#Camaro6
AWE Tuning
Old 03-30-2015, 07:05 AM   #1
Jbryant910
Drives: 2014 Malibu
Exclamation OFFICIAL: 2016 Camaro weight at least 200 pounds lighter (March 30 update)
http://media.chevrolet.com/media/us/...30-camaro.html
2016 Camaro Does More with Less
New model is at least 200 pounds lighter than current car
2015-03-30
DETROIT – For the all-new, 2016 Chevrolet Camaro, the team was challenged to improve the handling, acceleration and fuel economy of the award-winning current model.
To meet all three objectives, the team focused on a singular mission: reduce mass. By obsessively searching for opportunities to save ounces, the team pared more than 200 pounds off the Camaro compared with the fifth-generation model.
As a result, the Camaro does more with less, according to Al Oppenheiser, Camaro chief engineer:
“We kept the cornering confidence and control that make the Gen 5 Camaro 1LE so fun to drive, and added a greater sense of agility,” he said. “The new Camaro brakes harder, flicks into corners more quickly, and drives out of the corner faster. We expect it will set the benchmark in the segment and give many sports cars a challenge.”
A new architecture, one of the most mass-efficient ever from General Motors, is responsible for much of the weight savings.
Additionally, dozens of small changes cumulatively contributed to shedding pounds. For example, the beam that supports the instrument panel is now made of aluminum, saving 9.7 pounds (4.4 kg) over the steel beam on the current generation Camaro.
In addition, the front and rear suspension assemblies are now aluminum, and links on some models feature an intricate, structurally optimized design made with a rigid composite material that’s even lighter than aluminum. As a result, the total weight for the suspension is 21 percent lighter compared to current steel-intensive assemblies.
Chevrolet will introduce the all-new 2016 Camaro on Saturday, May 16, during a special public event at Detroit’s Belle Isle Park.
The 2016 Chevrolet Camaro features an aluminum beam to support the instrument panel, which is 9.7 lbs. (4.4 kg) lighter than the previous steel beam. Changes like this help reduce total curb weight for the new Camaro by more than 200 pounds.
The 2016 Chevrolet Camaro features aluminum front and rear suspension assemblies, with links on some models made of rigid composite material that’s even lighter than aluminum. As a result, the total weight for the suspension has been reduced 21 percent, compared to the previous, steel-intensive assemblies.
Jbryant910 is offline   Reply With Quote
Old 03-30-2015, 07:19 AM   #2
PYROLYSIS
Remember the Charleston 9
PYROLYSIS's Avatar
That would put a 1LE at 3660 pounds! Awesome news.
Old 03-30-2015, 07:31 AM   #3
BahamaTodd
BahamaTodd's Avatar
Drives: 08 Accord V6/M6 / 04 Canyon Z71
So only certain models get the composite speed holes...
BahamaTodd is offline   Reply With Quote
Old 03-30-2015, 07:37 AM   #4
DrkPhx
DrkPhx's Avatar
That's outstanding news. Good job GM. I wonder if they'll take it further for the hi-po models.
Old 03-30-2015, 08:01 AM   #5
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
I'll have to check the door sticker again but I tbink the 2015 1LE has a curb weight of over 3900 lbs.
I hope this means the curb weight will be 200 lbs less and not like the Mustang where the chassis was lighter but the finished car ended up heavier.
Bhobbs is offline   Reply With Quote
Old 03-30-2015, 08:08 AM   #6
Jbryant910
Drives: 2014 Malibu
Yeah, that's the first thing I thought about when I saw that. I'm hoping for the SS to come in at or below 3700lbs. That might just happen.
Old 03-30-2015, 08:23 AM   #7
Splitter
Drives: '14 RRM 1LT/RS A6
Woot!
Splitter is offline   Reply With Quote
Old 03-30-2015, 08:27 AM   #8
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
Another link, just different text.
http://blog.caranddriver.com/less-pa...r-2016-camaro/
oneredry is offline   Reply With Quote
Old 03-30-2015, 08:32 AM   #9
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
I don't like the way this is worded:
Makes it seem like it will be inferior to the 5th gen in other aspects, but the weight will help keep it better. If you know what I mean.
Old 03-30-2015, 08:36 AM   #10
ChefBorOzzy
ChefBorOzzy's Avatar
Drives: 2016 F150
I take it as less brakes, less tires, less wheels.. Sounds good to me.
ChefBorOzzy is offline   Reply With Quote
Old 03-30-2015, 08:39 AM   #11
DenverTaco07
DenverTaco07's Avatar
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot
I read it as more performance, less weight, but that's just me i guess.
DenverTaco07 is offline   Reply With Quote
Old 03-30-2015, 08:40 AM   #12
iPODFAN11
iPODFAN11's Avatar
Drives: 2019 Shock ZL1
More with less...read that as in outperforms the Gen 5 and at the same time as less mass in turn producing a better car. Add lightness.
From Super Chevy mag, April 2002: "Most of the weekend Settlemeire was meeting and greeting and quickly became known as simply "The Camaro Dude" (note, even his initials are SS)."
we're certainly looking at it -- but right now, the emphasis MUST be on getting the Camaro V6 and SS out -- and having it exceed your expectations....
Once that's done....................
iPODFAN11 is offline   Reply With Quote
Old 03-30-2015, 08:41 AM   #13
terri_Lovehands
terri_Lovehands's Avatar
Drives: 2016 1LT RS NPP
I took it as less weight, i don't see them making other aspects inferior, i took it as, we're using different materials and engineered things a bit differently so that it would weigh less but outperform the previous incarnation.
terri_Lovehands is offline   Reply With Quote
Old 03-30-2015, 08:44 AM   #14
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Awesome, but I agree with others and hope this doesn't turn out to be a let down when they made the statement that the Mustang would weigh less.
BaylorCamaro is offline   Reply With Quote
2016 camaro, 2016 camaro forum, 2016 camaro forums, 2016 camaro pounds, 2016 camaro spy, 2016 camaro spy photo, 2016 camaro spy photos, 2016 camaro spy pics, 2016 camaro weighs, 2016 camaro weight, 2016 chevrolet camaro, 2016 chevy camaro, 2016 chevy camaro pounds, 2016 chevy camaro weight, 2017 camaro, 2017 chevy camaro, 6 gen camaro, 6th gen camaro, 6th gen camaro forum, 6th gen camaro forums, 6th gen camaro info, 6th gen camaro news, 6th gen camaro rumors, 6th gen camaro weight, 6th gen chevrolet camaro, 6th gen chevy camaro, 6th gen chevy camaro forum, 6th generation camaro, 6th generation camaro info, 6th generation camaro news, 6th generation camaro rumors, 6th generation chevy camaro, camaro 6th gen, camaro 6th generation
