Old 01-13-2015, 07:50 PM   #1
didon1972
Drives: 2014 Z28, 1969 Camaro SS
Redline Motorsports Z28 Package (video)
Just got back my Z28 with the cam & exhaust package from redline motorsports.. Sounds like a different beast.
didon1972 is offline   Reply With Quote
Old 01-13-2015, 08:54 PM   #2
Mikebrinda
Mikebrinda's Avatar
Drives: Ferrari F430 Spider F1 Azzurro Arge
Video locked as private. Will not play.
Mikebrinda is offline   Reply With Quote
Old 01-13-2015, 09:19 PM   #3
silver surfer ZL1
silver surfer ZL1's Avatar
Drives: 2013 silver ZL1
What else was done? Those are impressive numbers
2015 Z28 Black #16 600rwhp N/A
Colorado speed and performance build: hand ported heads, titanium valves, hand ported throttle body,fast lsxr intake, custom cut lunati cam, lunati push rods, fm high performance lifters, dual beehive springs + titanium retainers, trunnions upgrade, ARH headers + x pipe, fast fuel rails, c5r timing chain, katech high volume oil pump, ati underdrive pulley, Taylor wires.
Sold---2013 ZL1 M6 Silver Ice Metallic: 767 rwhp
silver surfer ZL1 is offline   Reply With Quote
Old 01-14-2015, 06:28 PM   #4
didon1972
Just the cam, American Racing long tube headers, high flow cats, stock mufflers & tune. Made just under 600 hp at wheels. Not too much needed to wake this ls7 up a bit. Thinking about changing out mufflers next. Might as well go stainless all the way..
Old 01-14-2015, 08:18 PM   #5
LT4SS1997
Drives: 2014 z28,2015 Z06, 2017 ZL1
What cam was installed?
LT4SS1997 is offline   Reply With Quote
Old 01-14-2015, 09:31 PM   #6
didon1972
It is a comp cams .644/.648-inch lift and 238/250 duration at 0.050 with a 114 LSA.
Stock cam is 0.593/0.589-inch lift and 210/230 duration.
Old 01-17-2015, 08:36 AM   #7
silver surfer ZL1
600 at the wheels with just a cam and headers????? Im sorry but thats very hard to believe.
Heads cam intake header cars don't even make that kind of power...
can you post a dyno sheet please
Old 01-17-2015, 10:51 AM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
So how had these mods helped your track time?
Post some numbers please. Thx
Mods:
Old 01-17-2015, 12:18 PM   #9
TonyNDeb
Drives: Candy
Dyno sheet is posted at the end of the vid. Not sure if that's wheel or crank hp, but it clearly says 579.
Don't know how they helped track times, but they helped my ears... Sweet music.
TonyNDeb is offline   Reply With Quote
Old 01-17-2015, 12:22 PM   #10
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
Dyno sheet says 579 hp/521 tq at the wheels. I don't know why you guys find that hard to believe, look at other cam only LS7's in C6Z's and they make the same numbers. Plus it's on a dynojet..
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles |
Tuned by Ryne @ CMS E85: 734rwhp/636rwtq (mustang dyno)
Jeff_SS is online now   Reply With Quote
Old 01-18-2015, 10:46 AM   #11
didon1972
Obviously they aren't too familiar with the Ls7 if they can't get those numbers with all that work.
Here's the write up in superchevy:
http://www.superchevy.com/how-to/eng...-from-redline/
