON
Camaro Lives On's Avatar
Drives: 2005 Saab 9-5 2.3T
Send a message via AIM to Camaro Lives On
Refer to sig plz!. Looks like I need to update it with a new Z06!
Camaro Lives On is offline   Reply With Quote
