02-13-2015, 09:45 PM | #1 |
Drives: 2010 Camaro SS Join Date: Jan 2015
FIC injectors??
I know everybody here says ID850s! I get that they are the best, but I am looking for any input from people that have used FIC injectors (not the ebay junk)
How well do they tune? How is your drivability? |
02-13-2015, 09:58 PM | #2 |
Fine and great. I have FIC 850cc
02-13-2015, 10:03 PM | #3 |
I've used 60lb,80lb and now 95lb FIC in my car with no problems. Just using the data they come with injectors work great. Just make sure it's Fuel Injector connection. There's another company called Fuel Injector Clinic, Not the same company.
http://fuelinjectorconnection.com/sh...gory&cat_id=33 |
02-13-2015, 10:37 PM | #4 |
Yeah there's two FICs but one is only slightly better than the other by what I've gathered.
02-13-2015, 10:45 PM | #5 |
Good info, I didn't know there were two!
02-13-2015, 10:53 PM | #6 |
Boosted Moderator
I've used three different sets of Fuel Injector Connection injectors, and just ordered my 4th set... The injectors we just ordered are a low impedance 225 lb per hour injector... These are a Siemens injector... Rather than a Bosch...
The only reason I've changed injectors is growing the power...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
02-13-2015, 11:05 PM | #7 |
How are they for low rpm tuning?
02-14-2015, 09:26 AM | #8 |
Drives: none Join Date: Aug 2011
Typically fine, but there are people who claim to have had low pw issues on FIC's that were cured by ID's.
02-14-2015, 09:46 AM | #9 |
02-14-2015, 09:49 AM | #10 |
After looking at the website I saw this:
"Each injector set is 100% matched. They have OUR MACHINE SS SINGLE TIP discharge plate for the best atomization possible, The deadtimes are provided with the set as well as the proper orings for a drop in installation. These are Bosch injectors and are brand new These are modified from the 2009 ZR1 stock injector" Am I correct to assume these are drilled out to flow more? I thought that is what causes the inconsistency? |
02-14-2015, 10:10 AM | #11 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
IDs are very good injectors, but its not that ID are the best, its they provide calibration tables for your tune.
PM me for pricing on Infinity Injectors. Infinity Injectors in a nutshell: These 88lb injectors flow 88 lb/hr at 58 psi of fuel pressure. They are late model, short-style set up injectors with EV6 connections. They have an excellent spray pattern and meet or exceed the original manufacturer’s quality standards. Each set of injectors come with our copy/paste data for your actual ECM to make your job quick and easy! Yes different ECMs/Car use different data.
02-14-2015, 01:59 PM | #12 | |
02-15-2015, 06:47 PM | #13 |
Drives: 2013 Triple Black ZL1 / 2006 TB SS Join Date: Feb 2011
^^^ Exactly right. I've tuned ID's and FIC's and they're both easy to tune. FIC also provides complete injector data. The FIC will idle just fine.
