Old 10-07-2014, 12:23 PM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JANNETTY RACING TUNED 1-LE AGP TWINS 93 OCT 10 PSI
Loving these AGP Twin kits, Lots of power for a single bolt on.
We did this one with
The AGP twin kit
ID-850 injectors
ADM Fuel pump control module
SCT 7416 hand held tuner
JRE custom dyno tuning.
93 octane pump gas
G-force boost controller
10 psi at peak finishing at 8.5 psi. with 6 lb wastegate springs.
Results 615 RWHP 631 RWTQ
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 10-07-2014, 12:28 PM   #2
402
Drives: Camaro
10 psi at peak finishing at 8.5 psi. with 6 lb waste gate springs
Any reason for such fluctuation? Are you boost controlling it? When i ran 6lb springs it was 6 from 3500 to 6600.
402 is offline   Reply With Quote
Old 10-07-2014, 12:36 PM   #3
JANNETTYRACING
With the 6 psi springs it falls about .5 psi toward redline 6.5 to 6.0
When you add a boost controller it is common to not hold a flat boost curve.
It hits 10.1 psi at 4000 and falls to 8.5 by redline but smooth.
If we went the route of installing 10 psi springs the boost would be more flat.
Customer wants 6 for the street and 10 for the track.
Ted.
Old 10-07-2014, 12:40 PM   #4
402
Drives: Camaro
Ted.
A simple "Yes, there is a boost controller" would have sufficed.
I wouldn't call 10 to 8.5 smooth by any means.
Old 10-07-2014, 01:06 PM   #5
pincushin3819
pincushin3819's Avatar
Drives: 11 AGP TT SS, 14 ECS C7
So the peak numbers are off of 8.5lbs of boost not 10 right?
Also if you put a 10lbs spring & retune would the numbers be around 700rwhp/tq to red line?
pincushin3819 is offline   Reply With Quote
Old 10-07-2014, 01:08 PM   #6
Unreal
Drives: 2006 Z06
~10.5-11psi to make 700rwhp. ~14ish to make 800rwhp.
Nick
Corvette Z06 -1200ish rwhp
Old 10-07-2014, 01:09 PM   #7
Fraxum
Fraxum's Avatar
Drives: a M6 LT1 ordered From Becky!!!
I knew ahead of time the boost might trail off. Kevin told me that with the 6 pound spring.
Can't wait to get the car back!. Thanks Ted. I was looking for flexible boost. I will not just be drag racing this car. I also want to track it and there I will be on the spring @ 6 pounds. Ted says my 6 pound power levels will be a bit softer. Exacly what I wanted as the turbos hit a little hard completely overwhelming the slippery when cold Goodyears and TC. Can't wait to wear them out.
But this extra power and the new clutch should get me closer to those pesky supercharged 5.0s. Hoping to get down to a 1.6 60' and low 11s. I can always add more power if I want. Easy with the Turbos.
Old 10-07-2014, 01:09 PM   #8
JANNETTYRACING
The Green line on the sheet is boost.
Red is Torque
Blue is Horsepower.
10psi at peak torque and 8.5 psi boost at peak hp.
Ted.
Old 10-07-2014, 01:10 PM   #9
JANNETTYRACING
Thanks for chiming in Nick,
Old 10-07-2014, 01:27 PM   #10
Fraxum
Fraxum's Avatar
I picked up 65 ft/lbs of peak torque over my 6 pound level. That should help push this big girl down the track.
Old 10-07-2014, 01:40 PM   #11
pincushin3819
Awesome can't wait for mine!
Old 10-07-2014, 02:16 PM   #12
z06-tt
Drives: 06 Z06 TT
i bet these two cars are closer in power than you think.....
z06-tt is offline   Reply With Quote
Old 10-07-2014, 05:46 PM   #13
Unreal
Drives: 2006 Z06
Maybe. Dynos are just tools.
The dynapak AGP uses has always shown 5-10rwhp of the dynojet down the street, so I don't think the numbers are far off.
Nick
Old 10-07-2014, 07:25 PM   #14
AGP Turbo
Drives: All things Turbocharged
Ted,
If you had more octane, how much more power do you think you could have made? 20ish?
As a rule of thumb, would you say that you gain 26-29whp per lb of boost?
27.5x6=165
So 6psi more and octane could make what, 185whp more?
AGP Turbo is offline   Reply With Quote
