03-10-2015, 08:04 AM | #1 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
Blower Cams
Who makes the best blower cam for a centri type blower?
03-10-2015, 10:47 AM | #2 |
Drives: IOM 2SS/RS Join Date: Dec 2011
Ecs has one available or you can just have someone spec a custom one for your needs
03-10-2015, 11:04 AM | #3 |
USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Have Pat Guerra custom spec you one for your application. He's one of the best.
http://www.guerragroup.com/#!camshaft-help/c1mq5 Or go with an off the shelf one that will work fine, just not optimized
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
03-10-2015, 11:36 AM | #4 |
Pat G is a great choice
Ed Curtis Martin@Tick Brian@BTR John@LJMS All of them can spec you a centri cam for your needs. I used Pat G and I'm happy, but would gladly run whatever any of the above recommend.
Nick
Corvette Z06 -1200ish rwhp |
03-10-2015, 12:07 PM | #5 |
Just use a N/A cam of your choice. Centris love em.
03-10-2015, 12:09 PM | #6 | |
Thanks just sent him a request. |
03-10-2015, 02:10 PM | #7 |
Drives: 1999 Trans Am Join Date: Jul 2009
03-10-2015, 03:47 PM | #8 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Boosted CAM
My vote would be to use a Dallas Performance cam
__________________________________________
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
03-10-2015, 04:47 PM | #9 |
Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
My guy has his own spec cams and his boost cam on an eforce car made 90 hp from just the cam only nothing changed on the car besides the cam. This is unheard of but I can show you the logs and Kurt Urban worked with Tracey on these cams and he can vouch for the claim also and if you all know who Kurt Urban is it says a lot. Id HIGHLY recommend you get a hold of my guy and give the boost cam a try you will be surprised with the results guaranteed.
03-11-2015, 06:40 AM | #10 |
03-11-2015, 01:31 PM | #11 |
Drives: T Join Date: Mar 2015
03-11-2015, 01:39 PM | #12 |
03-11-2015, 02:27 PM | #13 |
Drives: 2011 Synergy Green 1xxxrwhp Join Date: Sep 2012
I have a stock ZL1 cam for sale....
I have worked with Geoff Skinner @EPS for about 7 cams now and everyone of them has been great. my cam for the first build was unreal on the whipple... |
03-12-2015, 10:49 AM | #14 |
boosted vs non boosted cams
I was running a NA cam and the car ran fine with it but the boosted cam the car has a better pee band
