09-05-2014, 08:38 AM | #1 |
Drives: 2016 Corvette Z06 M6 Join Date: May 2009
10" lower to keep blower stock for warranty?
I'm thinking about picking up another ZL1, and am trying to determine a correct mod path.
My last car had a 2.4 upper, ported snout, TB, CAI and an LS9 cam. Using the 10" lower on my new ZL1 and leaving the blower pulley and snout stock should eliminate any warranty concerns down the road with a supercharger bearing/isolater failure right? I could also go with a different cam too while doing the lower. Thoughts?
2013 Dodge Viper #44/150 Launch Edition IG:@absoluthank
20/21 BC Forged Wheels : BC Coilovers: TA Aero |
09-05-2014, 09:29 AM | #2 |
Drives: '21 ZLE A10 Join Date: May 2012
I like my 10" lower and the upper pulley is stock. I have never removed the blower from the engine. If you do a 10" lower and a cam swap, your car will run great. Metco makes a 10.5" lower ring if you use a Metco lower balancer. ATI is limited to a 10" lower. Warranty concerns are less with an unmodified blower and you could easily return the car to stock.
09-05-2014, 09:39 AM | #3 |
Drives: none Join Date: Aug 2011
Agree with Stephen, and is what I did.
As long as your dealer will play ball then you still have a shot at them replacing the blower should it start rattling. |
09-05-2014, 11:33 AM | #4 | |
I prefer to use the lower to increase blower speed over the upper pulley method. It takes more torque to turn the blower faster why reduce the belt contact area and induce belt slip during throttle transitions. You can spin the blower past max blower RPM with just the lowers that are available. Ted.
www.jannettyracing.com
09-05-2014, 05:47 PM | #5 | |
Drives: 2013 ZL1 A6 #7860 Join Date: Apr 2014
09-06-2014, 07:47 AM | #6 | |
09-06-2014, 07:51 AM | #7 |
Drives: none Join Date: Oct 2012
Personal opinion here if you are going to mod it take responsibility for it, your warranty is gone. Put a solid isolator in it, any issues are your problem.
Computer will also show that the tune has been changed and also how many times it has been changed. |
09-06-2014, 01:34 PM | #8 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
The way I see it you want to change the lower pulley so you will still have a warranty on the upper pulley isolator that pretty much everyone now realizes is bad. Why not just change the upper pulley and completely eliminate the bad parts right from the beginning?
The only reason the supercharger needs warranty is because of that spring isolator behind the upper pulley. If you change the upper pulley, pretty much everyone throws away the bad isolator with the pulley change and puts in a solid. If you do the upper pulley and put in the solid isolator at the same time all the supercharger problems are fixed. If you want pulley upgrades put a 2.5 upper on it an you wont have any more worries with supercharger then you can do a lower on the bottom if you want more boost in the future. That is what I would do.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
09-06-2014, 07:20 PM | #9 |
Faster than you...
Drives: 1194whp. 8.62@168. daily driver... Join Date: Nov 2013
Another ZL1? Lol, you change cars way too fast.
Can't wait to see what you end up with
GTR
09-08-2014, 08:02 AM | #10 | |
If you touch the blower they will not warranty if the bearing fails. Ted.
09-08-2014, 09:05 AM | #11 | |
Speed Freak
I've had 2 cars with LSA, superchargers. My Cadillac had the supercharger replaced because the isolator bearing was knocking. The knock was starting to come back and then I had the upper pulley changed and that fixed everything. My ZL1 had the upper pulley changed 3 days after I bought the car and never had a problem. You probably see a lot more cars than I do but I don't know of any car that had the upper pulley changed and a solid isolator installed that had a bearing problem later on. I still think the smart way to go is change the upper and get that spring loaded isolator out from the beginning.
09-08-2014, 09:20 AM | #12 | |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
09-08-2014, 09:53 AM | #13 | |
Speed Freak
09-08-2014, 11:09 AM | #14 |
ANGRY Z
A guy has to look at the build date on the 14's also Jess. The earlier 14's had the spring loaded isolator. I couldn't find a serial # split but my dealer had a TSB that states cars produced after Nov 13 had the solid isolator.
