Old 10-27-2014, 07:53 AM   #1
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
killed the motor on a road course
OK, I was shifting all day long between 5000 & 5500 RPM. have done this many times.
I have a little over 20k miles on the current build. I use it as a daily driver with occasional "spirited" driving on the street and road races every couple of months.
the car back fired once, that then NOTHING. did a compression test Sunday morning.......#1 had 60psi and #2 had 0psi. not good at all.
I'm guessing a timing chain or cam gear failure............ we will take it apart next week. (I have the stock chain)
so, suggestions on a rebuild?
I'd like to keep NA, with around 500hp/torque
I've been reading about the "Cadillac race lifters", what are these and what advantage do they bring?
offloading at the house............
h018871 is offline   Reply With Quote
Old 10-27-2014, 02:57 PM   #2
Taco Time
Taco Time's Avatar
Drives: 2014 1SS
If you decide to buy a new motor PM me. I'll sell you my LS3. 3,700 miles on it.
If you're shooting for 500rwhp, a full bolt-on car w/ cam will get you there. (I have 471 right now.)
Taco's 2014 SS
Mods: 417 Stroker | CAI | Bo's PTB | Kooks LTs | Flowmaster Outlaw Catback | Night Fury Cam | Powerbond UDP | Apex Catch Can |PRC Ported Heads |FAST 102 Intake |Suspension Crap|
Built by J-Rod.
Taco Time is offline   Reply With Quote
Old 10-27-2014, 03:04 PM   #3
lsuguy
lsuguy's Avatar
Drives: 2011 2SS/RS
Caddy lifters have mixed reviews. I would research lifters over on ls1tech. Much more information over there on different brands.
I went with Morels when I had to rebuild my topend.
lsuguy is offline   Reply With Quote
Old 10-27-2014, 04:14 PM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
You'll need full bolt ons, heads, the right cam to hit over 500rwhp
62nalide is offline   Reply With Quote
Old 10-27-2014, 04:19 PM   #5
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
My cam (Night Fury from lethal) with heads on an LS3 plus boltons would get you to 500.
But especially for road racing, its not all in the hp numbers, my cam is an "all around" cam really, there might be a better one spec'd for road racing. Most of the shops on C5 can help you with a custom grind.
Old 10-27-2014, 04:54 PM   #6
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
no warranty?
tw78911sc is offline   Reply With Quote
Old 10-27-2014, 05:14 PM   #7
Pluto
Pluto's Avatar
Drives: 2013 Camaro 2SS/RS
Originally Posted by tw78911sc View Post
no warranty?
based on his sig probably not
2013 VR Camaro 2SS/RS LS3
Small, but effective mod list:
Roto-Fab Intake, TSP 2" Long tubes, TSP catless mids, MSD spark plug wires, stock catback, Elite Catch Can, APEX washer relocation and scoop, VMAX throttle body, Diablo InTune-Tuned by Matt@FSP, and a JacFab license plate bracket.
Pluto is offline   Reply With Quote
Old 10-27-2014, 05:31 PM   #8
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
no warranty?
drivetrain warranty is bye bye the moment you internally modify, such as a cam, LTH's and tune..
OP, did you replace all the internals in your cylinder heads with the cam and upgrade the oil pump?
alaskacamaro is offline   Reply With Quote
Old 10-27-2014, 05:38 PM   #9
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Dam another one down. WTF
1977and2010 is offline   Reply With Quote
Old 10-27-2014, 07:49 PM   #10
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
The track you were at, did it have any high bank turns? I've heard that can kill these motors with a stock pan.
There's a company, that I can't remember their name that sells baffling that can be put in the sump of the pan.
Sent from my SM-G900V using Tapatalk
Firefighter is offline   Reply With Quote
Old 10-27-2014, 07:57 PM   #11
tw78911sc
tw78911sc's Avatar
I will never add a cam
Old 10-27-2014, 07:59 PM   #12
SSSoon
SSSoon's Avatar
Drives: RY 2011 2SS A6
Really sorry to hear it.
I killed mine, but it was through melted cats:
http://www.camaro5.com/forums/showthread.php?t=375392
JusticePete is putting in an LS7. He has my original supercharged L99 and will be rebuilding it and reselling it. PM him for details
Dry sump LS7, cage, JPSS suspension, Wilwood brakes, fire suppression, ARH 3" headers/exhaust, Z/28 DSSV coilovers, Kirkey seats, TeamTech 6-point harnesses, 19" Forgeline GA3R, 325/30R19 Re11 tires, oil cooler, monster JPSS splitter/wickerbill, CAI, brake ducts.
SSSoon is offline   Reply With Quote
Old 10-27-2014, 10:02 PM   #13
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
no warranty?
For sure not from GM. Plus I have over 20k on the shop work.
Oh yeah, long gone
Did not change the valves but everything else, yes. I upgraded the oil pump, but not the chain. The engine is not apart yet but I'm convinced that the failure is unrelated to my mods. Basically a chain failure, probably should have upgraded it while apart. The thoughts at the time were 50/50 regarding upgrading the the chain. I went with the builder's recommendation at the time. Live and learn. KEEP IN MIND nothing is definitive at the moment. Tear down is in the morning. Also hindsight is 20/20.
No not really. The front straight is only 8 degrees, the oil pressure was good all day. The failure occurred on the back straight, which is flat.
Old 10-27-2014, 10:07 PM   #14
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
I Don't think that my issue is directly related to adding a cam. Although I'm sure that it was a contributing factor. I drove it harder and enjoyed it more.
Just my feelings......
