02-13-2015, 11:27 PM | #1 |
Drives: 2013 1LE Join Date: Feb 2012
Engine choices
Everyone assumes the SS will be a V8. And the base model will get a V6 or Turbo 4 option. What if the V6 or even basic V8 was replaced with the ATS-V power plant? A TT-V6. Possibly de-tuned to 400 hp to replace the V6. Or tuned up closer to 500 hp to replace the base V8. The alpha platform is already setup to handle it and clearly doesn't have clearance issues the Stingray had when considering turbo power. How would that go over with enthusiasts?
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013 |
02-13-2015, 11:53 PM | #2 |
Drives: 18 1SS 1LE Summit White Join Date: Jan 2015
But the information on GMAuthority does suggest that. It says V8 (LT1)
http://gmauthority.com/blog/gm/chevr...-camaro/#tab-3 |
02-14-2015, 12:13 AM | #3 | |
Drives: RS Join Date: Jan 2013
I doubt we will see the TT-V6 in the Camaro. Maybe a Turbo 4 if they can build one with at least as much HP as the one in the Mustang. All things being equal I would prefer the V8 to the TT-V6. |
02-14-2015, 12:53 AM | #4 |
Drives: 2008 Malibu V6 Join Date: Mar 2008
02-14-2015, 12:55 AM | #5 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
There's no point. The LF4 doesn't make more than the LT1.
02-14-2015, 03:08 AM | #6 |
Drives: 2016 F150 Join Date: May 2014
I had a dream a week or so ago that the Camaro gets the turbo 6. I guess I've been on here too much lately. Not going to happen though, at least not for now.
02-14-2015, 06:21 AM | #7 |
Drives: 2016 Camaro 2SS M6 Join Date: Aug 2014
We've already heard from multiple videos that it is in fact a V8, and most likely the LT1 as the others have said.
02-14-2015, 08:38 AM | #8 |
Drives: 2020 LT1 Black Join Date: May 2013
Would it be heresy to have a performance option somewhere between the V6 and V8?
I'd rather have a TTV6 for $28k than a 2LT with a damn moonroof. |
02-14-2015, 08:59 AM | #9 |
Drives: A few Camaros Join Date: Dec 2012
02-14-2015, 09:16 AM | #10 |
Drives: Coupeless :( Join Date: Jan 2015
I would imagine that the TTV6 is at least as expensive to manufacture as the V8, and the reality is that its probably more expensive.
You also have to factor in that its performance is very similar to the V8, so even if it were possible to offer a TTV6 for $28k, GM would never do it, because they would be cannibalizing the V8, which they presumably make more money on. |
02-14-2015, 09:51 AM | #11 | |
1. Worse mileage than the V6 and would require premium fuel. The V6 is the power seller and losing those benefits would seriously jeopardize sales. 2. The engine is as costly to build as an LT1 and weights the same. As far as replacing the V8. That's a definite no.
Current: '17 2SS Hyper Blue, A8, MRC, NPP
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
02-14-2015, 10:11 AM | #12 |
Romans10:9-13
Drives: /\yes, this is me/\ Join Date: Nov 2008
I think people are going to be very shocked at the options we have when ordering the new camaro, both in engine choices and trim levels ( 1LE, ZL1, SS, etc) the 1st year
02-14-2015, 10:26 AM | #13 |
There are no current plans for TTV6 in the Camaro.
02-14-2015, 12:51 PM | #14 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
I see the LT1 has AFM which I hated on my L99... I had to use a Range to delete it. Now I have the V8 I wanted. So how will that be handled? Can it be disabled with a setting to avoid an aftermarket fix again? This time I assume it will affect manual trans cars too.
Cam |
