Old 08-27-2009, 12:54 AM   #1
turboed2000
Drives: 2010 Custom Turbo
ProCharger + cam + methanol results = ~700hp
As featured on homepage.
Here are the results from my N/A cam pro charger set up on 91oct. It was out of fuel and the second run we tried to use meth to help but it didnt. We were down to 18 psi fuel pressure hanging the 80# injectors open untill there was no more. The afr is on the money these were just some trial and error.
Tomorrow we are installing another fuel pump and controll module. Also a cam swap and hit 700 plus on 10psi.
turboed2000 is offline   Reply With Quote
Old 08-27-2009, 01:29 PM   #2
rayhawk
rayhawk's Avatar
Drives: Cadillac CTS-V
Nice setup, keep us updated on the results.
rayhawk is offline   Reply With Quote
Old 08-27-2009, 02:01 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
D@MN! What cam?
Great results!
'20 ZL1 Black "Fury"
Old 08-27-2009, 11:59 PM   #4
the rich dude
Drives: Getting 2010 Camaro
wow, some killer power. what is your cam? Headers? Exaust??
is that the P1SC blower and stock pulley?
I take it that is a LS3?
love to learn more about your car, although your setup may be too much for the everyday driving I want to do with my car
the rich dude is offline   Reply With Quote
Old 08-28-2009, 01:59 AM   #5
turboed2000
The car has a D1 on it. The headers are kooks 1-7/8 with full custom 3" exhaust. The cam is a mild N/A cam. Daily drives lock a stock car. The blower is so quiet u forget its on the car. Just put 91 in it and drive. I just finished the twin intank pump set up. It holds pressure now. Got to get it on the dyno again. There is no way an average Joe will do the twin intank set up. We are going to work on a bolt in kit this weekend.
Old 08-28-2009, 02:00 AM   #6
turboed2000
Sorry the pulley is a 3.85 and stock lower. It was a 102* and no cool down on all the runs.
Old 08-28-2009, 06:18 AM   #7
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
stock short block?
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 08-28-2009, 12:14 PM   #8
Codefive
Codefive's Avatar
Drives: 1000HP 2010 SSRS
What did you use? ZO6 stuff or something else? Did you have to get crazy in the tune to make this work? What other restrictions did you run into in terms of tuning? I am in the process of putting a twin turboed 427 in my 2010 and want to know what I may be up against.
Thanks in advance!
David
Codefive is offline   Reply With Quote
Old 08-28-2009, 12:46 PM   #9
turboed2000
It is the stock bottom end. There is nothing as fare as fuel system that is compatible. I have figured a way to make two pumps work and will test it today on the dyno. Tested it on the street and all was good. Its a little expensive but a lot cheaper than doing a full fuel system. Tuning is easy once you get the fuel.
Old 08-28-2009, 01:19 PM   #10
1BadaSS
Drives: 2010 CGM 2SS 6spd
That's nasty power there! Let me ask you, did you get the tuner procharger kit? If so, what size injectors are you running ect... I'm planning on going with the D1 and already have kooks 1 7/8 LT's and full 3" exhaust. I might go with a kenne bell boost a pump and 60lb injectors. I just wanna know what your running so I have a better idea of what I need to achieve results similar to yours. I don't wanna have to go to 2 fuel pumps however.
1BadaSS is offline   Reply With Quote
Old 08-29-2009, 06:04 PM   #11
turboed2000
yes its a tuner kit. I run ford 80# injectors. A boost a pump is good but will not help with this much power. The 2 pumps held perfect pressure last night on the Dyno. We are going to do a little more testing and then shoot for 700rwhp.
Old 08-29-2009, 07:40 PM   #12
1BadaSS
Well 700 whp is pushing it on the stock block. I'm looking to get close to 600 without a camshaft. What kind of cam do you have in it right now?
Old 08-29-2009, 09:27 PM   #13
old motorhead
Drives: Maggie blown LS3 vette
Probably get there without a cam. But, with a mild blower cam, you can get there with less boost, more timing, and no meth.
old motorhead is offline   Reply With Quote
Old 08-30-2009, 01:42 PM   #14
turboed2000
Its a comp custom grind that was spec. for my nitrous set up. I have a smaller blower cam but this one works so I may just leave it. Every one says 700 is to much on a stock short block. My car makes over 700 and my c-6 made over 700 for 2yrs and is still alive and well. May be its the tune they run. We run ritch afr and conservative tune. Most people run on the ragged edge to make peak power.
Cam basics CamaroSpike23 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 76 11-25-2015 11:42 AM
TVS 2300 / Supercharger CAM Results and thoughts Crowley Forced Induction - V8 36 08-27-2009 08:28 PM
Initial Results for my TVS / Blower cam install at ADM (586rwhp/577rwtq) Crowley Forced Induction - V8 33 08-20-2009 01:08 PM
TVS 2300 / Supercharger CAM Results and thoughts (different pulleys) Crowley USA - Texas 2 08-20-2009 12:28 PM
BUDWEISER SHOOTOUT LINE UP CamaroScotty General Automotive + Other Cars Discussion 22 02-07-2009 07:03 PM
