10-02-2014, 09:38 PM | #1 |
Drives: 2011 Camaro 2Ss M6 Join Date: Dec 2011
Windsheild Wiper Blades
Where do you get yours?
Whats a good brand? |
10-02-2014, 11:12 PM | #2 |
Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
Wrong section.
Detailing is an involuntary obsession.
10-03-2014, 06:24 AM | #3 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
I have never had an issue with the OEM blades. They work great, and I have driven in some heavy downpours, for hours without issues. Are you having issues with your blades or just prefer something different?
10-03-2014, 06:33 AM | #4 |
Too much is never enough!
Funny every new car I have ever bought, the blades last forever! I just changed the blades on my car at 45k miles! lol Seems as though once there changed I can never get the same longevity out of the replacement blades as hard as I try. In fact they don't last any ware near as long.
I like Anco wiper blades, those are my prefrence. Also Bosch and Rainex make a decent set as well.
10-03-2014, 07:57 AM | #5 | |
Drives: 2014 Camaro 2SS RS Join Date: Aug 2014
10-03-2014, 08:02 AM | #6 |
Something about what they put on at the factory and what they put on from the dealer is never the same. I don't understand why but its different. Same with the last 4 Chevy vehicles I have owned, Including a Toyota I bought new.
I have watched the dealer grab Delco blades....still not the long lasting as what was put on the car. That is why I have gone with Anco they last longer then the OEM's I buy at the dealer.
10-03-2014, 08:07 AM | #7 |
I always go and get the oem blades, they last a looooong time for me, allot longer than the aftermarket
10-03-2014, 11:16 AM | #8 |
I was actually washing my car and i went to grab the blade to dry it down and after 36k miles i guess they had enough and the blade peeled back a bit. Ended up getting bosch icon's at walmart for 18 a piece. Hopefully they last! We almost never ha e rain out here in cali and my car is 100% garaged.
10-03-2014, 11:31 AM | #9 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
GM part numbers for the blades with inserts: 92231676 and 92231677
You can get them on ebay for $18.86 per pair, shipped.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
10-03-2014, 04:33 PM | #10 |
Obsessed
Drives: 2016 Hyper Blue 2SS RS Join Date: Jun 2011
OEM for me all the way, no replacement has ever been as good for me as the OEM ones.
2016 Hyper Blue 2SS |
10-03-2014, 04:41 PM | #11 |
10-03-2014, 04:43 PM | #12 |
Ok now you guys got me thinking that maybe something has changed in the last few years. Too bad I just bought some blades last week,I think i'll give the OEM a shot again next time.
10-03-2014, 08:04 PM | #13 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
OEM are the best IMO.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
10-03-2014, 08:36 PM | #14 |
Montani Semper Liberi
Drives: 2011 Black 2SS/RS w/ IOM stripes Join Date: Feb 2010
usually just get the OEM ones off GMpartshouse.com, from replacing them on my last camaro learned that the originals are just as good as the best aftermarket ones and there cheaper for the most part if you shop around. get the OEM's and once your replace them you will realize they are darn good!
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint |
