| Member Car Journals Want to keep a long term Camaro project journal to share with the community? Use this forum to create a single thread which you can update over time to document the progress. |
Thread Tools |
[COTW 4/11/10]: ITMERC's Hennessy HPE800 Project
Featured COTW on Homepage.
Hi Folks, I've been holding off on starting this till we got close to finishing the main part of the build and now seems like the right time to kick off the thread! ![]() I've been working with Hennessy to build a special 'built' block HPE650 with my Cyber Grey 2010 SS with all the normal stuff they put on their HPE650 PLUS: a forged/balanced/lowered compression/coated internals stroked 415 CID block, twin disk clutch, full Pedders Track Extreme suspension kit, Baer Extreme Plus 6 piston brake kit, 20" HRE P43 Monobloks... and too many tech details to go into. Its being badged a 650 primarily because their 700 is an LS9 and the 800 is a twin turbo! Heh!They got 592wheel hp on 91 octane out of a 'normal' HPE650 they did for a guy in Cali so I'm REEEEEEALY looking forward to seeing and reporting to you all what they get out out my 'built' forged motor next week on the 93 Octane we have here in TX. The motor is done and everything is installed but they need to work out an issue with the clutch and settle on how much boost they will be running before I get final numbers but its reasonable to assume it'll be significantly more then a 'normal' HPE650 since I went with a seriously 'built' motor specifically designed to safely run more boost and handle more power. I did my homework before choosing Hennessy so hold the bashing... They're 100% clean with the BBB for the previous 3 years which is as far back as they keep records for, they're local to me, their shop is big/well set up and BUSY, and to date they've been very professional so I look forward to reporting all the details as this part of the build nears completion. Pics, dyno graphs and details to follow! ************************************************** ***** For anyone who's interested I also have a Porsche Project I've been working on and the thread to that ongoing though basically finished bit of fun is posted at the link below: http://www.planetporsche.net/cayman-...onversion.html |
![]() Drives: 2010 1SS/RS Inferno Orange Join Date: Jun 2009
Sick. Looking forward for a dyno graph, and VIDS (I hope plz
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 13 Roush S3 05 Dodge Ram Daytona Join Date: Apr 2009
You had me at: [QUOTE=ITMerc;886021]I've been working with Hennessy to build a special 'built' block HPE650 with my Cyber Grey 2010 SS with all the normal stuff they put on their HPE650 PLUS: a forged/balanced/lowered compression/coated internals stroked 415 CID block, twin disk clutch, full Pedders Track Extreme suspension kit, Baer Extreme Plus 6 piston brake kit, 20" HRE P43 Monobloks... and too many tech details to go into.
Its being badged a 650 primarily because their 700 is an LS9 and the 800 is a twin turbo! Heh!QUOTE] LOL!! Sounds very nice man. |
[QUOTE=
LOL!! Sounds very nice man. They have it all installed and running but are having a problem with the new twin disk clutch that they hope to clear up after the holiday weekend. Hennessy convinced me that the Magnusson TVS2300 supercharger is the way to go on the LS3 but they're still discussing how much boost my 'built' block can reasonably run and still allow them to provide the 3 year warranty. Since I went with the fully 'built' motor stroked to 415CID with all forged/balanced/Polydyn coated internals and upgraded main caps/head studs etc (on top of the stuff included in their 'normal' HPE650) its reasonable to expect that this motor will safely put out a nice large chunk more Hp/Tq than the 592 wheel Hp they got out of the 'normal' HPE650 at 8PSI with OEM internals they have posted elsewhere in this forum that was set up for California on only 91 Octane. (93 is readily available here in TX) I'd guess that with the increased displacement and lowered compression that they'll have to run at least 10PSI, though this built motor should safely handle more than that. (Why bother with a 'forged' motor if it won't!) Before I pulled the trigger on this project I visited their facility a couple of times and John Hennessy took me for a ride down the drag strip out back. One in their red HPE550 Camaro and a wild ride in their yellow 700+Hp ZR7 Vette. VERY nice! I had considered doing a single turbo build with Fastlane here in Houston and Nick is a great guy with a nice shop and lots of forced induction experience so it was a hard choice. The pricing was roughly similar for my 'built' block project at either shop so in the end it was the 3 year warranty and the Hennessy name and resources that swayed my decision. |
Diamond forged/dished pistons with Polydyn coating
Interesting color!
#6 |
Heads
Polished combustion chamber, Ferrara hollow stem valves, Comp Cam springs/seats/retainers, Viton seals.
#7 |
Bottom end
Forged, balanced, Polydyn coated.
![]() Diamond forged dished pistons and wrist pins Diamond rings Compstar forged connecting rods Callies forged stroker crank 4.065 bore, 9:1 compression ratio |
#8 |
Very nice. Sounds like a stout engine.
![]() I would have to agree with the customer service/3 year warranty, that is a pretty easy choice. Keep us posted. |
#9 |
![]() ![]() Drives: 2 SS RS, YR, '97 WS6 blown Join Date: Jan 2010
any update on this ride?
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2LT/RS/GFX/M6 Join Date: Jan 2010
Jeez, I can't wait to see the final product. I am not a motor head but it sure sounds like you know what you are doing. Awesome.
"Reality is an illusion that occurs due to lack of alcohol" -W.C.Feilds
#11 |
Hi guys,
Instead of continuing to wrangle with the unhappy TVS2300 Hennessey offered me a deal to upgrade to their first twin turbo HPE800... It looks like Hennessey has 2 similar threads on the 800 now: http://www.camaro5.com/forums/showth...=hennessey+800 http://www.camaro5.com/forums/showth...=hennessey+800 It looks like when we stroked AND lowered the compression of my LS3 the air demand of the motor was outside the 'sweet spot' operating range of the 2.3l Maggie so we either neeed to go to a higher volume supercharger OR just do twin turbos... Who can say no to TWINS! ![]() We did some paint and a car show here in HOuston that stretched the build out a bit but we're hoping to have it 'finished' at the end of this week. I'm still looking into some interior work after I get the car back though that depends on scheduling of potential media coverage. Can't wait to drive it!!! Here's a couple of shots showing the Seibon CF hood and trunk with the metallic black paint scheme I added... We put the OEM wheels on for the paint process so these don't show the HRE P43 Monoblocks I have on there now.
"Life is a one lap Race... Carpe Diem"
#12 |
wow......really?
Your car is jaw dropping.
#13 |
Dyno sheet and video link:
YES, this build could make WAY more than 800 but 800 is what I was promised and they're over delivering. This on a very conservative tune and only 11psi of boost WITH a warranty on the motor.
#14 |
Incredible. Your ride will forever haunt my dreams.
#15 |
![]() Drives: 2010 Camaro CGM 2SS/RS Join Date: Aug 2009
Awesome.
![]() Kenne Bell 2.8 Polished & Black - Coolingmist Methanol Injection Stillen Front Splitter - Havoc Side Skirts & Rear Diffuser ICONZ Wheels & Nitto NT-05's - PFADT Springs |
#16 |
![]() Drives: ZL1, 2012 3500 Duramax Dually 4x4 Join Date: Jan 2010
Amazing numbers for 11psi boost!
drool |
#17 |
![]() Drives: 2011 Camaro SS/RS Cyber Grey Join Date: Oct 2009
:0
#18 |
![]() Drives: 90 Black Camaro, 02 Sable Join Date: Mar 2009
amazing
how much it cost ??
2SS/RS
Black/Black 6Spd. Aut. ![]() |
#19 |
![]() Drives: Cobalt SS/SC Join Date: Jun 2009
![]() ![]() ![]() ![]() I think I need to change my pants |
#20 |
#21 |
#22 |
Unless I'm mistaken, if you provide the base car the cost shouldn't be $100k... Of course the total project cost depends on what ELSE you do to the car... Suspension, brakes, wheels, etc. If you want to figure out YOUR out the door cost give em a call!
800hp twin turbo ANYTHING isn't pocket change though!
#23 |
Got any updated pics with your new wheels on?
#24 |
![]() Drives: 2010 CMG RS & 86 black Z28 3rd gen Join Date: Feb 2010
A freaking beautiful car! I wanted to go the way of the carbon fiber hood and trunk and the way you pulled it off looks so damn perfect. My engine won't ever come close to yours (I doubt anyone will), but your project makes me totally sold on going forward with the STS turbo for my V6. Once again, perfect ride, it looks amazing.
#25 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Rev-It-Up for Wounded Warriors Join Date: Nov 2009
Just WOW..............some serious coin spent on that BEAST!!!!
| Tags |
| hennessey, hpe800, itmerc, twin turbo |
| Thread Tools | |
