12-06-2014, 07:40 PM | #1 |
Banned
Drives: Blown and inter cooled Join Date: Apr 2014
More boost out of a D1
I'm swapping out my cam and doing a LS3 conversion in 3 weeks, but I dont just want to stop there.. I want to get more boost out of my D1, but I'm having a hard time trying to figure out what pulleys I need to make 12 psi of boost. I'm at 8 psi right now with 8 rib pulleys, what all do I need to change to make 12 PSI? Thanks for any help
12-07-2014, 12:49 AM | #2 |
What pulleys are you running g now? I'm at 12psi with my NOVI 1500 and can and will go further when I swap my cam.
12-07-2014, 07:33 AM | #3 |
Drives: 2010 Camaro 2SS/RS,LS3 Join Date: Oct 2010
Before intalling my cam I was running a 4.15 pulley making 11psi. The cam dropped my boost to 9.3 psi @ 6300 rpm. I am running a 4" blower pulley now and it's making 11 pounds @ 6400 rpm. Just remember centrifugal supercharger continue making boost the higher the rpms.
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi Last edited by MANNYS2SS/RS; 12-07-2014 at 01:49 PM. |
12-10-2014, 06:40 AM | #4 |
Drives: '10 Camaro SS CGM Join Date: Dec 2013
I'm cammed with a d1 and my 4.25 pulley makes about 9.3psi @ 7000 rpms. On cold days it will make 10+ psi
12-10-2014, 08:25 AM | #5 |
Drives: Blown G8 GT Join Date: Apr 2010
I have a forged ls3 with a d1, stock crank pulley.
Blower is making 10lbs of boost with a 3.9 pulley at 6700rpms |
12-10-2014, 11:14 AM | #6 |
This go's to show you, how different set up differ in boost.
LS-3, ProCharger D1SC 665. rwhp /562. rwtq @ 9.3 psi |
07-30-2015, 11:06 PM | #7 |
Banned
Is that the pulley on the procharger you guys are talking about? Wherd did you find the part you needed and which pulley would i need to make around 11 psi? Currently have the pulley that came with the procharger kit
07-30-2015, 11:15 PM | #8 |
Sittin side ways
Drives: 2010 2SS/RS IOM Join Date: Nov 2012
With the race f series head units a 4.50 pulley is 13psi and 750rwhp.
850+hp club member
Procharger F1-A |
08-05-2015, 11:45 PM | #9 |
2010 transformer
Drives: 2010 ss camaro Join Date: Nov 2014
You can hit 700 rwhp on a p-1 so a d-1sc is good to 900rwhp on a lt-1
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
04-18-2016, 03:32 PM | #10 |
Drives: 2012 Camaro Ls3 Join Date: Apr 2012
Looking to make 10lbs or 700rwhp out of my d1sc. Have a boost cam, headers, and meth. Anybody know which pulley size would work?
Dynatech LT headers/Hi-flow cats/Jannetty rough idle blower cam/Full BMR suspension/3" magnaflow catback 442rwhp-410rwtq
04-18-2016, 04:02 PM | #11 |
Svt lol
Drives: 2011 ss inferno orange blown Join Date: Jan 2012
If you the exact HP and boost call Procharger and ask them what pulley you will need they know better than anyone. Those are the two things that are need to know when it comes to pulley size.
04-19-2016, 10:19 PM | #12 |
Sittin side ways
I found the max of the F1-A recently. 17psi and 900 wheel with the 4.250 pulley. Installed the 4.0 pulley and it picked up 50hp until 6k rpm and nosed over do to being over spun. If I could find a 4.125 12 rib it may make a bit more. We took off the filter and installed a bell mouth and lost 3rwhp.
850+hp club member
Procharger F1-A |
04-20-2016, 11:29 AM | #13 | |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
