02-08-2015, 07:33 PM | #1 |
Drives: 2013 1SS RS 1LE NPP ADM LSA CON Join Date: Mar 2014
Another ADM, LS3 to LSA Build
Placed my order with ADM today. I can see some long nights ahead of me to get my car ready before the spring.
I still need to locate an intake, blower and base tune. If anyone has any good leads please PM me. My order: LSA Supercharger Dampner NGK TR7 ADM FPCM 2.5" LSA 2 Piece Pulley 65lb Injectors ADM LSA Install Kit W/O Supercharger My current car setup: 1SS 1LE NPP Kooks Headers w High Flow Cats K&N CAI Goal: 550 to 600 RWHP reliable car. Think I can meet my goal without a CAM? Lots more pics to come... |
02-08-2015, 09:09 PM | #2 |
Drives: 2011 2SS Join Date: Jan 2013
I just put down 551rwhp on the pump gas tune and 8 pounds of boost through an auto. I bet you do fine.
02-08-2015, 10:00 PM | #3 |
Awesome choice. You will be really pleased with the kit. Is there a reason for not doing a cam? An ls9 cam would help you hit your goal and run smooth yet. They are amazingly cheap. Adm uses them all the time in forced induction engines. The dampener is not a needed part. I would save the money and get an ls9 cam instead. With a stock cam and a 2.5 pulley you will make way too much boost. With the ls9 you will make less boost and more power and less heat. If you dont mind some cam thump go with a stage 3 cam. My car drives great and sounds awesome. I would call andy and talk to him on your goals. He is a great guy to talk to and has endless knowledge on what you want. He can give you comparisons of past builds. Hope this helps. Good luck on your build. Your heading in the right direction.
02-09-2015, 04:06 AM | #4 |
Drives: 2014 Red Hot 1SS M6 Join Date: Jun 2014
Thinking of doing the same thing. I want to spend less than $5k if that's possible. You can get the blower and lid for $1k or less if you look on ebay and this forum.
2014 Red Hot 1SS M6 aka Bernadette
ADM LSA Conversion, ADM FPCM, 2.75 pulley, ZL1 fuel pump, FAST 89lb injectors, NGK TR7IX, Roto-fab intake, Stainless Power 1 7/8" long tubes w/o cats, NPP, Elite catch can, LG G5 Coilovers, Hurst shifter, GM strut tower brace, 1LE steering wheel, MRR 228 wheels, Nitto Invo 275/315. Tuned by Lashway Motorsports 575rwhp 528rwtq. |
02-09-2015, 05:57 AM | #5 |
Lid comes in the install kit from adm. All you need is the blower itself.
02-09-2015, 07:27 AM | #6 |
Drives: Autobot Join Date: Jan 2015
What PSI and HP do these kits max out at? Pump gas.. Not meth or E85 tunes?
02-09-2015, 09:34 AM | #7 |
Hmmm. Good to know!
02-09-2015, 11:36 AM | #8 |
Drives: Anything I want Join Date: Oct 2008
02-09-2015, 12:49 PM | #9 |
Drives: 2010 camaro ss Join Date: Jun 2010
Will the nightfury cam work with this LSA Sc ?
02-09-2015, 01:12 PM | #10 |
'It's an experiment'
You'll want a blower friendly cam. My VVT SS1 is better suited for NA. I'll be replacing mine with a BTR spec stage 1 Supercharger cam...
Andy knows what works with this kit... -Don Last edited by hammdo; 02-09-2015 at 04:22 PM. |
02-09-2015, 01:14 PM | #11 | |
-Don |
02-09-2015, 02:09 PM | #12 |
I thought the NF was blower friendly
02-09-2015, 04:19 PM | #13 |
Drives: 2011 Camaro SS/M6 Join Date: Dec 2013
I'm running the Night Fury Cam with a PD blower and it works great. My tuner was pretty impressed considering it is a true NA cam. Is there more efficient options, yes but if it's in there already I wouldn't go out of my way to replace.
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
02-09-2015, 04:32 PM | #14 |
That's what I wanted to hear
