09-05-2014, 08:57 AM | #1 |
Drives: 2014 Camaro ZL1 Join Date: Jun 2014
Jack stands - one side at a time?
I hope I don't get beat to death over this topic as I seen it's been discussed a lot, but I can't find this particular question answered. I realize the ZL1 has the belly pan so you can't get to the center support to jack the entire front of the car at once. I just completed the break-in period, so I'm going to be changing all the fluids and hit the track this fall. I need to get the car up on jack stands to have enough room to comfortably do everything. I assume since the belly pan is in the way, I need to put jack stands under the front, one side at a time. Won't it put a lateral force on the first jack stand when I move to the other side to jack it up? I'm thinking that might cause it to shift and slide off the first jack stand. Any tips would be appreciated.
Thanks, Shane |
09-05-2014, 09:32 AM | #2 |
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla Join Date: Aug 2013
Jack from the center and put stands under both sides before lowering.
(borrowed from GIS result) |
09-05-2014, 09:36 AM | #3 |
Drives: none Join Date: Aug 2011
Where did that pic come from? Doesn't look right at all.
09-05-2014, 09:42 AM | #4 |
09-05-2014, 09:58 AM | #5 |
Drives: 2013 ZL1 Join Date: Oct 2011
I just bought a two post lift. seemed like the most economical way to deal with the belly pan issue.
the quickest easies solution to this car IMO is s second cheap floor jack from harbor frieght. lift one side enought to pull the belly pan and then jack from the center. I already had a few floor jacks so that is how I did before the two post lift. there are low profile ramps and such but they cost more than a cheap floor jack.
shopping for 2017+1le or zl1
2009 CTS-V -sold 2015 Hellcat-sold 2013 ZL1 -sold 2007 Z06- sold 2014 Chrysler 300 2011 Duramax 8" lift, deleted tuned |
09-05-2014, 10:02 AM | #6 |
Man, I'd love to do that. I have issues with concrete floor thickness though. I'm looking into freestanding 4 post lifts, but that still leaves the issue of taking the wheels off. Still better than jack stands I guess.
09-05-2014, 10:07 AM | #7 | |
I would just do a cheap harbor frieght or used second floor jack until you get that all figures out. what is you pad thickness? one quick and dirty solution is just just pour supports for the lift. saw out a sectio of the floor and put in support. I got luck and they had some sloppy excavating toward the back of my shop so the pad is like 6"+ back there where it is more of the minumin 4" up in the front bay. that is where sloppy work pays off ha ha. I don't miss the two jack rodeo one bit.
09-05-2014, 10:14 AM | #8 |
Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I use jack pads from ZL1addons with two floor jacks to raise the car evenly from the rocker lift points. Then put that stands inward as shown. It's a little time consuming because you have to raise the front and rear in stages but gets it done
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - |
09-05-2014, 10:35 AM | #9 |
I can't do that. My parking area is actually an elevated concrete deck on composite decking (my garage has a basement). The pour is only 4 inches thick and with the ripples in the decking some parts are only 2.5 inches thick. It's safe and certified. They do a lot of it around here. Just not thick enough for those two post lift anchors.
09-05-2014, 10:36 AM | #10 |
I guess it looks like two jacks is the solution until I decide on a lift. What a hassle.
09-05-2014, 11:13 AM | #11 |
Drives: 2016 Challenger Hellcat, 2018 ZL1LE Join Date: Dec 2009
Seems odd to me that GM didn't allow for some room underneath in the front to be able to jack the car up from the middle so we can put jack stands under it.
09-05-2014, 11:48 AM | #12 |
Belly pan is covering the structure so you must go frm the sides
09-05-2014, 11:57 AM | #13 |
Drives: 2013 summit white ZL-1 Join Date: Sep 2013
once you know where the center support is under the belly pan...who says you cant jack from there?
09-05-2014, 12:17 PM | #14 |
Cartoon Maus
It probably isn't, as I swiped from a GIS as I noted. Point being, there is a central jacking point, front and back, and every car. Or at least, every car I've ever owned. I can't imagine the Camaro is special in this regard.
