Old 07-07-2014, 03:01 PM   #1
BigBoyBlue
Go NY Giants & NY Rangers
BigBoyBlue's Avatar
Drives: 2013 ZL1 M6
Cutting The Grounding Bolt - Installing RotoFab
Hello, guys. I am 0% mechanically inclined. For that reason, I'd like my RotoFab to be installed such that I can take the air filter off without disassembling the CAI. I've read that some people shorten the grounding bolt and that allows the filter to be changed without disassembly.
Does anyone have a video or step by step instructions for this strategy?
Thanks in advance.
Molon Labe!
BigBoyBlue is offline   Reply With Quote
Old 07-07-2014, 03:04 PM   #2
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
I wouldn't do that.....not worth it.
Filter will last a pretty long time to worry about removal.
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 07-07-2014, 03:12 PM   #3
BigBoyBlue
BigBoyBlue's Avatar
Drives: 2013 ZL1 M6
How do you clean the filter? Don't you need to take it off?
Molon Labe!
Old 07-07-2014, 03:25 PM   #4
CRTZL1
Banned
Drives: 2013 CRT ZL1
Do the normal install. It's very easy just to unscrew the clamp holding the filter on. I can get mine off maneuvering around the ground bolt.
You could always cut it down a little also with a dremel.
http://youtu.be/y7Uugwya0_8
CRTZL1 is offline   Reply With Quote
Old 07-07-2014, 04:33 PM   #5
BigBoyBlue
BigBoyBlue's Avatar
Drives: 2013 ZL1 M6
So it is possible to get the filter off without taking apart the intake? Thanks.
Molon Labe!
Old 07-07-2014, 04:36 PM   #6
CRTZL1
Banned
I'm not going to lie it is a pain in the ass to shimmy it off around the bolt.
Honestly now that you started this thread, I think I'm going to cut my bolt, make it a lot easier
Old 07-07-2014, 06:37 PM   #7
Baer383
Baer383's Avatar
Drives: 2013 ZL1 Ashen Gray
I didn't have to cut my ground bolt.
I don't have to know everything,I just need to know,what I need to know,when I need to know it!
MODS, a lot of money,a lot of parts,a lot of time,a lot of patience.
754 RWHP 747 RWTQ 93 Octane
http://www.camaro5.com/forums/showthread.php?t=347243
Baer383 is offline   Reply With Quote
Old 07-07-2014, 06:57 PM   #8
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Are you talking about the ground stud for jump starting the car? I removed that and left the ground bolt in place. Filter comes right out easy as could be! No cutting of anything.
2013 ZL1 #7860 is offline   Reply With Quote
Old 07-07-2014, 07:00 PM   #9
mmarx82
mmarx82's Avatar
Drives: '12 ZL1 #1609
Why not just get a Filter Wrap and then all you have to do is wipe it off with a microfiber cloth every now and then...
This is the right one if you bought the K&N CAI: K&N RF-1036DK
Life is too short to drive cars that suck.
My build Thread
mmarx82 is offline   Reply With Quote
Old 07-08-2014, 09:52 AM   #10
G Money
G Money's Avatar
Drives: 2013 ZL1, 2016 Denali HD
+ 1
LSX 427, Twin Precision Turbo's, 64/66. Nitrous Outlet System. Pro EFI Engine Management Systems. Vengeance Racing Built......
G Money is offline   Reply With Quote
Old 07-08-2014, 10:27 AM   #11
tonyfred
tonyfred's Avatar
Drives: 2013 ZL1-Victory Red-Auto
I used a pair of vice grips to remove the ground stud and relocated it.
tonyfred is offline   Reply With Quote
Old 07-08-2014, 11:29 AM   #12
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
The ground bolt that is in the way of the filter to remove it can be easily unscrewed with a 10mm wrench. No need to cut it.
Deke736 is offline   Reply With Quote
Old 07-08-2014, 07:18 PM   #13
2013 ZL1 #7860
Exactly? Why are people cutting it?
Old 07-08-2014, 07:32 PM   #14
OldJedi
Use the Force
OldJedi's Avatar
Drives: 2015 Corvette Z51, 2018 Porsche GTS
Send a message via AIM to OldJedi
Like Deke said, if it proves to be in the way, just unscrew it. Of course you most likely will not have to worry about cleaning the filter for 50,000 miles. Just a thought.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
