Old 04-14-2015, 02:31 PM   #1
Team STILLEN
Team STILLEN's Avatar
Drives: Varies
Stillen - ZL1 AP Radi-CAL Big Brake Kit
For the last 30 years, Stillen has been one of the world leaders in providing the best in aftermarket products, service and expertise.
A little over a year ago, I started a thread to introduce our NEW AP Radi-CAL Big Brake Kit to the Camaro 5 world and now we would like show what our Big Brake Kit can do for the ZL1!
Here is a little quick rundown again on our AP Radi-CAL Big Brake Kit…
Stillen and AP Racing has launched the new AP Racing Radi-CAL line of calipers used in the STILLEN-engineered Big Brake Kits. These new Radi-CAL road calipers get there heritage from the racing Radi-CAL high performance calipers launched in motorsports in 2007, which have been dominating the likes of F1, F3, NASCAR and countless others. This new caliper design features a 2-piece aluminum body with H-structure, and a non-symmetrical design developed to have a large reduction in mass yet improved resistance to braking torque. Another benefit is increased caliper cooling surface without decreasing structural rigidity.
- Each kit is designed specifically to the vehicle application with special attention to proper piston and rotor sizing to match OE ABS, stability control systems and brake balance.
- Hats and brackets are designed and engineered in Stillen's R&D Department and machined in house with the latest CNC lathe and mill machining.
- Each Kit design is based on vehicle weight, heat index required at maximum speed and GVW to provide repeated high speed stops while managing the heat in the most efficient way using components designed and validated for a high performance environment and every day road use.
- Each kit is complete with calipers, pads, rotor assemblies, hardware, brake lines and instructions.
- Track braking performance that is safe and compliant for road registered vehicles.
Radi-CAL Calipers
- Derived from AP Racing's patented and widely successful race Radi-CAL Calipers
- The unique asymmetrical designed and forged aluminum caliper bodies are tested at over 500,000 cycles of pressure and torque to meet AP Racing's stringent high performance and OE road use validation requirements to provide maximum stiffness and reducing weight.
- Opposed piston design provide better pedal feel and immediate brake response.
- The 6 and 4 piston caliper design allows larger pad surface area to be used which decreases heat at the friction point between the pad material and rotor surface.
- Differential piston sizing to minimize pad taper.
- Forged removable bridge support for east pad change and additional strength to the caliper mouth.
AP Racing Rotor Technology
The AP Racing discs in the Radi-CAL big brake kits are directionally curve vane vented for maximum air flow through the disc. AP Racing's unique curve vaned discs are Dyno and race proven as the best designed rotors for optimized cooling. The curve vane rotor acts like an air pump pulling air into the center of the rotor and blowing it through the veins and out of the top of the rotor. This act allows the rotor to be self-cooling and work extremely efficiently.
AP Racing's Wide Disc Technology (WDT) is used for the most efficient way to transfer heat from the disc. Designs using wider discs with larger air gaps increase air flow rates within the discs as proven by AP Racing's FEA, CFD and TSA testing. This goal was achieved while not increasing disc weight or disc stress and decreasing disc temperatures by up to 300 degrees F.
Larger two piece rotors allow for greater thermal capacity with an eye on weight by using aluminum center bells (hats) that minimize the unsprung weight of the overall disc assembly. This means greater heat management without increasing corner weight. It also increases the effective radius (leverage point) of the brake system which creates more brake torque with same braking effort.
- Designed for larger and wide rotors with taller annulus to increase thermal capacity and reduce rotor surface temperatures for increased pad and rotor life.
Last week, one of our customers took his ZL1 out to Laguna Seca with a newly installed Front and Rear AP Radi-CAL Big Brake Kit!
Front and rear kit details
10-14 Camaro APR77300 Front 6-Piston Calipers 390x36mm 2-Piece floating Rotors
10-14 Camaro APR77600 Rear 4-Piston Calipers 380x26mm 2-Piece
floating Rotors
Stainless steel braided brake lines
Aluminum mounting brackets and bells engineered and manufactured at STILLEN in Costa Mesa, California
Fits with factory ZL1 wheels
What happened next was a very happy customer!!
Our customer was able to knock off nearly 5 seconds from his lap time switching from his stock Brembo Brakes to our AP Radi-CAL Kit! No other modification had been made to the vehicle between his previous Laguna Seca session. He reported to us that he was able to enter the corners deeper – well into the 300-200 ft braking zone with confidence and no brake fade using the standard brake pads that come with the kit. His confidence in the brakes allowed him to set the attitude of the car confidently and consistently. Something he reported was not possible with the factory Brembo brakes which exhibited fade and overheating after just a few laps during his previous track sessions.
Even though our customer is an intermediate driver, if you don’t have confidence in your brakes at the race track, you will not be able to reduce your lap times.
Here are a few pictures…
Name:  AP Radical Camaro 2.jpg
Name:  AP Radical Camaro 3.jpg
Name:  Camaro ZL1 AP Radical Laguna Seca 2.png
Name:  Camaro ZL1 AP Radical Laguna Seca.png
Name:  Camaro ZL1 AP Radical Laguna Seca 3.png
Name:  ZL1 AP RadiCal.jpg
Team STILLEN is offline   Reply With Quote
Old 04-14-2015, 02:35 PM   #2
NW Sam
NW Sam's Avatar
Drives: 2017 ZL1 Garnet Red
What is the cost of the J hook brake kit front and rear? Thanks, Sam.
NW Sam is offline   Reply With Quote
Old 04-14-2015, 02:40 PM   #3
ZL1-V
Drives: 2013 Camaro ZL1
Very nice! I used a somewhat similar kit from you years ago on my supercharged Escalade. For being so damn heavy, that particular SUV could really STOP!
ZL1-V is offline   Reply With Quote
Old 04-14-2015, 02:48 PM   #4
Team STILLEN
Drives: Varies
PM sent!
Thanks
Yeah, these kits are, I believe, the best in the market right now!
JT
Old 04-14-2015, 03:16 PM   #5
ZL1-V
Originally Posted by Team STILLEN View Post
PM sent!
Thanks
JT
Um, I think you might be a bit biased?
I have used Baer brakes kit, your AP Racing kit, and Brembo twice with a CTS-V and now the ZL1. They all worked well.
Old 04-14-2015, 04:23 PM   #6
Team STILLEN
Drives: Varies
Just a little.
JT
Old 04-14-2015, 04:50 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
5 secs improvement ove the stock OEM Brembo set up...
Kinda find that hard to belive.
What makes these calipers/brake pads better over the OEM set up?
Not trying to bash this aftermarket kit. Just trying to understand the difference or improvement over the OEM Brembo's'.
Thx
Mods:
Old 04-14-2015, 05:09 PM   #8
Team STILLEN
Drives: Varies
Thx
Hey,
No worries man. I knew that posting the info that we will get questions.
The customer wasn't very confident with his OEM set up because of over heating. So after switching over to the AP Radi-CAL kit, he was able to get around the corners a lot sooner and braking later. Our customer told us he had a lot of brake fade. With the AP Kit he did not have any brake fade.
The OEM set up uses a Front 370x34 mm 2pc rotor and the rear uses a 365x28mm 1pc rotor.
Our AP Radi-CAL kit uses a 390x36mm 2pc rotor and the rear uses a 380x28mm 2pc rotor.
This gives you a bigger pad area against the rotor, better air flow and a trackable brake system for the street.
The biggest thing here when we designed the kit was managing the heat through a larger brake system.
JT
Old 04-14-2015, 05:12 PM   #9
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Hey,
JT
Ok, that makes for a better comparison.
Thx for the info.
Mods:
Old 04-14-2015, 05:16 PM   #10
Team STILLEN
Drives: Varies
Thx for the info.
No worries man!
JT
Old 04-15-2015, 08:50 AM   #11
Nickey31
Nickey31's Avatar
Drives: 2012 Nickey ZL1 #001, 2014 Corvette
Great looking brakes kit. Was the test vehicle using OEM brake fluid and what brake fluid is used for your kit? I am sure you will agree that will account for some improvement in peddle feel and brake fade.
Nickey31 is offline   Reply With Quote
Old 04-15-2015, 10:49 AM   #12
Team STILLEN
Drives: Varies
The customer was using the AP Ultra 5.1 fluid.
The temperature did not get high enough where he needed to go with a higher boiling point fluid.
But we do have customers with track only cars running AP 600 and AP PRF660.
JT
Old 05-01-2015, 02:02 PM   #13
Team STILLEN
Drives: Varies
I am able to offer a discount on our AP Radi-CAL kit if you are interested!
The discounted price will be good until May 14th!!
floating Rotors
PM or Call me with any questions!
Thanks
JT
Old 05-01-2015, 02:08 PM   #14
ZL1Naboz
ZL1Naboz
ZL1Naboz's Avatar
Drives: '13 ZL1, ‘53 Chevy Pickup, ‘22 GMC
PM Price please
floating Rotors
Thanks
JT
Rotofab CAI, Big Gulp & Washer Bottle Relo, MGW, Kook's w/Hiflo Cats, SCT4, Jannetty, 35% tint, Oracle Side Markers, MTX Sub, Escort 9500ix - Blendmount, 18% Lower, ATI Super Damper, ID850 Injectors, Moroso Catch Can, MSD BAP, AFCO Heat Exchanger
Pre-Pulley Dyno
559.92 RWHP 519 RWTQ
ZL1Naboz is offline   Reply With Quote
