Old 10-27-2014, 02:09 PM   #1
jdarc1
jdarc1's Avatar
Drives: 2011 Camaro SS
Tires and rims for strip
2011 Camaro SS lowered.
Im looking for tires and rims for when I go to the track only.
I currently run P Zero 20 inch for the street but am looking for a wheel and tire setup that I can drive to the track. I want to change the tires and then drive to the track and remove when I get home later.
Does anyone know which rim will fit if I go to an 18 and which tire is best.
I was looking at MT's but not sure. Im more concerned about the rim fitting over the Brembo in the back.
Thanks
jdarc1 is offline   Reply With Quote
Old 10-27-2014, 02:45 PM   #2
Rcfiddy1
Sold car...
Rcfiddy1's Avatar
Drives: 2010 Rally Yellow 2SS/RS #37115
Weld makes them, or 17in vette rims with offset, all depends on money.
These are vette rims with MT Drag Radials. You will run into clearance issues being lowered and might need to swap out LCA to BMRs. I am lowered right now and still able to use the vette rims but had to tie back ebrake cable.
Welds
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust.
Rcfiddy1 is offline   Reply With Quote
Old 10-30-2014, 07:24 PM   #3
Scott 78
Scott 78's Avatar
Drives: 2014 SIM SS 6M
What can you tell me about those Weld wheels? Those are sexy.
Scott 78 is offline   Reply With Quote
