Old 11-04-2014, 04:23 PM   #1
Sean@Phastek
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
Thumbs up 2014 SEMA Show - GM Booth - LSA 6.2L Supercharged Engine & Specs
LSA 6.2L Supercharged Engine - Exciting Supercharged Performance
The LSA 6.2L supercharged engine delivers 556 Horsepower with refinement that is rare in the world of high performance. It is smooth, quiet and well-balanced, all while delivering the kind of immediate delivery of power that will take your breath away - and likely some of your car's tires!
Part Number: 19260164
Engine Type: LS-Series GenIV Small-Block V-8
Displacement (cu in): 376 cu in (6.2L)
Bore x Stroke (in): 4.065 x 3.622 (103.25 x 92mm)
Block (P/N 12623968): Cast-aluminum with 6-bolt, cross-drilled main caps
Crankshaft (P/N 12603616): Forged Steel with 8-bolt flange
Connecting Rods (P/N 12604857): Powdered metal
Pistons (P/N 12625119): Hypereutectic aluminum
Camshaft Type (P/N 12623064): Hydraulic Roller
Valve Lift (in): .492" intake / .480" exhaust
Camshaft Duration (@.050 in): 198* intake / 216* exhaust
Cylinder Heads (P/N 12626958): Aluminum L92-style port; as cast with 68cc chambers
Valve Size (in): 2.160 intake / 1.590 exhaust
Compression Ratio: 9.1:1
Rocker Arms (P/N 12569167 int): Investment-cast, roller trunnion
Rocker Arms (P/N 10214664 exh): investment-cast, roller trunnion
Rocker Arm Ratio: 1.7:1
Recommended Fuel: 92 octane
Maximum Recommended RPM: 6,600
Reluctor Wheel: 58x
Balanced: Internal
MSRP: $14,006.25
Sean@Phastek is offline   Reply With Quote
Old 11-05-2014, 03:16 AM   #2
ZL1-QTR
#00193
ZL1-QTR's Avatar
Drives: 14 ZL1 - 12 CT
ZL1-QTR is offline   Reply With Quote
Old 11-05-2014, 11:18 AM   #3
Wayniez
Drives: 69 Camaro with LSA
Does anyone have the single part number for the complete LSA4l85 connect and cruise crate drive train? I'm having trouble finding the part number for the whole kit together. I have this one but not the one needed CPSLSA4L85E
Thanks
Wayniez is offline   Reply With Quote
Old 11-05-2014, 11:20 AM   #4
JD-ZL1
JD-ZL1's Avatar
Drives: 2013 ZL1 M6
Send a message via Yahoo to JD-ZL1
Nice LSA, did someone put the top of the SC on backwards, the cooling lines on my 13 ZL1 LSA are on the front..
JD-ZL1 is offline   Reply With Quote
Old 11-05-2014, 01:38 PM   #5
Wayniez
The LSA crate is a Cadillac CTS V super charger lid. They come out the back.
Old 11-05-2014, 07:38 PM   #6
RubyCamaro
Jan
RubyCamaro's Avatar
Niiiiiiiiiiiiiiiiiiiiiiiiiiiiiice!
Old 11-05-2014, 09:35 PM   #7
Sean@Phastek
Thanks
The 2015 GM Performance Parts Catalog on pg 198 shows the LSA 6.2L as part number 19260164, the 4L85-E transmission as part number 19300175, and the transmission controller as part number 19302405. They do not list a single part number for the whole kit, since it uses different options/electronics depending on the application.
Technically, the CPSLSA4L85E - 2WD kit lists these part numbers (pg 215):
- Engine: 19260164
- Engine Control System: 19259293
- Automatic Transmission: 19300175
- Torque Converter: **24217235 or 19299806
- Transmission Control System: 19302410
- ** Flywheel Kit: **19125597
- Transmission Installation Kit: 19259119
** Torque Converter 24217235 requires the purchase of a flywheel kit
Old 11-05-2014, 09:41 PM   #8
Wayniez
Thank you we've been trying to find a single part number for it with no luck, now I know why.
Thanks again
Wayne
sema 2014 gm lsa engine
