Old 03-03-2015, 06:58 PM   #1
forzasteve
forzasteve's Avatar
Drives: Love any sports cars
Forza Dual Mode Exhaust Controller
Hi Camaro5 ...
We are a new sponsor here at Camaro5 and have just announced the Dual Mode Exhaust Controller for Camaro's and Corvette's with the Dual Mode Exhaust (NPP) option.
With this controller, you take back control of the dual mode exhaust on your Camaro. You can select to have the exhaust bypass valves open all the time or closed to quite things down. Your choice.
The Forza Dual Mode Exhaust Controller is an evolution of a controller that was originally developed for exotic sports cars such as Ferrari and Lamborghini. After a few months of development, the Forza Controllerfor Camaro and Corvette is ready.
This is not a copy-cat product. It was completely designed as an evolution of another exhaust controller that we have been manufacturing for over a year. From the onset, we designed this new product with both quality and function in mind. We are proud to say that we have achieved that goal. No other controller device on the market matches the quality or the overall functionality of the Forza Controller. Check for yourself. From the wiring connections to the electronic enclosure … no other exhaust controller compares.
I have posted all the details in the Sponsor section and invite you take look.
http://www.camaro5.com/forums/showthread.php?t=398390
I think you will agree that the Forza Controller is the best exhaust controller available.
If you have any question, feel free to post them.
Thanks
Steve
Forza Componenti
forzasteve is offline   Reply With Quote
Old 03-03-2015, 07:06 PM   #2
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Welcome..
Just so I'm clear. When this is in closed position the car is basically back to stock configuration where it will open and close.
Old 03-03-2015, 07:19 PM   #3
forzasteve
forzasteve's Avatar
Hello mlee,
You are correct. When in the "closed" position, full control of the exhaust bypass valves return to the car. In this mode, the car's ECU manages the opening and closing ... just as it does without the controller.
When you press the button to open the valves, they are open all the time.
Regards,
Steve
Welcome..
Old 03-03-2015, 07:39 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Good deal... looks like you have it packaged up for a nice easy install.
Glad to have you on the forum
Old 03-03-2015, 09:49 PM   #5
forzasteve
forzasteve's Avatar
Hi mlee,
I certainly try for that. In my experience, it is very frustrating to go to install something and your missing some part or some details on instruction. With my other controller and this one, I spent many hours writing up and testing the installation instructions. And, I am including accessories to help out as well.
Regards,
Steve
Old 03-04-2015, 07:55 AM   #6
Ashley2202
Drives: 2013 camaro convertible SS
so in other words this is for the exhaust cut off system do youhave the rest of the parts if so will this void any warranty i have
Ashley2202 is offline   Reply With Quote
Old 03-04-2015, 08:39 AM   #7
omegaman
omegaman's Avatar
Drives: very poorly
Send a message via AIM to omegaman
The Forza controller is excellent
The Forza dual mod exhaust controller is excellent. The price is a steal at $78.50 which includes free shipping. I have this very model installed on my ZL1. The kit includes every thing you need to do the installation.
Two things I really like about the controller. One, the controller can be configured to use either the wireless remote (included) OR you can hard-wire it so it can be activated by a switch that you could install in the cabin somewhere (cabin switch not included). Two, the controller has a lighted push-button (LED) on/off switch that allows you to switch off the unit if the car is not going to be driven for an extended time. The current draw of the unit is minimal, but best to shut off the unit if not driving the car for 2-3 months.
Installing the unit was easy, but I did have to notch the existing plastic fuse box cover to make room for the fuse-tap wires. And I did use a zip tie to get the fuse box cover to stay on - the fuse-taps are just tall enough to keep the fuse box cover latches from engaging fully.
2013 Camaro ZL1, Crystal Red, Auto, Exposed Carbon Fiber, Navigation.
omegaman is offline   Reply With Quote
Old 03-04-2015, 08:45 AM   #8
omegaman
omegaman's Avatar
Drives: very poorly
I don't know for certain, but i don't think it would void the warranty of the exhaust bypass valve itself. What the Forza controller does is intercept the power going to Camaro's exhaust bypass valve relay - so basically it just reroutes the power. The Forza controller is fully fused so as not to cause a short-circuit. Also, the controller will only work if you have a Camaro with the Dual Mode Exhaust option (NPP).
Old 03-04-2015, 09:11 AM   #9
forzasteve
forzasteve's Avatar
Thanks, Perry, for the review. I appreciate it very much.
I do not think there should be any issue with the warranty. The controller is in effect opening and closing the circuit to the vacuum solenoid valve. This is akin to pulling the fuse. There are Chevrolet dealers here and there that are actually providing dual mode exhaust controllers. So, they obviously recognize that the action of opening and closing the circuit to the vacuum solenoid valve is not a problem.
What many people have done is merely pull that fuse out and leave it out. Obviously a very inexpensive solution ... but, once it is out, it is not a quick matter to put it back in.
Regards,
Steve
Old 03-04-2015, 05:49 PM   #10
vatechguy3
Drives: 2014 ZL1 M6
Anyway to make this a 3 way controller?
This way you could have open, closed, or off (let the car control it).
Tony
2014 ZL1 M6
Bone stock, for now!
2001 Z28 M6
!cags, !air, FTP 85mm Lid, Z06 85mm MAF, P&P TB
!4x4, Strano Springs, Strano Sways, Koni 4/4s, Watts Link
ARH LTs, ARH catted Y, SLP catback with Dual/Dual Muffler, SLP CME and Valance
OE Wheels Machined Face C5 DDs, 18x10.5s, with 295/35-18s on all 4 corners!
352rwhp and 366rwtq
vatechguy3 is offline   Reply With Quote
Old 03-04-2015, 05:53 PM   #11
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
how is this any different from the mild2wild?
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 03-04-2015, 06:03 PM   #12
omegaman
omegaman's Avatar
Drives: very poorly
Tony
Tony, you're suggestion is close to how the controller works. With the unit switched on (receiver is listening for the remote) there are two modes you can choose. First mode allows the car's ECM unit to control the exhaust valve just as it did from the factory. Second mode is always open. I suppose Forza could make a model that would keep the exhaust valve always closed (silent mode).
Old 03-04-2015, 06:07 PM   #13
omegaman
omegaman's Avatar
Drives: very poorly
Good question. I wondered about this also. Fortunately Forza has a page that does a complete comparison between their controller and Mild2Wild. Here is the link to the comparison. Go to tabs at bottom of linked page. There you'll find the comparison.
Old 03-04-2015, 06:54 PM   #14
sd1611
sd1611's Avatar
Drives: 2014 1SS RS- RRM - NPP Exhaust
Tony
This is exactly what I am looking for as well.
Stainless Power LT headers with HF cats / NPP exhaust / C.A.I. cold air intake / OEM ZL1 wheels
sd1611 is offline   Reply With Quote
