02-21-2015, 08:42 PM | #1 |
Steering Wheel Noise
I just bought a 2011 Camaro 2SS, and I have noticed there is a faint steering wheel noise when turning the steering wheel. Kinda sounds like the noise a squeegee makes. Anyone else have this noise, and is it normal?
02-21-2015, 09:10 PM | #2 | |
Just video recorded the noise. You can hear it at the 5 second mark.
02-21-2015, 09:48 PM | #3 |
Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
Video is marked private
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
02-21-2015, 10:05 PM | #4 |
02-22-2015, 12:44 AM | #5 |
Drives: 2015 Redhot 1LE Join Date: Feb 2013
had this in my v6 its the power steering fluid pump, it need replacing
02-22-2015, 11:45 AM | #6 |
Drives: One of the baddest handling Gen 5s Join Date: Feb 2011
02-22-2015, 02:52 PM | #7 |
Vrrrm.
Drives: 2011 2SS/RS LS3 Join Date: Jun 2013
If you have headers they are rubbing the steering shaft boot
You can pop the hood and see for yourself
02-23-2015, 04:16 PM | #8 |
02-23-2015, 04:57 PM | #9 |
Drives: Camaro SS/RS inferno red interior Join Date: Mar 2012
Hey dude I had the same problem and went to the dealership and they told me to come back when I have a real problem and not some just faint noise on a 25k mile car. I really did not like their answer but I have just come to deal with it. I guess it is better than they don't rip my car apart just for some little noise which doesn't hurt anything. But that is just my 2 cents on the matter
02-23-2015, 06:26 PM | #10 | |
02-23-2015, 08:00 PM | #11 |
Drives: 2012 SS Red w/ black rally stripes Join Date: Jan 2015
There is an air bag part inside the steering column, technicians call it a clock spring. It is a rotating connection. That would be my guess. I can hear it in my car if it is quiet and the radio and A/C are off. I'm not concerned about mine.
2012 SS Camaro, Victory Red w/black rally stripes, SLP front splitter, ZL1 Rocker panels, ZL1 Add-ons Stealth Wickerbill, L99, Magnuson Heartbeat supercharger, 65 lb. injectors, 87 mm pulley, ZL1 fuel pump, ADM FPCM,1 7/8 Texas Speed long tube headers, v-max ported throttle body, Rotofab cold air intake with Apex scoop, Apex catch can, MSD plug wires, AEM AFR and Boost gauges, GPI SS1 VVT Cam, HP tuners with remote tune by Ryan at GPI, Solo axleback exhaust w/j pipes and stock resonator.
02-23-2015, 09:53 PM | #12 |
02-23-2015, 10:20 PM | #13 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Mine has a slight squeegee squeak when turning the wheel counter-clockwise and traveling slowly. It's mostly noticeable when manuvering through parking lots.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
02-23-2015, 11:35 PM | #14 |
