10-27-2014, 05:56 AM | #1 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Squared 1LE's wheels & tires setup for an automatic?
Who had upgraded their automatic SS Camaro towards the 1LE's squared wheels & tire set up? Tell us about your driving experience compared to your prior stock setup.
10-27-2014, 01:33 PM | #2 |
Drives: 2013 2SS/RS/1LE Join Date: Apr 2010
Unless you have considerable track time, you aren't likely to notice any difference. The "square setup" pertains to road coarse racing, not daily driving.
10-27-2014, 01:46 PM | #3 |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
I did it just for the fact I can rotate tires now instead of having 2 of same size.
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
10-27-2014, 07:04 PM | #4 |
Sometimes to take it to the track, I like a good handling car.
Are those 285's? |
10-27-2014, 07:05 PM | #5 |
Wheels sizes?
10-28-2014, 03:12 PM | #6 |
Sold car...
They are stock ss size rears on all 4 corners. 275/40 since I had the rears already I just got 2 new ones for the front. After this set I might wider.
Build Thread
10-28-2014, 06:12 PM | #7 |
BowtieBelle's SS
Drives: 2010 Camaro SS Join Date: Jan 2012
I have upgraded to 20x9 all around with 275/35s.
Performed well on the road course. Recently upgraded to FE4 LCA and ZL1 takeoff rear sway(1LE same). But haven't tracked with this combo yet. The lower profile of my tires rides slightly more harsh but I don't mind.
10-29-2014, 04:51 AM | #8 |
Anybody with 285/35R20 tires & 20x10 and/or 20x11 squared wheels? Driving performance feeling?
10-29-2014, 10:15 AM | #9 |
'It's an experiment'
I did 1LE upgrades but got the staggered ZL1 Polished wheels --
10-29-2014, 10:24 AM | #10 |
Square setup cuts down on the understeer. The car will turn more responsive with more tire upfront. Right now I am running 275/20 but will be moving to 285/35 with next tire change.
10-29-2014, 11:04 AM | #11 |
Drives: 2013 2LS Join Date: Jul 2013
I am running 295 30 19 on all 4 corners... car definitely corners much better, haven't met a turn I couldn't really power through yet.
Performance K&N Typhoon : Vmax Ported Throttle Body : Eibach Pro Kit : Flow Master Super 40's : MagnaFlow Resonated X-Pipe : GM Strut Tower Brace : FSP Tuned
Cosmetic Painted Bowties : Painted Tail Light Bezels : Blacked Out Side Markers : 19x10 Forgestar CF10's |
10-29-2014, 12:15 PM | #12 |
Track > 1/4 Mile
Going to a square set up on an SS won't be too noticeable for just daily driving. Widening the front tires is going to make it more responsive to the the road and will grip better. It will also make the car more neutral for the track, meaning it will take out some of the understeer.
11-01-2014, 01:23 PM | #13 |
Drives: 2010 Camaro 1SS/RS, 1973 Corvette Join Date: Dec 2011
I don't have the 1LE squared wheels set-up or an automatic...
I am currently running PFADT lowered springs and ZL Spec sways with their upgraded swaybar links. My wheel and tire combo are N'burgs 20x10 with Nitto INVO 275/40/20 on all 4s. I don't track my car, it is currently my DD. I have about 15k miles on this set-up. Unfortunately, I cannot say how the set-up performs on just the wheel/tire combo alone, as I did everything at once. What I can say is that this set-up is WAY better than the stock SS set-up. The car feels more neutral than before. I don't go crazy on the streets, but I noticed the car less roll and more grip on the curvy roads. If you have a Camaro (profile says you own a mustang), I would suggest ZL1/1LE style sways as well as a squared set-up. I am not sure if I like the idea of running a 285 tire on an 11" wheel. Personally, I'd find a 9" or 10" wheel that I liked with the correct offsets and run either a 275 or 285 tire. I went with the 275 tire as I felt that the difference between that and 285 was negligible. Also, it seemed that there were more tire options for the 275, and it was stock tire height. |
11-02-2014, 08:10 AM | #14 | |
