Old 05-03-2015, 07:20 PM   #1
zr1chris
zr1chris's Avatar
Drives: 2018 Camaro 1SS/1LE
UPDATE: Finished adding color to my wheels.
Well I finally found a vinyl that I think is a close enough match to IOM. It's 3M Fiery Orange.
I'd like some opinions of if you think the color is close enough and also about my idea.
This vinyl does crazy stuff under different lighting.
Here's the 1st scenario
Now this angle looks like a perfect match.
Now finally here is a sample size of my idea. I want to do the entire inner barrel of the wheel.
Got 1 side done! More work than I thought but came out good. Just wish it showed up a bit more.
Sun shining through the front.
Back side.
Its a damn shame I can't this much light to shine through with the wheel mounted.
Mounted.
zr1chris is offline   Reply With Quote
Old 05-03-2015, 08:08 PM   #2
Whoomba
Drives: 2024 Camaro 2SS CE Convertible
Hey, I like that idea. That should look good if you can get it applied right. Subtle yet a splash of color.
Whoomba is offline   Reply With Quote
Old 05-03-2015, 08:15 PM   #3
CruzinQueen
CruzinQueen's Avatar
Drives: 2017 1LT RS Convertible V6 A8
Interesting idea. I'll save my judgment for when its complete.
CruzinQueen is offline   Reply With Quote
Old 05-03-2015, 08:19 PM   #4
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2018 ZL1 1LE
It will look similar to a dodge challenger redline edition wheel (which look great in person)
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
Old 05-03-2015, 08:45 PM   #5
zr1chris
zr1chris's Avatar
To be perfectly honest that is where I got the idea from. I parked next to a black one at my local Walmart parking lot. I think these wheels will show a little more of the color. The inner barrel on my wheels come more to the outside edge of the wheel.
You guys think this color is close enough?
Old 05-03-2015, 09:12 PM   #6
Fieryfight
Fieryfight's Avatar
Drives: 2011 Camaro 2LT IBM Convertible
wouldn't it be possible to get the vinyl pin striping like what is used on motorcycle rims and use it on our cars? if so maybe get some in the color vinyl that you found.
...........................................2011 2LT IBM Convertible
Fieryfight is offline   Reply With Quote
Old 05-03-2015, 09:17 PM   #7
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
I think it's a nice idea, it's not exact match but close. Besides it might be difficult to tell the difference being that there would be space between the colors. Like your not putting the vinyl right on the paint
45thCamaro is offline   Reply With Quote
Old 05-03-2015, 09:28 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Man that's really close an a really cool idea I might think about doing it to my charcoal factory wheels.....
Where did you find it?
Old 05-03-2015, 09:39 PM   #9
zr1chris
zr1chris's Avatar
That's exactly what my thought was when I started looking and couldn't find IOM vinyl. Just has to be close enough...
www.metrorestyling.com
Old 05-04-2015, 11:40 AM   #10
zr1chris
zr1chris's Avatar
Well I went and ordered 4 1'x5' rolls of vinyl. Hoping I get it by Friday. If I end up with the vinyl and the day off then that will be project day.
Old 05-04-2015, 08:52 PM   #11
MagooJr
Drives: 2010 2SS ABM, 68 SS/RS 396 4sp
3m ABM
My family and friends are split
MagooJr is offline   Reply With Quote
Old 05-04-2015, 10:46 PM   #12
The Patriot
Drives: 2014 2SS/RS VERT
THAT doesn't appeal to me, but the idea of running it in the barrel is genius!
2014 2SS/RS Vert.
"Today I didn't even have to use my AK, I got ta' say it was a good day"
The Patriot is offline   Reply With Quote
Old 05-04-2015, 10:52 PM   #13
JT Camaro
JT Camaro's Avatar
Drives: 2018 ZLE
I tried it in the barrel years ago on my Chargers rims.
Could never get it to stick well enough with years of grime in the barrel. Became a major nuisance to clean as well with all the brake dust.
Hope you have better luck! Would be awesome!
JT Camaro is offline   Reply With Quote
Old 05-05-2015, 12:35 AM   #14
zr1chris
zr1chris's Avatar
Thanks guys!
I did try sticking a previous sample to that part of the wheel to see how it stuck and it seems to work perfectly. Even better than I thought.
Vinyl shipped today!!
At first Glace it almost looks like it's just a reflection of the paint showing on the spokes. Definitely doesnt look bad but not sure if I like it...
