Old 04-11-2015, 12:30 PM   #1
jergarr
jergarr's Avatar
Drives: 11' RJT 2SS/RS L99
Tire size for 18x9.5 wheel
Soon I will be running 18x9.5 on all corners and I'm looking for input on front tire size. I'm gonna run 305 45 18 drag radial for the rear but want to know what size tires I should use for the front?
GPI VVT3 Cam
Circle D 3800 Single Disc Stall
1LE 3.91s
Stainless Power Headers w/cats
Fluidampr 25% UDP
Cold Air Inductions Intake
Bo White Ported Throttle Body
ADM Trans Cooler
Some BMR Goodies
jergarr is offline   Reply With Quote
Old 04-16-2015, 10:04 PM   #2
jergarr
jergarr's Avatar
Bump?
GPI VVT3 Cam
1LE 3.91s
Fluidampr 25% UDP
ADM Trans Cooler
Some BMR Goodies
Old 04-17-2015, 10:11 AM   #3
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
Nitto Motivo 265/50R18 in front, Nitto NT05R 305/45R18 in back. Never set ABS codes. And you still have dibs I might have them off finally on Saturday.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 04-17-2015, 09:31 PM   #4
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
What wheels are those and what's the offset on them?
IOM Black Diamond is offline   Reply With Quote
Old 04-18-2015, 10:30 PM   #5
jergarr
jergarr's Avatar
Thanks I'm definitely still interested in them. Also did you buy special lug nuts for the 18's or does the OEM work fine?
GPI VVT3 Cam
1LE 3.91s
Fluidampr 25% UDP
ADM Trans Cooler
Some BMR Goodies
Old 04-18-2015, 10:52 PM   #6
Pro Stock John
Writer
Gorilla lug nuts. Never tried the stock ones, they might work.
18x9.5 ZR1 replicas, +40mm offset. Fronts fit with some work.
PROJECT HEAVY CHEVY
