HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
Mixing fuels
In Arizona we basically have 91 octane, but there are a few places that sell "racing fuel" which is 100 octane. My question is can you mix the two and at what ratio? Also once mixed, can you just reset the tables or would a tune be required? I would like to be able to boost the octane this way without buying octane booster. Anyone done this?
Going for Plaid
Drives: 2011 C6 Join Date: Jan 2010
Octane is a straight ratio. So 5 gallons of 91 and 5 gallons of 100 would be 91+100/2=95.5 octane. You can do the fuse pull deal to reset your fuel trims. Unless you get your IAT2 under control it really won't matter on the stock tune. Also, unless you have a tune loaded that adds more timing for the added octane, I wouldn't bother.
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance. 2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14) |
#3 | |
HAMMER PILOT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Mar 2013
I was told somewhere on this forum that you cannot use racing fuel if it is leaded. Now unleaded racing fuel would be great and I was told it is made but have not checked into that any further.I just use the torco when I want to drag race the car and it works very well.
That is what I did before when mine was stock. It sure made a difference. Again I used the torco and it put it 111 octane I believe.
#6 |
HAMMER PILOT
I will have to check if it is leaded, 111 without a tune? That would be great, maybe I will just have to go the torco route.
#7 |
Going for Plaid
You can run whatever octane you want if it's unleaded. Added octane won't matter if you aren't tuned for it. You might see a few HP, but it's not going to be much. The stock tune is designed to make max power on 91/93 octane.
#8 |
Going for Plaid
I know what Torco says it does with octane, but knowing that octane is a straight ratio, I don't see how you hit 111 octane adding Torco unless it's A LOT of Torco. You want max power just do 93-94 octane. Unless you add timing for more octane there's no point going past 93-94.
#9 |
Well I just went out to the shop and got a can of it. It says +11octane with a 32 oz can on 10 gallons.So if you have 93 octane plus 11 that will be 104 octane. My mistake. I guess I was thinkin 111 when I saw the +11! O well sue me!!
#10 | |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
#11 |
HAMMER PILOT
Can you run that in a car that is stock? All I can get is 91 octane here. I am trying to find a way to run higher octane on a race day, I have a CAI, but I want to keep my warranty for now but still get the best performance.
#12 |
ANGRY Z
Yes you can but it's very expensive. I think you'd be better off just adding torco to race. I pay 25.00 a gallon for VP109. Before I had a race gas tune I used to add 1/2 can of VP equivalent to tank of gas just to be sure my octane was up. A night at the track can run me 250.00 just for fuel!!!
#13 | |
HAMMER PILOT
#14 |
ANGRY Z
I think with a custom tune the tables are set and will not adapt. I don't think a fuse pull does anything like it does to a stock tune.
