Old 09-24-2014, 04:09 PM   #1
JoshuaJP84
Drives: 2011 Camaro LS V6 Stock package
Governor
118 mph??? How do I bypass this thing?!
JoshuaJP84 is offline   Reply With Quote
Old 09-24-2014, 05:48 PM   #2
Au201
Drives: Black V6 auto 2LT RS
Don't. Unless you get new tires. The reason it's limited to 118 is because your tires aren't rated for speeds higher than that. They're not safe above that speed. Camaro's with the RS package get perilli tires and their limiter is moved up to 155mph
Sent from my bragging iPhone using an app that encourages it.
Au201 is offline   Reply With Quote
Old 09-24-2014, 07:09 PM   #3
Demon War Horse
War Horse Pilot
Demon War Horse's Avatar
Drives: 2017 NFG 1SS 1LE
This. Better tires, then tune.
COTW 09/07/2015 - 2014 AGM 2SS/RS - RIP 6/01/17
2017 Nightfall Gray Metallic 1SS 1LE Born 5/17/17 - Click Sig Pic below for for Demon War Horse 02 Build Thread
SigPic by Hazman
Demon War Horse is offline   Reply With Quote
Old 09-25-2014, 10:37 AM   #4
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Only way to do it is an ECU tune but then you lose your powertrain warranty
Old 09-25-2014, 12:18 PM   #5
CruisingSpeed
The Stealth Bumblebee
CruisingSpeed's Avatar
Drives: Black 2013 2LS
Almost thought this was going to be about Rick Perry with the governor/texas and all that. Bigger tires. I hear the dealer would take the limiter off if you change diameter. Some nimwad at GM skimped on the rims by 1 inch and it costed us 37 mph more in speed! One thing I didn't know when buying, pisses me off. Like this weather down here!
KILLER BEEhttp://www.ferrarilife.com/forums/attachments/modern-v8s-360-f430/51795d1353344804-f430-yellow-calipers-imageuploadedbytapatalk1353344802.106093.jpg
CruisingSpeed is offline   Reply With Quote
Old 10-17-2014, 08:31 AM   #6
Snidely Whiplash
Fight Crime, Drive Armed
Snidely Whiplash's Avatar
Drives: '14 2SS Yelo Maro, HD collection
My SS was supposed to be limited to 155 at the factory. When Anthony did my tune, he said the factory governor was set at 255.
Bring back Sunoco 260 to the local station. Some folks STILL drive L-88s and need the good gas.
Snidely Whiplash is offline   Reply With Quote
Old 10-17-2014, 04:59 PM   #7
jkchambless
Austin LT
jkchambless's Avatar
Drives: 1LT - Airaid,JBA Axleback,VMax PTB
Diameter isn't the issue.....you can buy Z rated tires for the 18 inch rims but they are expensive. Also, haven't heard of any dealer resetting the limiter regardless of the tire change....too many liability issues. A tune will be required and on a V6 it doesn't necessarily void the power chain warranty as long as you have the option to reload the original factory tune.
jkchambless is offline   Reply With Quote
