Old 03-30-2015, 02:28 PM   #1
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
2015 ZL1 knock? Conclusion @ 4/27/15
Hey everyone, I'm new to Camaro5 and also a new first-time Camaro owner. Please forgive me if I'm asking a question that is common knowledge, I did try to use the search :/
I have a 100% stock 2015 ZL1 6spd MT which I bought new 2 weeks ago with only 25 miles on the Odometer.
The car consistently knocks while WOT from 2000rpm and maybe 33% of the time while WOT from 3000rpm. It occurs as soon as I see the boost gauge hit boost, it never knocks prior to boost. These aren't loud knocks and its not drivetrain noise and its not the supercharger clunking as far as I can tell. It's just a light tat tat tat that happens a few times when I'm WOT and then goes away. The car feels slightly down on power but not huge.
I've followed proper break-in procedure and now have 1600 miles on the car. The car has been knocking or at least what I believe is knocking since day 1. For the first 500 miles I assumed the dealer put crap gas in the car but by now I've definitely eliminated any of the original gas, I even tried octane booster since we only get 91 octane here in San Francisco. So then I thought maybe it just needed to do some knock learning and I should finish break-in and stay out of boost.
I decided to buy an Moroso Oil Catch Can and its on the way but I'm weary about touching the engine, I don't want anyone saying I voided my warranty.
If anyone has any insight to this, I'd love to get this awesome car running properly. Bear in mind I'm guessing this is a knock, it could be something else -- let me know if you have other ideas.
Thanks!
UPDATE @ 4/4/15: Dropped off at Fremont Chevrolet Post 77
UPDATE @ 4/7/15: GM Tech Round 1 Post 116
UPDATE @ 4/9/15: GM says, "Ignore what I said before" Post 168
UPDATE @ 4/10/15: GM says, "Knocking is normal". angryBits tries Race Gas! Post 216
UPDATE @ 4/13/15: KR @ 98 octane Post 248
UPDATE @ 4/27/15: HP Tuners Log File attached w/ KR Post 308
UPDATE @ 4/27/15: Conclusion & Juicy Data Post 310
angryBits is offline   Reply With Quote
Old 03-30-2015, 02:37 PM   #2
Vick415
Vick415's Avatar
Drives: 2014 ZL1
This one will be a bit tough to diagnose over a forum. If at all possible try to upload a audio/video so people can hear and provide a more concise opinion. Or invest in a unit like Dashlogic so you will be able see real time readings from your ECU. I see you are in the Bay Area, you are welcome to use mine if you are near the HMB.
Sent from my iPad using Tapatalk
Vick415 is offline   Reply With Quote
Old 03-30-2015, 02:44 PM   #3
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
I'm actually in Pacifica, we're neighbors
Since you're get the same gas as I do, have you had any detonation issues?
Getting an audio/video clip would be tough, its not very loud -- my wife can't hear it and says I'm crazy but I know that "tat tat tat" my STI and Mazdaspeed 6 both made the same "tat tat tat" under boost until I got them properly tuned, but I don't want mess with this car until I trust it more. I saw someone on this forum blew a stock engine while just driving down the street -- I'd hate to pay for that myself.
Old 03-30-2015, 02:53 PM   #4
boondocksaint
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla
You wouldn't. That's what the warranty is for.
boondocksaint is offline   Reply With Quote
Old 03-30-2015, 03:04 PM   #5
Vick415
Vick415's Avatar
Drives: 2014 ZL1
I use several alarms setup within Dashlogic, detonation being one of them. So far no issues, however I am no longer on stock tune.
Heck you are few minutes from me feel free to PM
Old 03-30-2015, 03:12 PM   #6
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Does Dashlogic require you to load software onto the car? I'm hoping to avoid that.
Old 03-30-2015, 03:13 PM   #7
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
That's why I'm trying to avoid touching the engine. I don't want anyone at GM to even think "voided warranty"
Old 03-30-2015, 04:04 PM   #8
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Sounds like bad gas to me....
SF bay area is used to Prius not ZL1's. lol j/k
The DashLogic is a great plug and play device that allows you to monitor your engine vitals. No software or tune needed.
Mods:
Old 03-30-2015, 04:05 PM   #9
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
Thanks!
I maybe wrong but if it is a 2015 I would take it back to the dealer and let them check everything out if there is a problem it won't be your problem!!!
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 03-30-2015, 04:46 PM   #10
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
I completely agree. But I'm afraid they're going to hold onto it for a week and then just tell me "It's normal for these cars".
I'll take it to the dealer if I have to but I'd prefer to try and diagnose it myself if I can.
Current: 2019 ZL1 1LE A10
Mods: MPS4s Tires | Borla Atak | CF Steering Wheel
Previous: 2018 ZL1 1LE M6 | 2017 Z06 Z07 M7 | 2017 GS A8 | 2015 ZL1 M6 | 2013 GT500
Old 03-30-2015, 04:49 PM   #11
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Seems there are a few ZL1 C5 members that live in your area. I would be nice to them a arrange a meet up. Then you can test drive each others cars and make sure your not just hearing things.
Worth a shot.
Mods:
Old 03-30-2015, 05:07 PM   #12
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Worth a shot.
That is a good idea.
I also took Vick415's advice and bought a DashLogic. It will tell me about the knock plus it seems like a cool thing to have anyway.
Old 03-30-2015, 05:25 PM   #13
hawk02
Coupe Newbie
hawk02's Avatar
Drives: '23 CT5-V BW, '21 Corvette HTC
I think I'd take Vick415 up on his offer to use his Dashlogic. It just plugs into the ODBII port and makes absolutely no changes to the ECU calibration.
Vick415 says he already has an alarm setup for detonation. If it goes off when you hear the tat, tat, tat, then you know you have a knock problem. If doesn't go off then you can be fairly certain that the sound your hearing is caused by something other than knock.
hawk02 is offline   Reply With Quote
Old 03-30-2015, 05:40 PM   #14
angryBits
angryBits's Avatar
Drives: ZL1 1LE A10
Ended up buying my own DashLogic.
If I see that it's knocking, then I'll take a look at the AFR and if it's way off then its probably something wrong with the MAF or intake. Otherwise, I'll try the oil catch can. If that doesn't do it -- it's going back to the dealer :(
