01-09-2015, 04:16 PM | #1 |
Drives: 2010 camaro ss/rs Join Date: Dec 2009
Questions on M6 to a 4L80E swap?
Well fellas my M6 tranny is on its last leg and that puts me in the market for a strong transmission, specifically the 4L80E. I wanting to know on the job itself. How difficult is it? What changes need to be made. What challenges were you faced with? Any and all info will be much appreciated. Pics would be VERY appreciated also. Diet coke made a thread a while back but all pics have been deleted. Another thing that concerns me is cost. Well I'm all ears thanks in advanced.
2010 SS @gt_klr Built by Jrod Tuned by Matt Sorian LSX 434 by HKE Dragon Slayer, Callies ultra rods, Wiseco Coated Pistons, Mast 285cc LS7 Heads ProCharger F1-X Nitrous Outlet Direct Port Fore Innovations Triple Pump on E85 Alky Control Meth Injection ProEFI ECU Stainless Works 2" Headers with Corsa 3" Exhaust RPM 4l80e with Jakes Transbrake BMR Everything with 15" Conversion Zl1 Front Brakes & Carlyle Racing Rear Brake Kit Weld Wheels |
01-09-2015, 04:24 PM | #2 |
Treasure Coast Camaro 5
Diet was on this morning so try pm him also Mr Nasty had a 6L but put a 4L in using Jakes parts and been a beast!
01-10-2015, 06:46 PM | #3 |
Drives: 2010 Camaro SS Join Date: Aug 2013
Diet's pics are gone for good. I am in the middle of the swap right now, I have IM'd back and forth with Diet a few times. so far, things are pretty straightforward. My progress is pretty slow though! I am almost done rebuilding the 4L80E. I have the trans cooler in and the fan wired up. I also have the console out and the seats out.
If you have any questions, let me know! |
01-11-2015, 03:47 AM | #4 | |
01-14-2015, 03:23 PM | #5 |
What a dilemma! ...... So to those who made the change to the 4l80E. Do you have any regrets? I imagine dig racing is awesome but how is from a roll? Really need some help from guys who have made the change? What are the pros and cons?
01-14-2015, 04:43 PM | #6 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
Get a triple disc lockup converter and lockup wot. You can have your roll races too. It would be the same top speed as your 4th gear now.
01-14-2015, 05:58 PM | #7 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
You wont regret it. Its not too difficult to make the swap either and get you a good trans controller like the PTS 2000.
01-17-2015, 12:23 PM | #8 |
Well I finally committed to the 4l80E swap. I called up RPM and placed my order. It will take a few weeks to receive it.
01-17-2015, 12:37 PM | #9 |
Good deal! I test fit mine for the first time yesterday. You definitely need to cut the frame. Ill add a pic later if you'd like.
01-17-2015, 07:10 PM | #10 |
That would be great. Keep me posted!
01-17-2015, 07:15 PM | #11 |
Drives: Camaro Join Date: Aug 2014
I would just wire in a t42 trans controller so you have factory control.
01-18-2015, 10:43 AM | #12 |
Just jump the wiring and make it full manual.
01-27-2015, 10:29 PM | #13 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
I agree. Manual valve body is the only way to go especially if you are FI.
01-28-2015, 02:49 PM | #14 |
I drive on the interstate too much for a MV. They create a touch more heat than a stock one up on the hwy
