![]() Drives: CAMARO SS 2012 L99 PROCHARGED/METH Join Date: Jul 2014
Wich is the max PSI for a Stock Camaro SS 2012 L99
Hello, i have a camaro with p1sc procharger, the question is wich is the max psi pressure for my stock l99 engine? 10 PSI? 12? Thanks for your help.
Guest
Mine blew @ around 11.5 -12 psi. I'd stay under 10 but that's just me.
#3 | |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
I lost a head gasket at 16 psi and 807whp on my LSA motor.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. ![]() |
![]() Drives: '11 Camaro Supercharged Convertible Join Date: May 2014
10 is about it with meth as a safety precaution, but I've pushed mine to 15 lbs.
2011 Triple Black SS convertible, LSX 427, PRC 260cc heads, Callies Ultra Billet Rods, Wiseco -20 cc piston, Callies Dragon Slayer crank, Strange Dana 60 rear w/3.73 gear ratio and driveshaft, Pfadt coilovers, Pfadt sway bars, Pfadt trailing arms, Pfadt tie rods, Pfadt subframe bushings, Vortech YSi with wastegate and twin BOV, Haltech ECU, Mantic 9000 Twin Clutch, ALKY control meth system with dual nozzle, Squash twin fuel pumps, ACS T3 ports, VIS Terminator Hood, Seibon ZL style lip.
Guest
#6 |
Thank you for your help! I'll try to keep in 10 PSI with methanol. I do not want to damage the engine.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Z06 Join Date: Oct 2010
Depends. Turbo cars can typically get away with a bit more. It isn't PSI, just power you should be concerned about. l99 is good for ~700-750rwhp depending on blower or turbo. Boost doesn't matter. Could be 22psi or 5psi.
Nick
Corvette Z06 -1200ish rwhp |
#8 |
#9 |
No, it doesn't. It is just a measurement of restriction. Headers, cam, heads, type of power adder all change that. You could ask what is a general range of boost for a bone stock car with no other mods and a procharger to run, but in the end power and specifically cylinder pressure is what limits a motor. You can get to 800 crank HP with 5psi with really good heads/cam/headers or 20psi with a restrictive setup. Most guys will say ~12-13psi is the limit because that is typically what gets you to ~750rwhp on a ls3 car, but the boost doesn't matter, it is the power level/cylinder pressure. You can put some heads and cam on a 750rwhp car, make 3psi less, and the motor is still making 750rwhp, seeing the same cylinder pressure and same stress on the pistons/rods/rings/head gaskets. You maybe in a more efficent part of a compressor map so may get cooler intake temps, which maybe safer, but you may not.
If you are asking on a bone stock motor, with a p1sc how much boost you can run, the answer will be until you run out of fuel/octane, and with that blower and nothing added like meth you will run out before the motor is the limit. If you upgrade the fuel system sufficiently then you should be able to just about max out that blower before the motor runs out in the 700rwhp range assuming you have enough fuel/octane to push the blower to max RPM/impeller speed.
Nick
#10 | |
#11 |
![]() Drives: 06 Z06 TT Join Date: Nov 2013
Unreal is correct... BOOST mean shit..
example. a 6.2 making 700 on twins with 8 psi and a 6.2 making 700 on a single will have different boost levels.. both making same power. is tthe cylinder pressure you have to watch out for. ^^ those two cars i list above should ahve close to the same cylinder pressure. |
#12 |
Really, Really Fast
Drives: 2010 Camaro SS Join Date: Feb 2013
I have been running 16-17 psi on mine for a year now... No problems.car is somewhere between 800-900whp
I'm on e85 with 100% meth
Procharger F1X, TH400, E85, CBI Street Cars, DSX Tuning, 1300whp
#13 |
Really, Really Fast
Also there are quite a few cars running well over 900whp to the tires with no problems
#14 |
Drives: Many C7's Join Date: Apr 2014
