Old 01-08-2015, 07:39 PM   #1
sick13ss1le
sick13ss1le's Avatar
Drives: 2013 2ss/rs 1le
Holley mid rise
Ok vendors or members who has the best price on the holley mid rise?
sick13ss1le is offline   Reply With Quote
Old 01-08-2015, 08:51 PM   #2
62nalide
62nalide's Avatar
Drives: 2013 SS
Jegs....
62nalide is offline   Reply With Quote
Old 01-08-2015, 09:45 PM   #3
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
They don't fit the camaro. Hood and cowling clearance issues.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 01-08-2015, 10:54 PM   #4
62nalide
62nalide's Avatar
Drives: 2013 SS
Mid rise fit with zero issues
Old 01-08-2015, 11:39 PM   #5
RaiderSS
RaiderSS's Avatar
Drives: 2010 Camaro SS2 DeadBLK
Sorry but that's not true.... You can get it direct from Holley for same or less than jegs, will require cowl notch, loss of passenger wiper linkage and aftermarket hood
RaiderSS is offline   Reply With Quote
Old 01-09-2015, 01:03 AM   #6
62nalide
62nalide's Avatar
Drives: 2013 SS
Well guess I've been told wrong then.
Old 01-09-2015, 08:47 AM   #7
qongcunot
Drives: camaro
We can look after you on one of these sir at a great price
qongcunot is offline   Reply With Quote
Old 01-09-2015, 05:19 PM   #8
sick13ss1le
i know it doesnt fit im willing to do a little cutting steve ill send you a pm
Old 01-24-2015, 02:08 PM   #9
DMC_90
DMC_90's Avatar
Drives: 2011 Hellion Camaro SS
How would the mid rise compare to the high ram in a boosted setup
2011 2ss L99, 61mm hellion twin turbo, borla atak full cat back, Bmr suspension and 1.25 lowering springs, ls2 92mm tb, Nitto NT05R radials, 2step, Hurst line lock, 564 rwhp 567 rwtq @ 7psi
DMC_90 is offline   Reply With Quote
Old 01-24-2015, 05:54 PM   #10
sick13ss1le
mid rise out performed the high rise in the lower rpm but the high rise out performs the mid rise at higher rpm
