02-14-2015, 04:38 PM | #1 |
Front Tire Width
So after a lot of searching (I swear), I have to ask...do 305's fit on the front of a ZL1? I'm looking at Finspeed 19" with 305's all around if they'll fit. Does this require more than -1.4 camber?
Would you recommend 11" wheels or 10.5"? Recommended offset front and rear? What do I need to get to -2 camber? 2014 ZL1 |
02-14-2015, 04:52 PM | #2 |
Track > 1/4 Mile
Guess I'll be your Guinea Pig. I just ordered 19x10.5 rims for a square set up. Tires going on it are 305x30x19 I'm currently at -2.0 degree of camber. I should have it ready for a test in about two weeks. First actual track event will be March 15. The wheel and tire supposedly fits, but not sure with that kind of camber..
11" would be better than 10.5 but unfortunately I didn't have that option in the wheels I got. Only offset option I had was +27, not ideal but will work. OEM offset is like +23 front +43 rear or something very close to that.
02-14-2015, 04:58 PM | #3 | |
It should fit easier with that camber correct? I took the car to Bumberas but they said they could only get like -1.3 camber. What's it take to get -2 camber? 2014 ZL1 |
02-14-2015, 05:01 PM | #4 | |
Track > 1/4 Mile
Technically I'm at -1.8/1.9 but I didn't do anything special. Not sure why you can't go more aggressive, but depending on how much you drive this (aside from track duty) you may be thankful. Inside of my tires wear pretty quickly. Thankfully I don't daily it.
02-14-2015, 05:44 PM | #5 |
Bumberas had great customer service but I wasn't blown away with their knowledge of the camaro so I'm not sure about the camber either...they said I needed the eccentric camber bolt to get more camber and I didn't believe that was right.
I don't daily drive either so I'm not too concerned with more camber. 2014 ZL1 |
02-15-2015, 01:48 AM | #6 |
Drives: '16 C7 Z51 Join Date: May 2012
19x11 or even bigger at the rear is pretty easy. You can actually get 19x11 up front, but then you need to really push for a low offset, and the tire/wheel will stick out of your fenders.
I initially ordered Forgestars 19x11 all around with +17 offset up front (their lowest) and +40 offset at the rear, but then learned that these wheels are not strong enough for heavy track duty, so switched to Z/28 OEM wheels. Z/28 wheels are +11 up front, and stick out quite a bit. I ended up getting the Z/28 fender extensions as well to keep them within the wheel wells, or sticky tires can destroy your paint in short order at the track. 19x10.5 +27 is very very close to the limit. It should have very little clearance left with the suspension. It will work, but I'd rather recommend APEX ARC-8 19x10.5 ET22 wheels for a little bit more clearance. I have these wheels with Hankook R-S3s for street use:
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD Last edited by X25; 02-15-2015 at 01:58 AM. |
02-15-2015, 11:00 AM | #7 | |
Drives: 62 Chevy & 2021 1SS/1LE manual Join Date: Aug 2010
i have the same setup baylor. i have the same brand, size and offset of wheels you have. i put the SUV studs and a good 5mm spacer in front, i dont have my negative camber maxed out and the tire is about 8mm from rubbing. this is with 295 30 19s that dont hang over the rim. it may work with no spacer and the camber maxed out but with the 305s hanging over the rims a little i bet it would be too close or even rubbing. |
02-15-2015, 11:08 AM | #8 |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS Manual Join Date: Mar 2010
I installed the 10" ZL1 replicas with 305\35-20's up front yesterday. My 2010 has Phadt coilovers and I had to use 8mm spacers and longer wheel studs to get everything to fit. The clearance looks good even on my lowered car with a camber of -1.8. I hope to take it for an aggressive test drive later today and will post my results. I have 11" ZL1 replicas for the back and planning on mounting 315's back there. I will try the front 10" wheels on my stock 2014 when I get a chance and report back on that fitment. The font offset is 23 if i remember correctly and the clearance to my coil over is very narrow. I need to get some feeler gauges in there to see, my guess is I should have at least 4 or 5mm clearance which should be fine since all of the tire twist happens at the bottom.
MagnaCharger TVS-2300 550rwhp 540 rwt and a radical suspension under the car.
02-20-2015, 08:50 PM | #9 | |
Track > 1/4 Mile
02-21-2015, 07:47 AM | #10 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
In my experience, an 8 mm tire to strut gap is a huge, almost wasteful amount of clearance, and even half that is still a lot. The wheel shouldn't need more than 1, maybe 1.5 mm clearance anywhere. Tire width vs wheel width probably has a small effect, 305/xx on 10.5" a wheel probably needs a little more static clearance than the 1.3-ish mm I've got with 285/xx on 11's. Norm Last edited by Norm Peterson; 02-21-2015 at 08:02 AM. |
02-21-2015, 07:56 AM | #11 | |
Track > 1/4 Mile
02-21-2015, 08:13 AM | #12 |
Sounds very close. I can't see 5 mm not working, but I'll bet you could get away with maybe 3 . . .
Incidentally, when you're fitting things really close you'll want to try all possible combinations of wheels at corners. Wheel offsets/backspacing, struts, and even tires have dimensional tolerances that don't have to stack up the same way in all combinations. Looks like I slipped an edit in my previous post after this last post of yours landed. Norm |
02-21-2015, 09:09 AM | #13 |
here are the spacers i got i think. i havent actually measured the gap at rest. its less than it was when it was jacked up. i have room to throw more negative camber in if i want/need to. this square setup made my car a different car. i had got it all jacked up last winter and took almost all season to get it back right. dont mix and match tire compounds, it made my car a death trap and it took my dumb butt half a season to figure it out. i was trying to save some money but you cant really skimp on tires and brakes im finding.
http://www.ebay.com/itm/5MM-5X120MM-...7f26b0&vxp=mtr |
02-21-2015, 10:42 AM | #14 | |
I think everybody who is interested in improving the cornering and handling of their cars needs to personally live through this sort of thing at least once (safely, please). It is entirely possible to make even an understeerish FWD car scary-loose at only moderate speeds and cornering g's by changing just two tires and touching nothing else. Norm |
