08-15-2014, 09:18 PM | #1 |
618 RWHP
Need advice please .
I was driving my new 2014 ZL1 today and some (A hole ) left a razor blade knife in the road. Of course I did not see it and ran over it. I ended up with a broken razor blade embedded about 3/4 of an inch in my rear tire. I had to pull it out because it was going in deeper as I was driving on it to my local dealer. To my surprise after pulling it out the tire was holding air and when I got to my dealer they pulled off the tire and checked it - it was not leaking. I told them to order me a new tire anyway because I don't want to take a chance of it starting to leak a week from now or when I am driving on a track. This whole situation got me thinking about a few things.
First I only have 2,700 miles on my car should I replace both back tires? Or just the one? I am also wondering is there any options out there of how to get a ZL1 on a flat bed truck with out wrecking the front splitter or the rims? I have seen this tow ring that sticks out of the front lower grill but I think it looks terrible. |
08-15-2014, 09:29 PM | #2 |
Drives: 2013 ZL1 Join Date: Oct 2013
I would compare outside diameter old versus new. Maybe even circumstances and tread depths. That should give you a much better idea as to if there is too much wear . I guess it really depends on how much you have been getting on it as far as tread depth left. A second tire is cheaper and easier than premature wear on a limited slip diff.. All that said I bet you would be fine, but I would want measurements to help make my mind up.. In the end if I felt funny about it, just to know all is cool I would replace both so I would not have to wonder about it again.
2013 Silver ZL1
08-15-2014, 10:01 PM | #3 |
H-Town Camaro Club Member
Drives: 17 Hyper Blue Metallic KLR-ZL1 Join Date: May 2009
If you have the cash then buy both. They are less than $300 apiece on Tire Rack. You can get all for mounted at Discount for a little more than a grand.
08-16-2014, 02:47 AM | #4 |
Drives: 2014 Black ZL1 Join Date: Jan 2012
Mine was flat bedded out to the track so that easily possible we solved the clearance issue with a few 2 by 4s. Drove on fine both ways. Funny, I had my rear right tire go flat at 800 miles due to some piece shrapnel embedding into the sidewall.
2011 2SS, 535 rwhp (sold)
2013 300 SRT8 (sold) 1968 Triumph T100C 1960 Ford thunderbird 390 FE 2014 Camaro ZL1 |
08-16-2014, 07:47 AM | #5 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
The stock tires seem to pick up anything that can puncture a tire like a magnet. I picked up a nail in my rear driver side within a few months of buying it. In your case I would have the tire tested to see if it actually has a leak. If it does have a leak I would have it patched unless you plan on tracking it. There is a spare tire in the trunk in case you get a real flat on the road so you don't get stranded.
08-16-2014, 08:29 AM | #6 | |
HAMMER PILOT
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado Join Date: Nov 2011
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
08-16-2014, 10:22 AM | #7 |
Drives: 2014 ZL1 M6 Join Date: Jul 2014
I have a battery where the spare tire used to be.
Just fyi. Tony
2014 ZL1 M6
Bone stock, for now! 2001 Z28 M6 !cags, !air, FTP 85mm Lid, Z06 85mm MAF, P&P TB !4x4, Strano Springs, Strano Sways, Koni 4/4s, Watts Link ARH LTs, ARH catted Y, SLP catback with Dual/Dual Muffler, SLP CME and Valance OE Wheels Machined Face C5 DDs, 18x10.5s, with 295/35-18s on all 4 corners! 352rwhp and 366rwtq |
08-16-2014, 10:32 AM | #8 | |
Drives: 2013 Camaro ZL1 Join Date: Dec 2012
I love the way mine looks. It's required for those that take their cars to the track. You'll hate the look of it until you are stuck and need to get pulled out of the dirt on a public highway! I have been in that scenario before, prior to installing a tow hook I was forced to watch the tow truck operator attach hooks to the underside. The whole time I'm hoping that he didn't take out the MR sensor while attaching the hook! He didn't but others have. One possible option is to attach a strap to your bumper, since you want to keep your ZL1 stock and not looking"terrible". |
08-16-2014, 10:56 AM | #9 | |
Yep, Nails got my right rear and had a track day that Monday, That was a quick 300 $ . You don't realize how big the tire is until you see it off the car. |
02-18-2022, 07:33 AM | #10 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
Not the same issue.
Oil? At the front grill, or coolant? And jfyi, it is more appropriate to start your own thread, rather than reviving an 8 year old thread, particularly when the matter is totally unrelated to the op. |
02-18-2022, 08:21 AM | #11 |
Drives: 2015 Camaro 2SS l99 Join Date: Jul 2021
I am new on here my bad
02-18-2022, 08:31 AM | #12 | |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
02-18-2022, 10:21 AM | #13 |
KaBoom1701
Meh.... it happens.
Just do a epic burnout and give the rear tires a proper send off. Then grab a new set and move on. Gotta pay to play with these cars.
Mods:
02-18-2022, 01:07 PM | #14 | |
Drives: ZL1, 2013, tri-coat-red, manual Join Date: Nov 2013
Yep I send old rears and clutch's to the graveyard with the same ceremony.. |
