Old 08-19-2009, 01:09 PM   #1
Gen5SSRS
Drives: Black 2010 1SS RS,
Auto Indexing Window Broken
I leave my windows open slightly because of the heat(approx. 1"). I came out, got in the car and my drivers window had closed itself. When I started the car, the info center told me to open and close my window. This went on for several days, and the indexing feature stopped working. . Not wanting to experience the joy of hoping my dealership could repair it without desimating my ride, I searched the threads and found one on a different problem, however the thread also explained how to reset the window module. With the key on roll the windowdown all the the way and hold the switch for 3 seconds, then roll up and hold switch for three seconds, repeat once more. I tried it and Tah Dah!!! Problem solved! If you have a similar problem try this. Thanx Camaro5 web site for saving me a trip to the dealer!!!
Gen5SSRS is offline   Reply With Quote
Old 08-19-2009, 02:09 PM   #2
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Glad that fixed your issue.
The steps to reset the windows is on page 1-16 of your owner's manual as well.
To program each front window,
follow these steps:
1. With the ignition in ACC/
ACCESSORY, ON/RUN,
or when Retained Accessory
Power (RAP) is active, close
all doors.
2. Press and hold the power
window switch until the window
is fully open.
3. Pull the power window switch up
until the window is fully closed.
4. Continue holding the switch up
for approximately two seconds
after the window is completely
closed.
The window is now reprogrammed.
Repeat the process for the other
windows.
rolnslo is offline   Reply With Quote
Old 08-20-2009, 12:20 AM   #3
bonnhew
Drives: Audi A5
are these windows all power? (i mean is it one touch down and one touch up?
bonnhew is offline   Reply With Quote
Old 08-20-2009, 11:59 AM   #4
rolnslo
Rolling along...
rolnslo's Avatar
Yes. One touch up and one touch down. Push the button again in the same direction while the window is moving and it will stop where it's at.
Old 08-20-2009, 02:48 PM   #5
Gen5SSRS
They are also 2 position switches. Press lightly and the window will stop when you let off the switch, up or down. Press the switch all the way and they will express up or down. The sunroof switch is the same way.
Old 08-20-2009, 06:25 PM   #6
bonnhew
Drives: Audi A5
thank u.. and it applies for both the windows right?
Old 08-20-2009, 08:05 PM   #7
Gen5SSRS
Yup
Old 09-12-2009, 05:00 PM   #8
RickRay
INJACC
RickRay's Avatar
Drives: 2010 CGM 2LT/RS AUTO
This just happened to me. I came on this site did a search and found you and I did what you said (once) and "Voila" it worked. Thanks
RickRay is offline   Reply With Quote
Old 09-12-2009, 05:05 PM   #9
JewelZ
Just Lovin' My Camaro!
JewelZ's Avatar
Drives: CGM 2LT/RS/AUTO
I love this feature, it always tripes my friends out!
CGM( GRAY 2 tone interior ) 2LT/RS/AUTO
NJHKKM $29,965.00 1EH37 1100 03/28/2009 AFF, B34, DCP, FE9, GBV, LLT, MX0, SGC, UQA, WRS, 2LT
50 YEARS FROM NOW, DON'T YOU WANNA BE ABLE TO LOOK BACK AND SAY YOU HAD THE GUTS TO GET INTO THE CAR!?!?
ORDER STATUS : 6000 as of 08.18.2009. VIN# 33,985!!! His name is 'GOLIATH'!!!
GOT MY CAR!!!! AND I LOVE IT!!!!
JewelZ is offline   Reply With Quote
Old 09-20-2009, 09:20 AM   #10
peel out
Peel Out
peel out's Avatar
Drives: 2010 2SS/RS Inferno Orange 6sp
THANKS!!!!
It just worked for me!!!!!!!!
peel out is offline   Reply With Quote
Old 09-22-2009, 03:50 PM   #11
deljaso
deljaso's Avatar
Drives: 2010 1LT/RS
Alright, I'm trying the manual method of reindexing the windows, but having problems.
It seems my driver side opens very little - about 1/8 inch or so, just barely clearing the molding, and the passenger side now opens about 3/4", a lot more than it used to.
I've tried following the procedure in the manual, opening the window all the way, then immediately closing it and holding up for 5 seconds after it's all the way up...
Tried with both half presses down and up, then full pressess on the switch down, then up. Tried with half press down, full pull up, and full press down and half press up.
Tried opening and closing the door before doing it. Tried it with key in ACC position, with key in full on position.
Is there some kind of trick to re-index the windows?
deljaso is offline   Reply With Quote
Old 09-24-2009, 04:39 PM   #12
Gen5SSRS
Try Pressing the switch all the way down. Once the window is down, continue holding switch for 2 seconds. Then roll window up, once up continue to hold switch 2 seconds. If this doesn't work, a trip to dealer may be necc.
Old 01-01-2010, 06:09 PM   #13
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
If you just push it part the way down it will only move until you release the button, from what I have heard when you reindex your window do not use the one touch feature, it won't work that way.. upi should be able to feel a detent in the switch where you go from manual to the one touch feature.
The Bird is the word!
Old 01-01-2010, 10:08 PM   #14
SPYDERMAN1
SPYDERMAN1's Avatar
Drives: 2010 2SS/RS L99 Victory Red
At last I thought I was the only one that had this issue. The dealer didint know how to fix it. Thanks everyone !!!!!!
SPYDERMAN1 is offline   Reply With Quote
GM offers sneak peek of Detroit auto show display KILLER74Z28 General Automotive + Other Cars Discussion 7 12-02-2013 06:01 PM
2006 TRAVERSE CITY AUTO CONFERENCE KILLER74Z28 Off-topic Discussions 2 09-18-2010 10:45 AM
R6P-If Window Stckr shows price increases-How do u get dealer 2 honor org MSRP price? renderinfo Camaro Price | Ordering | Tracking | Dealers Discussions 48 06-03-2009 12:03 PM
What is window indexing? coolbreeze 5th Gen Camaro SS LS LT General Discussions 24 05-31-2009 09:32 PM
Iacocca rips auto industry, warns: Don't sell Chrysler KILLER74Z28 General Automotive + Other Cars Discussion 6 04-14-2007 12:38 AM
