JUICEDMOTORSPORTS
Camaro V6 LLT Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 08-08-2009, 04:23 PM   #1
97one
97one's Avatar
Drives: 1LT RS w/polished 19"rims
Exclamation V6 > 0-60 mph TIMES, what have others got ?
What 0-60mph times have you got with your 2010 V6 CAMARO ?
These are the times I got.
On level ground with 3/8 tank of gas , The Starts were from idle, in SPOPT mode & W/traction control ON............Which gave a Great start: not too much wheel spin.
5 runs: 5.70, 5.72, 5.76, 5.85 & 6.01 secs. (Last run was w/2 persons)
I used a MATRIX 3-axis accellerometer to get the results.
Does anybody know what HP Factor to use for the V6 to get Peak and avg. Horsepower readings ?
I tried 1.00 & 1.25 but they are to low.
Any input ?
Thanks
97one is offline   Reply With Quote
Old 08-08-2009, 04:46 PM   #2
jeansonne627
jeansonne627's Avatar
Drives: 2010 Camaro V6 RS IBM
wow...those sound like very good times for the 0-60...all i've seen on the videos have the M6 around 5.9 and the A6 at 6.0 - 6.1...I ordered the 1LT w/ RS in automatic also those times make me not feel so bad about getting the auto...however I live near downtown houston and traffic is horrible....what was the elevation/temperature when u made these runs?
jeansonne627 is offline   Reply With Quote
Old 08-08-2009, 06:21 PM   #3
97one
97one's Avatar
Elevation : app.300'
Temp. app. 70-75
Old 08-09-2009, 12:18 AM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
I've pulled 6.0... elevation in the 650 ft range... 75 to 80 degrees...
looking forward to some cooler days at the track come fall!
scrming is offline   Reply With Quote
Old 08-11-2009, 10:42 AM   #5
CamaroBAMF28
Drives: Black 2LT RS
times
haha ive ran a 5.7 on this dyno i have on my ipod. either my run was a good time or my ipod is accurate
CamaroBAMF28 is offline   Reply With Quote
Old 08-11-2009, 11:46 AM   #6
Mojave
Mojave's Avatar
Drives: 2013 300C HEMI, 2012 Ram 4X4 HEMI
If you are using Dynolicious, the times on that are good as long as the information you put in was good.
Good comparison of Dyno vs GTech on Garage 419. Done at a drag strip to compare the iPhone times to real times.
http://www.vodcars.com/garage419/episode/419_20080807
Ordered 2014 1SS 1LE NPP Recaros Backup Cam Sunroof AGM:
Status 1100: June 7
Status 2500: June 11
Status 3000: June 12
TPW July 15
Mojave is online now   Reply With Quote
Old 10-01-2009, 11:43 AM   #7
97one
97one's Avatar
[QUOTE=97one;776242]
On level ground with 3/8 tank of gas , The Starts were from idle, in SPOPT mode & W/traction control ON............Which gave a Great start: not too much wheel spin....Temp was 75 & Humidity was 50%
-----------------------10/01/09 New runs with COOLER weather.......................................
The same place and method as above runs. Only difference was 1/4 tank of gas.
And COOLER temp. of 53 & humidity of 59% ......elevation: app.350 ft.
0-60MPH 2 runs: 5.50 & 5.42 secs.
COOLER temps. do make for quicker runs....
Old 10-01-2009, 12:03 PM   #8
lil_chef
Banned
Drives: 2010 Mustang GT
[QUOTE=97one;991952]
And COOLER temp. of 53 & humidity of 59% ....elevation: app.350 ft.
WOOOOW, it looks like i wont need a 1SS to get the performance balance that i want.
lil_chef is offline   Reply With Quote
Old 10-01-2009, 12:22 PM   #9
KMPrenger
KMPrenger's Avatar
Drives: '10 ABM LT/RS, 01 Ford Ranger
scrming....what about the 5.63 (or close to that) that you ran on a cool morning?? Don't forget that! lol
Have you been able to try and reproduce that run?
Shes ALL MINE! - 8/24/2009 2G1FB1EV2A9133373 Custom Magnaflow Exhaust, Vararam intake, MACE Ported Intake Manifold, RX Ported TB, RX "Black Ice" manifold insulator, Mike Norris Catch Can, ZL1 reproduction wheels, DRL Harness, Heritage grill, Street Scene lower grill, NLP Spoiler, ZL1 rockers, Switchblade silver interior, Defenderworx sills, and more!
Old 10-01-2009, 02:24 PM   #10
scrming
scrming's Avatar
By golly you are right... forgot about this thread....
Most likely will not try to better it... Will probably stick to comparing time slips... LOL
Old 10-01-2009, 04:36 PM   #11
TJ91
:chevy:
TJ91's Avatar
Drives: 2LT/RS
0-60 in 10 minutes......seriously what if was feeling like a month ago....shes gotten better but ill see tommorow if my car just feels slow, or is actually slow
Old 10-01-2009, 07:04 PM   #12
Jozef
Drives: 2010 1LT Black on Black
I've done 5.78, 5.83 and 5.91 with my M6. Is the A6 really faster?
Jozef is offline   Reply With Quote
Old 10-01-2009, 07:23 PM   #13
scrming
scrming's Avatar
How are you measuring? What were the weather conditions?
Old 10-02-2009, 10:15 AM   #14
Primus
2G1FF1EV0A9113319
Primus's Avatar
Drives: 2010 1LT/RS 6MT
Manual shifting puts the onus on the driver, doesn't it? So it would be much less consistent. Auto trans shifting should be much more consistent since it will shift at specific RPMs.
2010 Camaro 1LT/RS M6 Black
1100: 10/13/2008
2000: 4/02/2009
3000: 4/08/2009
3300: 5/14/2009
3400: 5/21/2009
3800: 5/28/2009 VIN: 2G1FF1EV0A9113319
4000: 5/28/2009
4150: 5/28/2009
4B00: 5/28/2009
Delivered: 6/10/2009
Primus is offline   Reply With Quote
Old 10-02-2009, 10:28 AM   #15
Kaoz
Drives: Camaro 2LT/RS
How about power shifting? I'll try some 0-60s on the weekend.
It's around 40F and we're under 100 feet elevation.
Rally Yellow 2LT/RS
2000 - 06/03 - Moved to "Placed" status
2500 - 06/23 - Preferenced
3000 - 06/24 - Ready to schedule
3100 - 07/23 - Scheduled
3300 - 07/23 - Sequenced for production
3400 - 07/25 - Broadcast
3800 - 08/03 - VIN
Kaoz is offline   Reply With Quote
Old 10-02-2009, 11:12 AM   #16
blakeequalshyphy
blakeequalshyphy's Avatar
Drives: 2010 2LT/RS Black Camaro
I had a 0-60 run at 3.4 seconds. I was sloppy that day
blakeequalshyphy is offline   Reply With Quote
Old 10-02-2009, 05:56 PM   #17
ckaram
ckaram's Avatar
Drives: 2011 2SS RS, 1968 ragtop
Dude!
Current Camaros: 1968 convertible, original 327, Iron Eagle heads, DT headers, Magnaflows, Muncie 4-speed, 3.08 posi, 17" Torque Thrusts,
2011 2SS/RS, LS3, M6, IOM in and out, factory Hurst short throw, GMPP axleback exhaust Delivered 5/14/11
ckaram is offline   Reply With Quote
Old 10-02-2009, 11:00 PM   #18
Jozef
I was using a HP TravelCompanion on my Pocket PC. It was at about 100' elevation, and 58 degrees (early morning).
I hope to be able to find the time to go to an 1/8 mile track next week to get some more reliable numbers.
I also just finished my intake!!!
I'll hopefully get pics up tomorrow!
Old 10-02-2009, 11:06 PM   #19
revron
revron's Avatar
Drives: camaro 2lt rs auto silver
I used the matrix 3 axis unit. I did 3 runs. Average time was 6.5 sec
I have a v6 rs,auto, ran in manual mode. stock engine. Conditions were, 80 deg. humidity 20%, elevation 2600ft.
I just ordered an airaid intake, x pipe, 2 mufflers and tips. When I get my items I will do another base line and then do a timed run on the cai and then the exhaust to see if there is any difference and post my findings.
revron is offline   Reply With Quote
Old 10-02-2009, 11:27 PM   #20
revron
revron's Avatar
Scrming.
Regarding the sensors for the stock air box. I can relate to your hot air findings. I did a couple runs this evening. First run, 72* out, (engine barely warmed up) I ran a 6.4 sec and the next two were around 6.7 and the intake tube by the sensors was very hot.
Old 10-03-2009, 06:53 AM   #21
scrming
scrming's Avatar
WOW! 100' and 58 degrees... that's some GOOD AIR!!! I'm at about 850'. We do have one track that is open until the end of November... I meet up with some friends their the 1st Saturday of November... Usually some fantastic air and always one or two personal bests!
Looking forward to seeing your intake!
Old 10-03-2009, 06:54 AM   #22
scrming
scrming's Avatar
Originally Posted by revron View Post
Scrming.
yep, the difference is amazing...
Old 10-11-2009, 09:47 AM   #23
scrming
scrming's Avatar
Ok... incredibly clear morning (high pressure - 30.3 inches) so I decided to make another 0-60 test... this one is closer to 60 MPH.. previous one was 60.9...
Old 10-11-2009, 11:40 AM   #24
97one
97one's Avatar
OK today is great weather to make some 0-60mph runs, these are the results:
Temp. 54-55 degs. = VERY GOOD
Humidity 53-55 %
Barometric pres. 30.19 = VERY GOOD
Elevation app. 350 ft.
Did four 0-60mph runs today: 5.31, 5.18, 5.17 & 5.13 = my best ever.
This was with my new MRT axle back exhaust.
My prior four 0-60 runs were : 5.30, 5.29, 5.26 & 5.23 But with those runs the Bar. pres. was 30.02, tem. & hum. about the same so, how much the exhaust did can't say 100% but maybe as much as .10 sec.(which is the diff. on the best 2 runs)
Old 10-11-2009, 12:03 PM   #25
scrming
scrming's Avatar
Humidity 53-55 %
PS>>>>>>>>>>>>>>sorry I don't know how to make the photos SMALLER?......Need answer please.......
Very cool!!!
This morning the air was amazing... Barometric was 30.3 inches! I tried just a fairly hard take off with the traction control off and just spun the tire wildly! LOL!
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 297 04-21-2013 05:38 PM
Maximum Speed trudawg660 5th Gen Camaro SS LS LT General Discussions 54 02-23-2011 02:17 PM
Camaro vs Corvette? Dr Jkel Chevy Camaro vs... 71 11-12-2010 01:39 PM
Gear Ratio/RPM/MPH Spreadsheet in MS Excel ... dougmac 5th Gen Camaro SS LS LT General Discussions 8 04-20-2009 06:19 PM
Automobile Magazine Review - First Drive: 2010 Chevrolet Camaro SS camaro5 5th Gen Camaro SS LS LT General Discussions 17 03-21-2009 12:33 PM
